10-05-2018, 01:36 PM | #1 |
Rep 281
19" Winter wheels
Went for a test drive of the M2C and to my surprise found the demo car already equipped with the winter wheels. 19" rims look good in my opinion and should be easy to clean.
10-05-2018, 01:51 PM | #2 |
Rep 148
Drives: M3 G80
so that will be this in silver?
https://www.shopbmwusa.com/PRODUCT/6...EL----TIRE-SET |
Poochie9107.50 |
10-05-2018, 01:58 PM | #3 |
Rep 1,237
Drives: M2 Competition
Great, thanks for the pics! Will take delivery hopefully next week. The car will have mounted the 641M's so glad to have a preview
10-08-2018, 09:49 AM | #4 |
Rep 7
Drives: BMW M2C
8,5'' rims at the front, and 9'' rims at the rear? But same tire dimentions?
10-08-2018, 12:19 PM | #5 |
Rep 1,237
Yes
10-08-2018, 12:21 PM | #6 |
Rep 216
I don’t want to thread jack but will any 19 inch bmw wheel with a similar offset work? Someone near me is selling 550xi rims (style 332,19 inch) Will these fit on a M2c?
Bolt Pattern is the same. New tires are 245/40/19 all around. For the new wheels, I believe the offset is 33 and is a 8.5 inch wide wheel. When I run the calculator it doesn’t look like anything stands out as a huge size difference. Am I missing something or should these fit. Thanks in advance. |
10-08-2018, 09:36 PM | #7 | |
Rep 1,094
19x8.5 or 19x9 ET 20-30 are good fit |
10-08-2018, 09:40 PM | #8 |
Rep 3,318
I was close to pulling the trigger on the 641's for winter until I foolishly looked up how much they weigh. 29 and 30 pounds. Back to not being able to make a decision.
10-08-2018, 10:18 PM | #9 |
Rep 7,332
It's not cheap but you can run 4x front 437M and 245s all around. The front 437M is almost identical in poke because of the width difference and offset difference, it only sits 2mm inside of where the normal rear would be.
10-08-2018, 11:41 PM | #10 |
4143
Rep 6,926
10-21-2018, 09:29 AM | #12 |
Rep 1,237
Just found out the weight of the 641M, cast alloy.
24.5kg per wheel....
10-21-2018, 10:02 AM | #13 | |
Rep 3,318
You can look them up on http://felgenkatalog.auto-treff.com/ along with most other BMW's wheels (no 788's on there yet) |
///M Houbi1655.00 |
10-21-2018, 10:08 AM | #14 |
Rep 1,477
235 on rear with 9" rim?
10-21-2018, 10:16 AM | #15 | ||
Rep 1,237
10-21-2018, 10:47 AM | #16 | ||
4143
Rep 6,926
10-21-2018, 11:01 AM | #17 | |
Rep 281
///M Houbi1655.00 |
10-21-2018, 11:07 AM | #18 |
Rep 3,318
10-21-2018, 12:23 PM | #19 | |
Rep 658
My plan is to be with 763s for winter as well. I can see lots of advantages for this option: 1) 763s will be lighter than the set of 19s, which are proposed by BMW as a winter set. having lighter wheels means significantly better comfort going ober the bumps, which are unavoidable during winter time 2) the design of the 763s seems to be the best that the snow is not getting stuck in rims, causing vibrations etc 3) 245 & 265 or 245 & 255 will not provide seriously worse traction at snow in comparison to the recommended 245 all-around Last edited by kart driver; 10-21-2018 at 02:58 PM.. |
10-21-2018, 12:32 PM | #20 |
Rep 1,477
Bmw recommends 235 all-round for winter tires with both 640 (18") or 641 (19") rims
But I don't understand how you can fit a 235 tyre on a 9" rim. |
10-21-2018, 03:02 PM | #21 |
Rep 281
Door sticker shows also 255/35 for the 18" rear winter. Suspect that both 235/40 and 255/35R18 could support chains while anything larger than 235 on the 19" would not.
10-21-2018, 03:05 PM | #22 | |
Rep 658
Why putting 235? 245 front + 255 or 265 rear are fine. I had m3e92 in the past and instead of buying a set of recommened set of winter rims with 235 I went for 245 + 255 on a summer set of rims with no issues. If you own a car like M2, you are definitely an enthusiast and thus know how to drive a rear driven car in snow conditions. |
