BMW M2 Forum > BMW M2 Competition Model > What did you do to your M2C today?
      02-20-2019, 07:08 PM   #529
bplewis24
bplewis24's Avatar
Drives: 2019 LBB M2 Comp; Tesla Model3
You guys who did the front lip, did you install it yourselves? How difficult is it?
I'm definitely getting the front splitter even if it reduces clearance some. The CF front lip I had on my last car took on several of the scratches that my front bumper would have eaten, and I much prefer it that way.
Brandon
      02-20-2019, 10:22 PM   #530
Frank K
Frank K's Avatar
Here are the installation instructions:
https://www.dropbox.com/s/vc9jkc9h1m...5ENEN.PDF?dl=0
I had mine installed at a shop, but it seems to be pretty easy to do. The glue part is a bit sketchy, but you can't really misalign it.
2019 M2 Competition: DCT, BSM, 29U (ordered 9/1, production week 41, finished production 10/8, at port 10/11, left Bremerhaven on 10/20 on Horizon Highway (K line), arrived in Southampton 10/21, Baltimore/MD on 10/31 and Brunswick/GA on 11/3, at dealership on 11/12)
      02-20-2019, 10:43 PM   #531
DSOmegaX
DSOmegaX's Avatar
221
Drives: 718 Cayman GT4, GR Supra
It’s pretty easy. Part aligns very well. There’s two holes you have to drill if I remember correctly. And even though the instructions call out to use liquid adhesive I would recommend just doing it with 3m automotive tape. Just make sure the surfaces are cleaned and properly primed and it’ll hold.
bplewis24188.50
      02-20-2019, 11:36 PM   #532
bplewis24
bplewis24's Avatar
Does it come with automotive tape already applied to it, like the rear spoiler does?
Brandon
      02-20-2019, 11:57 PM   #533
Frank K
Frank K's Avatar
No. Also the plastic pins and screws needed have separate part numbers.
      02-21-2019, 12:51 PM   #534
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
Definitely going to use 3m adhesive tape. That's plenty considering it also bolts to the car.
      02-21-2019, 01:13 PM   #535
AlpsRider
AlpsRider's Avatar
2865
I would think that 3M adhesive tape would be enough. That way it can be easily removed and sold when the time comes for a trade-in.
      02-21-2019, 01:25 PM   #536
DSOmegaX
DSOmegaX's Avatar
221
^This. If something happens you can remove it far easier than dealing with betalink. Also, theres a bit of a design flaw as far as I see it which is the lip covers some of the bolts needed to remove the front bumper, so if you ever need to remove the bumper...
@dsomegax.cars
2019 BMW M2 Competition | LBB | M Performance | Build Thread
2020 Toyota GR Supra | Turbulence | TRD | Build Thread
      02-21-2019, 06:40 PM   #537
warrenw
Food Critic
warrenw's Avatar
South Korea
1086
Drives: 19 AW M2C, 21 M340i
Installed a thing.
And painted a thing.
bplewis24188.50
///M Houbi1655.00
      02-21-2019, 06:48 PM   #538
skibrian213
Drives: 2017 Toyota Tacoma OR DCSB
Originally Posted by Proctor750 View Post
Working on eliminating the Achilles heels starting with the oil cooler protection plate.
Still need to upgrade the charge air cooler to avoid death by hydrolock.
Also debating between keyed or spline locked hub.
so 1/3 booby traps successfully defused.
edit: make that 1/4 - forgot about diff mount
Can you elaborate on these achilles' heels? Hadn't seen these mentioned before, tried searching and not finding much. I'm all about prevention and promoting longevity lol
Current: '17 Tacoma OR 6MT, '74 914 2.0L
2020 M2C LBB ordered, euro delivery in spring
Past: '11 135i 6MT, '95 M3 5MT, '01 B5 S4 6MT
      02-21-2019, 07:13 PM   #539
epic
M Comp
epic's Avatar
Pictures to come when Chicago stops being crappy outside.
Had the local shop put on:
  • M Carbon Fiber Rear Diffuser
  • IND Alpine White Front Reflector Deletes
  • IND Black Honeycomb Rear Reflector Deletes
  • AutoTecknic Carbon Fiber Paddles
  • M Performance Carbon Fiber/Alcantera Interior Trim (Shifter/Shifter Surround/Brake)
  • M Performance Carbon Fiber Steering Wheel Insert
  • IND Red M1/M2 Buttons
  • Spraypaint rear muffler
Unfortunately AutoTecknic sent two passenger side CF Mirror Caps so waiting for the drivers side in the mail. Now those will wait until I can place an order on the M Performance CF front splitter. Car is starting to look proper and how it should come from the factory.
'19 M2 Competition | '07 Heads/Cam/Stall C6 Corvette | '17 Ford Escape Titanium
Past: '14 M235i, '07 335i xDrive, '06 GTO, '02 Trans Am Firehawk, '99 Grand Prix GTP
      02-21-2019, 07:21 PM   #540
Henry1518
Drives: 981 Spyder, M2C
Have you tried fitting them? I didn't have much luck with the AutoTecknic carbon mirror caps. Terrible fitment near the hinge portion on both sides. Luckily I was able to get a refund (minus shipping cost ).
      02-21-2019, 07:28 PM   #541
epic
M Comp
epic's Avatar
The shop put one on before finding out they sent two of the same so I can't comment on that. Do you have a picture of what you're talking about? The shop sent me one but I'm sure it doesn't show what you're talking about:
View post on imgur.com
      02-21-2019, 07:51 PM   #542
Henry1518
To their credit they offered to replace them at no cost but I wasn't confident they would fit well so I just went with oem M-Performance. They did look okay from far away...
      02-21-2019, 07:53 PM   #543
epic
M Comp
epic's Avatar
OK yea, I see the gap thins out and widens. I don't' see that on mine from my pic (you can click to zoom way in). I wonder if there were different runs to fix that. Can't tell if my mind is playing tricks on me with my picture.
      02-21-2019, 07:56 PM   #544
Henry1518
Hopefully yours fit well, they are a good savings over oem.
      02-21-2019, 08:04 PM   #545
epic
M Comp
epic's Avatar
Appreciate you pointing this out so I can look for it when they get installed. Good looking out.
      02-22-2019, 09:24 AM   #546
Proctor750
Drives: E30 M3
1. The oil cooler is at the bottom of the engine and covered by a plastic skid guard. If you hit anything in the road you risk puncturing your oil cooler and losing oil pressure quite rapidly. This has already happened to forum members.
https://f87.bimmerpost.com/forums/sh....php?t=1566129
https://f87.bimmerpost.com/forums/sh....php?t=1579322
2. The charge air cooler (top of motor) has a tendency to leak coolant internally which spills into your intake and can hydrolock your engine. It has happened to several M3/M4 owners already.
https://f80.bimmerpost.com/forums/sh....php?t=1570544
3. The S55 (and many other engines these days) has a "friction" fit crank hub vs one with a keyway and woodruff key that holds it to the end of the crankshaft. This friction can be overcome with high rpm resonance either backing the crank bolt out, stretching it, or simply a failure of the friction disc between the hub and crank. This results in the crank and your cams getting out of timing with each other. (This is an interference engine i.e. valves will hit pistons if not timed correctly)
https://f87.bimmerpost.com/forums/sh....php?t=1492290
https://f80.bimmerpost.com/forums/sh...2#post24407562
4. The rear differential is mounted via 1 mount or "ear" which means all torsional forces are put against that one point which can act almost like a fulcrum or pivot point. Read stories of older performance BMW's of the past with single ear diffs...
https://f87.bimmerpost.com/forums/sh...8#post24275208
Hope that helps.
      02-22-2019, 02:16 PM   #547
nomoracin
Drives: Porsche GTS 4.0
What are those things called that helps protect from rock chips by the tires? ...and where do I get them from?
      02-22-2019, 02:50 PM   #548
quadrapete
Drives: BMW m135i
Dropped in at my Dad's garage and painted the cows udder
Pleased with the results!!
Appreciate 4
cptobvious2531.50
///M Houbi1655.00
DazC905.00
      03-02-2019, 09:43 AM   #549
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Betrayed her for 20 minutes.... not the same acceleration as my M2C, but oh my god that drama....
AlpsRider2865.00
cptobvious2531.50
VIERsr2623.00
      03-02-2019, 03:35 PM   #550
dmf
Drives: M2 Competition DCT/BSM
While not 'today'. had an interesting weekend last week at Thunderhill where somehow after a lap with new Pagid RS29 pads, my front right caliper lost one of its bolts and other sheered as I was exiting the pits into the paddock. It cut into the brake line and mangled the backing plate in the process.
One of my next upgrades was going to be the brakes anyway so I'll probably go with the Brembo BBK in red.
As an aside, if anyone needs a better indicator as to why one shouldn't bother with stock pads on racetracks, this is what 2 days at Buttonwillow and 1 day at Laguna did to my stock front pads (in amongst ~6k of regular road driving)
cptobvious2531.50
