08-02-2019, 10:46 PM | #1 |
BMW forever!
1389
Rep 2,418
My car only has 3K miles and driven conservatively. I checked all my tire pressures, never hit any pot hole or taken the car to track.
Suddenly out of now where there seems to be a little play in the on-center part of the wheel. This misleads and causes me to over turn the wheel when going on a curvy road since there is no heft for 3 degrees of left or right turn of the wheel. Basically feels loose in the center. When the wheel is turned more than 3 degrees either side, I can feel the heft as if the steering engages. Is this normal part of the M2C character? Or is something off? Did any of you feel the same? Is it related to the differential or do I need a software update? TSB? Only thing I noticed was that one of the tires was cooler comparatively. See attached picture.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
08-02-2019, 11:03 PM | #2 | |
Luxury at the redline :)
9105
Rep 7,563
It's totally normal; the EPS is "active" so when it's not required, it loosens up the slack and can feel sloppy but that's by design not a defect. . https://www.newtis.info/tisv2/a/en/f...ring4/EEpdEE0c |
08-03-2019, 02:17 AM | #3 |
Rep 7,297
I think you would have to drive another one to know the truth 100%. Subjective opinions on the steering vary greatly. It's *probably* normal, but hard to say.
08-03-2019, 05:12 PM | #4 |
Rep 3,842
There have been reports of steering racks going bad too. Does it knock when you go over little bumps at low speed especially when turning?
08-03-2019, 06:28 PM | #5 |
BMW forever!
1389
Rep 2,418
Thanks, I will pay more attention when I drive my car next time. Knock meaning like a vibration?
2020 BMW X5
08-04-2019, 08:07 AM | #6 |
Rep 828
Links to these reports?
///M
08-04-2019, 08:28 AM | #7 |
Rep 335
My M2C has 1,200 miles... there is no play or loose feeling in the steering, on center, or anywhere else.
If my M2C steering started doing what you describe, I’d take it in for service ASAP. My 2001 Subaru Wagon beater has play in the steering, but this is expected, as it has 212,000 miles. Last edited by natmad; 08-04-2019 at 10:46 AM.. Reason: Sppelliinngg |
Project_F871231.00 |
08-04-2019, 08:53 AM | #8 |
Rep 969
For years Subaru mounted their steering racks to the frame with clamps that had rubber bushings, and these would allow the rack to shift if you ever turned the steering hard to one side and hit the stop. It was bad enough to totally wipe out the precision of a front end alignment. I don't know if they still do this, but it was a real design flaw.
natmad667.00 |
08-04-2019, 09:29 AM | #9 |
Rep 1,237
Drives: M2 Competition
7200km so far and absolutely no play in steering, no matter what position
08-04-2019, 10:45 AM | #10 |
Rep 3,842
I read it in the M3/M4 forum. Some people were having a knocking sound from the front left side of the car over small bumps at low speed. Some found play in the steering rack others found slack in other suspension components. I read it awhile back so I don't have a link.
The bottom line is if you believe there is slack in the steering then the car should go in for a safety inspection to rule out anything obvious or dangerous. |
natmad667.00 |
08-04-2019, 01:30 PM | #11 |
Rep 828
^^ That sucks. I’ve had 3 vehicles back in the day, (I bought new) that did that. 2 vdubs and 1 Subaru that clunked during low speed turns. It got on my nerves so bad I sold 2 of them. I cannot describe how much I hated it. I cannot deal with this if it’s a problem with the M2. Good that it sounds very rare.
///M
08-05-2019, 08:25 PM | #13 |
BMW forever!
1389
Rep 2,418
I also feel some vibrations on normal smooth road. I think my wheels are out of balance or misaligned. There's also a slight pull to the left.
I did notice that one of the other wheel has a missing weight. Not sure how this might have happened.
2020 BMW X5
Poochie9104.50 |
08-05-2019, 08:26 PM | #14 |
BMW forever!
1389
Rep 2,418
Sport mode steering !
2020 BMW X5
08-06-2019, 08:29 AM | #16 | ||
Rep 46
Anyway i think I'll take her to my dealer for a check. |
08-06-2019, 09:17 AM | #17 | |||
BMW forever!
1389
Rep 2,418
I have a MY2019 and dealer performed a differential update on my 1,200 mile service. I think they might have updated something in that service which is triggering the loose steering. Did you go through the same type of service?
2020 BMW X5
08-06-2019, 09:27 AM | #18 | ||||||||
Rep 46
08-06-2019, 09:56 AM | #19 | |||||||||
BMW forever!
1389
Rep 2,418
2020 BMW X5
08-06-2019, 10:32 AM | #20 | |
Rep 4,551
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh...8#post25111178 Curious how the new blacklines look on the MY20 models and I have yet to see a good quality photo. |
NYC Bimmer259.50 |
08-06-2019, 10:45 AM | #21 | |
Rep 845
https://f87.bimmerpost.com/forums/sh....php?t=1628298
Instagram: @Project_F87
AndrewC198910931.00 |
08-06-2019, 10:55 AM | #22 |
Rep 3,842
Those photos have already been posted. I think it would be good to have a photo taken straight on in complete shade and one in complete sun with the cars at the same distance away.
