12-14-2018, 11:27 AM | #45 | ||
Rep 1,014
Drives: Porsche GTS 4.0
12-15-2018, 01:39 AM | #46 |
Rep 479
Drives: CB E46 and SG E92 M3s
For u guys going stg2 w/dp I recommend
Sport+, Sport+, no MDM, LVL I DCT in auto. Otherwise it's shots fired. LVL II or above is like auto gun fire. Will surely give a few of us out there PTSD. |
12-15-2018, 09:28 AM | #47 |
Luxury at the redline :)
9105
Rep 7,563
"What mode you drive in"
"What's your mileage" "How many figurative inches does an M2C adds to your penis" I see we're running out of interesting subjects to delve into here.. Back to Pornhub.. |
12-15-2018, 11:55 AM | #48 |
Rep 3,843
M2 button: Sport+, Comfort, MDM. The M2 button is the closest to my thumb. Comfort steering transmits more feeling of the road in IMHO. I think the way that the throttle is mapped in Sport+ is smoother for manual shifting, especially 1st to 2nd gear. The exhaust is most aggressive in Sport+.
M1 button: Comfort, Efficient for less drone on a long freeway trip. If I'm going to do DSC off then I just do it manually. I have a 6MT so sport modes don't affect shifting. I have no problem using Sport+ when the car is cold since I'm in control of shifting rpm. I guess that someone with a DCT would need to consider shifting behavior. |
///M Houbi1655.00 |
12-15-2018, 12:57 PM | #49 |
Rep 2,808
I too have a 6MT. I'm curious, is there an actual chart or info on how the valves work in Efficient, Sport and Sport+?
Sport+ does seem a little bit louder than Sport, but I don't know if that's the ASD tricking me. And a bit more burbles maybe. But I'd like to see if there's actually info on it. I thought for example before that Sport+ left the valves open all the time, but I've read posts saying while it leaves the valves open the most, they are still not open all the time. So with a tune, leaving valves open all the time, presumably one would get a slightly louder exhaust sound compared to Sport+ even? |
12-15-2018, 01:09 PM | #50 | |
Rep 3,843
12-15-2018, 01:20 PM | #51 | |
Rep 1,237
Drives: M2 Competition
plus In efficiency mode your warmed up quicker
AlpsRider2865.00 bubsterino171.00 |
12-15-2018, 07:10 PM | #52 |
Rep 3,843
01-17-2020, 11:00 AM | #54 |
Rep 843
When setting off out of the garage, I leave it on normal.
M1 Mode: When just driving around the neighborhood after the engine is warmed up, I hit M1 (Comfort EVERYTHING). M2 Mode: When I get to some nice open roads, then it's all M2 (Sport+ EVERYTHING) time! |
01-17-2020, 11:18 AM | #55 |
Rep 4,048
My settings:
After startup until warm: Efficient, Sport Steering, D2 trans M1 (once she is warm): Sport, Sport, D2 trans. This is for cruising around town M2 (when the need arises): Sport +, Sport, D3/S3 trans. |
01-17-2020, 11:36 AM | #56 |
Rep 3,843
Custom programmed DME setup.
On startup I use the default which in my "MT" M2C is Efficient engine mode and Sport chassis mode (steering for MT). If I want it to sound like a beast on startup I click the M1 button which is programmed to MDM/Sport/Sport before starting the car. I have programmed the car to open the exhaust valves permanently in Sport and Sport+ engine modes. I've programmed engine Sport mode for mild mean but tasteful burbles, it's for all but the stealthiest situations. Sport+ is for car meets :-), it's programmed for all out burble mania. Normal good weather driving: MDM/Sport (mild burbles)/Sport Normal good weather driving stealth: MDM/Efficient (quiet as a mouse)/Sport Wet, cold or gravel: Sport/Sport, no MDM Long boring freeway drive: Efficient/Sport, no MDM because of Cruise Control limitation Car meet, show off mode: MDM/Sport+/Sport |
01-17-2020, 01:11 PM | #57 |
Rep 468
Sport for steering & throttle.
Traction almost always set to MDM. Thought I'd like the popular Sport+ throttle with comfort steering combo, but Sport throttle is juicy enough with a bit more control, although Sport+ seems to slow the car better off-throttle. Comfort steering feels completely wrong to me for the weight distribution of the car, and it doesn't return to center the way I like. Sport+ steering is too heavy despite the good off-center feel. I also came from an M240ix. That one I liked most in DSC OFF mode for aggressive driving, which I think was standard throttle, sport+ exhaust & faster shifts with the ZF. On the highway I liked Sport with the gearbox in D. |
01-17-2020, 01:26 PM | #58 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Depeche
8
Tag18165.50 cptobvious2531.50 Threeebowel31.50 KevinM2935.50 Davil6527.50 bri10425943.00 HFW0035701.50 bubsterino171.00 |
01-17-2020, 02:14 PM | #60 | |
this is the way
18166
Rep 8,530
Some of the map features provided: - Map Customization through Map Editor - Top speed limiter removal - Higher rev limiter - Exhaust burble (GTS, custom, aggressive mode), switchable with the steering wheel controls in efficient vs. sport mode - GTS Startup Roar - GTS DCT Transmission flash - Re-calibrated Sport Gauges on iDrive - Cold start cat heat cycle and cat efficiency check removed (for off-road use) - Maps for upgraded turbos - E85/blend, race gas and meth injection tuning - Custom Throttle mapping |
01-17-2020, 07:40 PM | #61 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
I usually leave it in the default mode until the oil temp is good (e.g., efficient/sport) and then hit the M2 button, which I have set up for sport+/sport+, MDM mode). I set M1 to sport/sport, which I sometimes use while the car is warming up; as far as I can tell, the oil seems to reach temperature at the same time in both efficient and sport engine modes (vs. with the extra cooling provided in sport+).
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
01-18-2020, 12:31 PM | #63 |
Rep 8,627
M1 -
Steering Comfort Tranny 2 Shift Speed and Automatic Throttle Sport MDM traction M2 - Steering Comfort Tranny 3 Shift Speed and Manual Throttle Sport Plus MDM Traction A few things I've learned... there is almost exclusively 0 value to having steering in anything other than comfort unless you just want artificially heavy steering, it does nothing for feel or response. Another thing I found bizarre is that the car on startup is in efficient mode throttle and sport steering (beyond me why it wouldn't be comfort by default). For daily driving, I use my M1 mode, for Fun driving M2... |
Moflow2484.50 |
01-19-2020, 02:50 PM | #64 | |
Rep 181
Cant force the flap in open position. You can open it and disconnect it. |
01-19-2020, 02:59 PM | #65 | |
Rep 4,048
What I do like is that start/stop is default off in the M2. That's a first I've seen |
ASAP10164.00 |
01-19-2020, 05:22 PM | #66 | |
Rep 1,602
I wish the steering worked the same way. After getting used to Sport, I switched to comfort and have decided I like it significantly more. I can't foresee a time when i'd ever want to use sport or sport + steering in the future, i think it would honestly mess with me in hard driving to suddenly have different steering effort. That means i have to burn one M button (M1) for just my standard driving mode (Comfort steering, eco throttle, full stability.) That leaves one button for fun mode (Comfort steering, sport + throttle, MDM.) If the steering defaulted back to comfort instead of sport every time i turned the car on or off or used an M button, i'd have one button set to "half fun" and one set to "full fun" with no TCS whatsoever so I could do my own rev matches. |
Capt Canuck704.00 |
