04-05-2019, 12:48 PM | #661 |
Rep 277
Drives: '23 M340i, '16 X3
You know, my ignorance is showing... I went down the list of coding I did on my E90 335i, and the fog lights was one thing I had done previously. When it showed up in the list on BimmerCode, I just selected it. I don't have fog lights on the M2
Current - 23 G20 M340i, 16 F25 X3 2.8i xdrive
Gone - 19 F87 M2C, 11 E90 335i, 08 E70 X5 3.0i, 04 E46 330i, 95 E36 M3 |
04-05-2019, 01:09 PM | #662 | |||
Rep 929
04-05-2019, 06:12 PM | #663 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
04-05-2019, 06:17 PM | #664 | ||
Rep 277
04-05-2019, 09:08 PM | #665 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Gotcha. Good to know.
04-06-2019, 02:23 AM | #666 | |
Rep 8,970
Then you can flush out the whole thing, on the bench, clean the baffles etc. Using a strong deagreaser. Just watch the bottom edge / sharp corner of the can presses against a water hose. I make sure the can is mounted rearwards as far as possible and stuck padded foam on the bottom of the can to prevent chaffing on the water hose... Last edited by doughboy; 04-06-2019 at 02:28 AM.. |
KevM2723.50 |
04-06-2019, 01:23 PM | #667 | ||
Rep 929
Also, is there any room at the bottom of the catch can once mounted where a drain plug could be installed? |
04-06-2019, 03:09 PM | #668 |
Rep 3,842
Actually the tailights have fog lights which are coded out on US models.
04-06-2019, 03:26 PM | #669 | |
Everyday I'm shuffling
449
Rep 1,098
Which OBDII dongle did you use, if I may ask? A link to Amazon would be great. |
04-06-2019, 03:56 PM | #670 |
Rep 1,237
Drives: M2 Competition
https://www.amazon.com/s?k=obd%C3%B6ink+mx%2B&ref=is_s
https://www.amazon.com/Veepeak-OBDCh...way&sr=8-3
04-06-2019, 03:59 PM | #671 |
Rep 3,842
This is the one that I bought. It's Bluetooth not WiFi. It has never lost connection.
https://www.amazon.com/dp/B00H9S71LW...p_mob_ap_share Last edited by AlpsRider; 04-07-2019 at 12:30 AM.. |
04-06-2019, 04:31 PM | #672 | |
Rep 277
04-06-2019, 04:34 PM | #673 |
Rep 277
Just finished installing the ASD bypass harness. Thanks to all those who left excellent instructions and pictures in this thread:
https://f87.bimmerpost.com/forums/sh...&postcount=319 The hardest part was freeing the inner panel from the trunk lip trim. I didn't want to break it, and just couldn't figure out how to free it after taking off the four pop rivets. I was able to muscle the liner out and from there it was a cakewalk.
04-06-2019, 04:48 PM | #674 |
Rep 6,635
04-06-2019, 04:51 PM | #675 | |
Rep 6,635
04-06-2019, 04:51 PM | #676 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Does it make you use the bundled software or could you just use apps like Torque and BimmerCode?
04-06-2019, 04:56 PM | #677 |
Rep 277
I used BimmerCode and BimmerLink successfuly, so it's generic.
04-08-2019, 07:46 AM | #679 | |
449
Rep 1,098
Are you speaking of the one the come on when I go in reverse gear? |
04-08-2019, 09:58 AM | #680 | |
Rep 1,015
Drives: Porsche GTS 4.0
04-08-2019, 10:09 AM | #681 | ||
Rep 277
https://www.bimmerpost.com/forums/sh...php?p=24616782
04-08-2019, 10:28 AM | #682 | |
Rep 3,842
The fog lights can also be coded to come on when activating comfort lighting. I have all of my lights come on when I unlock the car at night except the headlights. Last edited by AlpsRider; 04-08-2019 at 10:35 AM.. |
