12-18-2018, 02:09 PM | #49 | |
Rep 1,237
Drives: M2 Competition
Appreciate
12-23-2018, 03:32 PM | #50 |
Rep 37
Posts |
Thanks to ///M Houbie and OKCZ
I've set SPA_IST_GANG_ENABLE to aktiv and no more shift gear indicator only current gear (DCT gearbox). SPA_CHECKBOX doesn't work (no check box in iDrive display), it seeems to be quite logical for DCT. Thanks again, I can now drive without this virtual ecologist non-stop saying to upshift to save the earth ! |
Appreciate
12-23-2018, 04:56 PM | #51 | |
Rep 1,237
Set SPA_IST_GANG_ENABLE back to "nicht aktiv" (this is important). Set SPA_CHECKBOX to "aktiv" in Headunit and SPA_KOMBISELECT_DISABLE to "nicht aktiv" in Kombi. Then you should be able to control it via iDrive. At least it works this way in my car (6MT).
Appreciate
Kattanah139.00 |
03-07-2019, 10:41 PM | #52 | |
Rep 96
Posts |
Currently Driving:
Porsche GT4 '20 BMW M2C '19 Caterham S3 '01 Porsche 993 '96 |
Appreciate
03-08-2019, 12:31 AM | #53 |
Rep 8,972
Posts |
If it's DTC there is no shift indicator? Or does one appear if you select manual mode?
I think you can only do this in Esys? Correct me if I'm wrong? M Houbi and I used Esys... Edit: just checked and bimmercode has now unscrambled the Kombi ECU so you can do this mod with bimmercode! Last edited by doughboy; 03-08-2019 at 03:01 AM.. |
Appreciate
03-08-2019, 12:32 AM | #54 |
Rep 1,237
Meanwhile the M2C's kombi ecu is possible to code with Bimmercode.
But with DCT i don't think you can disable it, there is no shift point indicator as doughboy stated.
Appreciate
03-08-2019, 05:26 AM | #56 | |
Rep 37
Posts |
No way to disable.with iDrive. Had to disable it with ESys. See my post above. |
Appreciate
03-08-2019, 09:34 AM | #57 |
Rep 8,972
Posts |
Appreciate
03-09-2019, 12:16 AM | #58 |
587
Rep 897
Posts |
Just picked up a 2019 M2 Competition 11/28 build date. Already had the M menu in the iDrive. I am a 6MT however.. Really wish there was a current gear indicator for 6MT guys though
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
Appreciate
03-09-2019, 02:06 AM | #59 |
Rep 8,972
Posts |
I think US cars have the shift indicator disable check box available. Just EU cars don't.
All manual cars have a current gear indicator - the gearstick! Don't even need to take eyes of the road. Put your hand on the shifter and you know exactly what gear you're in... |
Appreciate
bubsterino171.00 |
04-07-2019, 08:05 AM | #60 | |
Rep 96
Posts |
Spa_ist_gang_enable was already not active and gear indicator was still showing. Tried this and it worked but no idrive toggle showed up. Thanks all! |
Appreciate
09-09-2019, 05:54 PM | #62 | |
Banned
757
Rep 2,149
Posts |
Appreciate
09-09-2019, 08:03 PM | #63 | |
Rep 8,972
Posts |
Sport plus and comfort are engine mode and steering setting. They are shown here when you turn off the pointless / stupid efficiency gauge in I drive settings. |
Appreciate
09-09-2019, 08:50 PM | #64 | |
Banned
757
Rep 2,149
Posts |
And I didn't know that about the other thing. I thought it was blank if you turned off efficient dynamics. I kept mine on because I liked the colors. Unless what's in his picture is another thing specific to M2C. I'll have to try disabling it tomorrow. |
Appreciate
02-15-2020, 12:01 AM | #65 |
Rep 194
Posts |
Appreciate
Post Reply |
Bookmarks |
