M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Really no way to disable shift/gear indicator?
      12-17-2018, 02:02 PM   #45
///Magic Bus
///Magic Bus's Avatar
38
Drives: M3C G80 XDrive
Thanks a lot ! Vielen dank ! Merci beaucoup !
Have DCT. I'll test that
Tschüss
      12-17-2018, 02:47 PM   #46
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
My last DCT (M6) showed current gear already in manual and auto modes.
Does M2 DCT not do that?
      12-18-2018, 01:16 PM   #47
///Magic Bus
38
Current gear is displayed but I want to disable the stupid shift indicator
      12-18-2018, 01:50 PM   #48
doughboy
doughboy's Avatar
1545
But SPA_IST_GANG_ENABLE is for enabling the display of current gear not the shift indicator??
      12-18-2018, 02:09 PM   #49
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
Do these steps then: https://www.bimmerpost.com/forums/sh...php?p=24006253
      12-23-2018, 03:32 PM   #50
///Magic Bus
38
Thanks to ///M Houbie and OKCZ
I've set SPA_IST_GANG_ENABLE to aktiv and no more shift gear indicator only current gear (DCT gearbox).
SPA_CHECKBOX doesn't work (no check box in iDrive display), it seeems to be quite logical for DCT.
Thanks again, I can now drive without this virtual ecologist non-stop saying to upshift to save the earth !
      12-23-2018, 04:56 PM   #51
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Try it this way:
Set SPA_IST_GANG_ENABLE back to "nicht aktiv" (this is important). Set SPA_CHECKBOX to "aktiv" in Headunit and
SPA_KOMBISELECT_DISABLE to "nicht aktiv" in Kombi.
Then you should be able to control it via iDrive. At least it works this way in my car (6MT).
Kattanah137.50
      03-07-2019, 10:41 PM   #52
kvnchu
Drives: z4m
Originally Posted by ///M Houbi View Post
Now it's working! thanks to the help of OKCZ with descrambling the KOMBI FDL's I can now switch the shift point gear indicator on and off
It's much cleaner and less distracting without that useless thing!
For those facing a similar issue, 3003_0_0_32 is SPA_KOMBISELECT_DISABLE which must be set to "nicht_aktiv" in addition to SPA_CHECKBOX which has to be "aktiv". SPA_IST_GANG_ENABLE (show current gear) does not work.
Trying in Bimmercode. Is this the process for DCT m2c as well as manual? Thank you
Currently Driving:
Porsche GT4 '20
BMW M2C '19
Caterham S3 '01
Porsche 993 '96
      03-08-2019, 12:31 AM   #53
doughboy
doughboy's Avatar
1545
If it's DTC there is no shift indicator? Or does one appear if you select manual mode?
I think you can only do this in Esys? Correct me if I'm wrong?
M Houbi and I used Esys...
Edit: just checked and bimmercode has now unscrambled the Kombi ECU so you can do this mod with bimmercode!
      03-08-2019, 12:32 AM   #54
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Meanwhile the M2C's kombi ecu is possible to code with Bimmercode.
But with DCT i don't think you can disable it, there is no shift point indicator as doughboy stated.
      03-08-2019, 03:02 AM   #55
doughboy
doughboy's Avatar
1545
Beat me to it! I haven't used BC for a while.
Glad to see we can code M2C Kombi with it now
      03-08-2019, 05:26 AM   #56
///Magic Bus
38
I had shift point indicator as standard delivery parameters (DCT gearbox) .
No way to disable.with iDrive.
Had to disable it with ESys. See my post above.
      03-08-2019, 09:34 AM   #57
doughboy
doughboy's Avatar
1545
Yep, but now you can do it with bimmercode as they've unscrambled the Kombi ECU settings now.
      03-09-2019, 12:16 AM   #58
cookiesowns
cookiesowns's Avatar
587
Just picked up a 2019 M2 Competition 11/28 build date. Already had the M menu in the iDrive. I am a 6MT however.. Really wish there was a current gear indicator for 6MT guys though
      03-09-2019, 02:06 AM   #59
doughboy
doughboy's Avatar
1545
I think US cars have the shift indicator disable check box available. Just EU cars don't.
All manual cars have a current gear indicator - the gearstick!
Don't even need to take eyes of the road. Put your hand on the shifter and you know exactly what gear you're in...
      04-07-2019, 08:05 AM   #60
kvnchu
Drives: z4m
Try it this way:
Thanks! Finally got around to doing it.
Spa_ist_gang_enable was already not active and gear indicator was still showing. Tried this and it worked but no idrive toggle showed up.
Thanks all!
      04-07-2019, 08:34 AM   #61
doughboy
doughboy's Avatar
1545
US cars should already have the disable option available from the factory as far as I know?
Have you checked these in HU and Kombi?
      09-09-2019, 05:54 PM   #62
Anthony1s
756
Drives: 2018 Mineral Grey M2
How did you get it to say M2 in the tach instead of M? And what are the "sport plus" and "comfort" indications for, where the effecient dynamics gauge used to be?
      09-09-2019, 08:03 PM   #63
doughboy
doughboy's Avatar
1545
M2/// is printed on the tacho fascia it's not a display. I though they all had that? (M2c)
Sport plus and comfort are engine mode and steering setting. They are shown here when you turn off the pointless / stupid efficiency gauge in I drive settings.
      09-09-2019, 08:50 PM   #64
Anthony1s
756
Ahh, the dash was updated for the M2C then.
And I didn't know that about the other thing. I thought it was blank if you turned off efficient dynamics. I kept mine on because I liked the colors. Unless what's in his picture is another thing specific to M2C. I'll have to try disabling it tomorrow.
      02-15-2020, 12:01 AM   #65
sharpmoney
Drives: NA
where is this disable option? i want im 6MT and this is super annoying.
      02-15-2020, 01:33 AM   #66
doughboy
doughboy's Avatar
1545
In the I drive menus
