M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Really no way to disable shift/gear indicator?
      10-23-2018, 12:07 PM   #1
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
This actually drives me completely nuts. Car tells me all day long to shift into XY gear....
Is this the most useless "feature" ever??
I know what gear I am in and I also know what gear i want to drive in next.
I searched through idrive settings for hours, i cannot find a way to disable that shit. Also i found no other way using bimmercode or similar..
If it at least would show the gear I currently am in? (That would be a bit less useless at least)
Any ideas would be VERY welcome!
P.S. i know it's super easy in MY16 iDrive. But for MY17/MY18 this seems no more possible?
      10-26-2018, 02:34 PM   #2
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
You can definitely disable the shift indicator entirely. My car is in for service, but if nobody else gives you the procedure I will find out for you when I have it back.
Unfortunately, on a 6MT there is no way to just make it display the current gear (which is what I want it to do, for the rare occasion I have a brain fart and forget what gear I'm in).
      10-26-2018, 02:38 PM   #3
Uncledanny6
Drives: 2018 M2 LCI
2018 BMW M2  [0.00]
2018 BMW M2  [0.00]
If you don't believe him , try a single day 700 mile drive . You'll forget a few times
ZPrime611.50
smknjoe234.00
      10-26-2018, 02:44 PM   #4
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Yeah, I only forget on long trips or if I'm preoccupied thinking about other stuff. E.g. I merge onto the highway in 3rd, shift up to 4th because I still want some power to get around other traffic, and then it takes me a while to get through that and I momentarily forget if I put it in 6th or not.
The car certainly knows what gear it is in - there are magnetic / hall-effect sensors in there somewhere to help enable the auto rev-matching. Even without those, the computers can do the math based on wheel speed sensors + engine RPM and determine the gear from that (my 2012 Audi TTRS did this, and it would always display your current gear in the cluster, along with the "suggested" gear for best fuel economy if you weren't already in it).
      10-26-2018, 03:07 PM   #5
///M Houbi
///M Houbi's Avatar
Switzerland
1655
That would be great, thank you!
      10-26-2018, 03:33 PM   #6
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Here ya go
///M Houbi1655.00
ZPrime611.50
      10-26-2018, 03:50 PM   #7
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Originally Posted by laszlof View Post
Thanks. But there is noch such setting for the shift point indicator there on a M2C (but all others are present and configured to my liking).
      10-26-2018, 04:04 PM   #8
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Ah, sorry,. I missed the m2c part. Figured it would the same. Odd that it's not.
EDIT: The video is from my LCI 18
      10-26-2018, 04:29 PM   #9
///M Houbi
///M Houbi's Avatar
Switzerland
1655
It‘s exactly the same menu points just the indicator one is missing.
      10-26-2018, 04:34 PM   #10
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Did you go to customize menu? It might be hidden. Not sure if it's an option on that screen. Will check in a bit.
      10-27-2018, 10:25 AM   #11
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Just spent another 15 minutes in the car. I can look and search in iDrive where I want, its not possible.
When bimmercode supports the KOMBI control unit i‘ll have a look at the available settings in expert mode...
      11-01-2018, 02:46 PM   #12
OKCZ
Drives: BMW M2 2017 MT; MINI GP2 2013
Hi,
just change:
SPA_CHECKBOX to active in HU
SPA_KOMBISELECT_DISABLE to nicht active in KOMBI
This will enable new option in iDrive to disable gear shift indicator.
Cheers
      11-01-2018, 03:05 PM   #13
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Originally Posted by OKCZ View Post
Hi,
just change:
Cheers
Thanks a thousand times! will try as soon Bimmercode supports the KOMBI of M2C
      11-01-2018, 05:21 PM   #14
///M Houbi
///M Houbi's Avatar
Switzerland
1655
@OKCZ, this is definitely going into the right direction! i do have the menu point now.
My quest for a token starts earlier then expected.... can't code the second option with bimmercode (yet)
      11-01-2018, 10:33 PM   #15
PAC
PAC's Avatar
Is there a way to code it to show just the current gear?
      11-02-2018, 04:30 AM   #16
///M Houbi
///M Houbi's Avatar
Switzerland
1655
SPA_IST_GANG_ENABLE is for that. But cannot test it at the moment.
pz6193278.50
PAC63.00
      11-16-2018, 03:57 PM   #17
///M Houbi
///M Houbi's Avatar
Switzerland
1655
I've made my esys ready and got latest data and fdl xml files from just a few days ago.
All ecu's look fine except the KOMBI which I need is scrambled....
Any ideas?
      11-17-2018, 10:11 AM   #18
hassr
Any ideas?
Are you running the latest version of launcher pro with a recent copy of PSdZData Lite? I had a similar problem on my M2 LCI after I upgraded to the latest ISTEP. The kombi module became readable after I upgraded launcher pro to the late September build.
      11-17-2018, 10:20 AM   #19
///M Houbi
///M Houbi's Avatar
Switzerland
1655
I ordered my Pro Token this morning, hopefully I don't have to wait three months for it...
      11-18-2018, 09:16 AM   #20
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Now it's working! thanks to the help of OKCZ with descrambling the KOMBI FDL's I can now switch the shift point gear indicator on and off
It's much cleaner and less distracting without that useless thing!
For those facing a similar issue, 3003_0_0_32 is SPA_KOMBISELECT_DISABLE which must be set to "nicht_aktiv" in addition to SPA_CHECKBOX which has to be "aktiv". SPA_IST_GANG_ENABLE (show current gear) does not work.
Appreciate 4
OKCZ11.00
Kankles1484.50
      11-18-2018, 09:22 AM   #21
OKCZ
Great to hear it worked for you
///M Houbi1655.00
Kdevil1.50
      11-18-2018, 09:31 AM   #22
///M Houbi
///M Houbi's Avatar
Switzerland
1655
once more, THANK YOU very much
