BMW M2 Forum > BMW M2 Competition Model > My new Stance
      12-12-2018, 11:26 AM   #1
kyoshi
Drives: BMW M2 Competition
My new Stance
Slight drop with Eibach springs and 15mm spacers..
      12-12-2018, 11:35 AM   #2
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
better pics needed lol
please give an update on the handling after a couple weeks.
      12-12-2018, 12:11 PM   #3
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
Is this 15mm all around?
      12-12-2018, 12:30 PM   #4
Project_F87
Project_F87's Avatar
Drives: 2020 M2C LBB 6MT
Attachment 1953308
looks good, but why a zoomed-in/cropped image?? let's see some high-def!
      12-12-2018, 01:18 PM   #5
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
I'm sure it looks good, can't really tell from the photo..
Some friendly advice though; using just lowering springs is a bad idea. It will wear out the OEM shocks because the dampers will have to compress much more to absorb bumps. It's logical; the spring is shorter and therefore the shock. The shocks/struts & springs need to be matched for a particular application.
Trying to make a shock handle a spring that it was not designed for (i.e. height, rate, etc.) does not yield good comfort and/or handling results. Especially if the shocks are the factory std. versions, which are borderline quality at best.
If lowering was your goal, coilovers are the better option, since the spring is mated to the proper shocks.
HS_M2C118.50
JeremyDFW458.00
