10-17-2018, 12:19 PM | #1 |
Rep 1,237
Drives: M2 Competition
Hey guys and gals...
I took delivery of my M2C last friday. I had it delivered with 641M (winter) wheels and Michelin Pilot Alpin 4 tyres in 235-35-19 all around. I asked the dealer if they set the pressure right, and naive as I am i believed it when he said yes of course we did. Tyres where set at 2.8 bar (stone cold). So they where around 3 bar warmed up... Once i drove a bit i had a pretty weird feeling of the car. It felt a bit like on eggs, not so precise, not much grip. I blamed it on brand new winter tyres and 235 beeing rather small width for so much power. After around 200km upside down on swiss mountains i decided to check out the highway just for very short distance. I was able to accelerate to roughly 70mph, but from that point it was not possible to accelerate any further. No matter if 4th, 5th or 6th gear, there was just no acceleration at all. Soon i realised that DSC is blinking like hell everytime i just looked at gas pedal..... Went off the highway and took a look at the tyre pressure chart myself. Aha! Cold they should be set at 2.5 bar and not 2.8 as my dealer did. So i removed 0.3 bar from each tyre, beeing alone in the car without any luggage. Since then car has significantly more grip, feels more precise, dsc does not blink anymore (at all), and i can accelerate as i am expecting to be able to. There where a few scary moments that first day, so check this yourself before you get it on the streets! As often in live it seems you have to do everything yourself if you want it to work out
10-17-2018, 02:59 PM | #2 | |
Rep 281
I had the opportunity to test a demo car with the same winter set-up. No idea what the tire pressure was but I also found that the tires struggled with the power/torque of the car when pushing it a little bit. Granted temperature was close to 20 C and tires quite new but it was definitley more challenging than on my " low torque" M3 featuring 225 square winter. By the way can please check in the manual owner whether chains are authorized with 235/35R19 rear. I believe it is to maintain the possibility to put chains that they had to reduce width of the 19 rear winter tires(18 are 255) |
10-17-2018, 03:34 PM | #3 |
Rep 3,325
My summer tires were over-filled and not consistently when I got my car. When I leave the dealership on Saturday following the break-in service, I plan on checking the pressure in the parking lot before I leave.
10-17-2018, 03:54 PM | #5 |
Rep 3,844
Good idea, every time that I take my car in for service I tell them NOT to touch the custom tire pressure that I'm running on the car. Every time the car comes back with the pressure different on all four tires.
10-17-2018, 04:05 PM | #6 |
Rep 1,237
Of course i forgot to mention that in my case also all tyres did not have same pressure. They day after i took care they where all exactly at the same and correct pressure...
All this is somewhat disappointing. Combine some bad luck and silly circumstances and something like this could even have a bad end....
10-17-2018, 08:33 PM | #7 |
Food Critic
1086
Rep 1,015
I'm not sure the conversion to bar but when I took delivery my tires were at max tire pressure, 50psi. The car felt terrible, I drive for about ~40km before I had to get gas and when I got gas I checked and realized it was 50, and brought it back down to 35. It was so, so much different afterwards! Mental note to always check from now on!
10-17-2018, 11:32 PM | #8 | |
Rep 1,237
So this seems to happen more often than i thought. Very dangerous
10-18-2018, 12:30 AM | #9 |
Food Critic
1086
Rep 1,015
Very dangerous indeed, max tire pressures really mess up the amount of grip you have.
10-18-2018, 02:21 AM | #10 |
Rep 7,341
Ah, yes, nothing like the competence of the average car dealership. Cannot even get a step right they should be performing on every single car they receive.
10-18-2018, 03:11 AM | #11 |
Όλα ρόδες
760
Rep 561
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Ok, you got your car already with 2NH? Good for you!
10-18-2018, 03:56 AM | #12 |
Rep 1,237
Indeed, for quite a while it looked like it won't work out... (despite having ordered the thing on first of june...)
Currently rumors around that 2NH will never ever be available again for the german market.
