08-20-2018, 08:05 PM | #1 |
Rep 80
Lithium battery for M2c?
When I was browsing the F90 M5 catalogue, I come cross this. If you have collected your M2C, can you confirm if the car came with Lithium battery as the M5 does?
I find the information useful, one of the page mentioned the 24V EPS in the previous model, the large capacity battery can eliminate the need of DCDC, a 2nd battery and therefore 90lbs weight saving sounds like a no brainer, I will be angry with BMW if they don't come std in all M models. Thx.
M2C - HS Manual
08-21-2018, 06:51 AM | #2 |
Rep 3,337
The M2C does not come with an Li battery like the M3/M4 do; if it had it would drop about 30lbs of weight. It would also result in a $1500 battery at replacement time. It's not a direct swap as that link shows; plus I'm guessing the charging system would provide the wrong input cycle and voltage for an Li battery.
Current Stable:
doug_9992542.50 |
08-21-2018, 10:43 AM | #3 | |
Rep 80
M2C - HS Manual
08-21-2018, 12:27 PM | #4 |
Rep 1,237
Drives: M2 Competition
Removing a lot of weight from the rear part of the M2C might not be the smartest move.
I'd rather start in the front.... bonnet would be very nice and help more towards 50/50 balance. Pricing is a stopper for sure...
AlpsRider2865.00 mikeahso411.50 Killed by Death12462.50 ki__409.00 bunnyhive55.50 Robin_NL8717.00 potato13373.00 |
12-29-2019, 09:54 PM | #5 |
Rep 72
Reviving this thread. Has anyone installed a Lithium Ion battery (LiteBlox or similar) on an M2C that retained all stock functionality, while achieving significant weight savings?
I know of few easier weight savings opportunities. |
12-30-2019, 09:06 AM | #6 |
Rep 1,263
I'm installing one of these in the next 3 months.
https://antigravitybatteries.com/pro...tive/ag-h7-rs/ I've run them in 2 other cars with no issues. In those two Japanese cars I had 5 lb batteries and they still started the cars even in the dead of winter. Their BMW recommended battery is a "drop in" replacement. Saves 40lbs....
12-30-2019, 09:26 AM | #7 | |
Rep 1,263
A Anti Gravity Lithium drop in battery and the rear seat delete kit I just ordered.. About 100lbs saved...
12-30-2019, 10:11 AM | #8 |
Rep 72
Thanks. That’s exactly what I was looking for. I’ve got 2 vehicles (car and Moto) with Antigravity batteries in them already, but hadn’t yet seen this.
For weight savings, I’m planning the battery, exhaust and wheels (763M already installed). That should be ~100lbs. I have kids, so no rear seat delete for me. After that, it gets pretty expensive (Carbon Hood-Trunk-Roof, AP Brakes, Seats). Last edited by Bill in Marin; 12-30-2019 at 10:16 AM.. |
12-30-2019, 10:55 AM | #9 |
756
Rep 2,149
That's why you have to work your way backwards. Start with the $32,000 Brembo Carbon brakes to shave ~50lbs. Then the $5400 carbon fenders to lose 7lbs. Then the more you buy, the more sense it will make to be buying it. And the better you'll feel about it. You'll be feeling FANTASTIC once you remove the rear seat for FREE and lose ~60lbs. lol
4
01-24-2020, 09:51 PM | #11 |
Rep 1,263
Yes battery has been shipped. Expect in next Thur/Fri
01-25-2020, 08:23 AM | #12 |
Rep 594
01-25-2020, 09:26 AM | #13 | |
Rep 1,263
https://sternperformance.de/en/186-bmw-m2-competition Its on a slow boat from Germany right now. Should get it soon and will take pics after its in...
01-25-2020, 12:31 PM | #14 | |
Rep 6,937
Drives: 2018 M2 AW DCT
Rayien581.50 |
01-25-2020, 01:46 PM | #15 |
Rep 1,263
I have the proper scanner to "teach" the new battery. It's simple to do..
DanG10660.50 |
01-26-2020, 07:46 PM | #17 | |
756
Rep 2,149
But if the new battery is different, you have to code the car to accept the new specs. |
01-27-2020, 12:05 AM | #18 | ||
Luxury at the redline :)
9105
Rep 7,563
Another thing is the ISTA+ program only allows you to register a battery as low as 80ah only, for the F87 software. The lithium ion battery that's in the M4 is 68ah, meaning that installing a M4 battery in an M2 is not a simple P&P operation; it requires intricate programming or coding to accept the new battery specs, that goes way beyond the typical, pre-populated battery registration process BMW's software allows. I must say the M4 lithium battery is pretty light, one can typically lift and carry it with just one hand. . |
Killed by Death12462.50 |
01-27-2020, 09:17 AM | #19 | |
756
Rep 2,149
What is going on is that BMW programmed IBS to vary the rate the battery is charged based on battery age and type of battery. With age being the only factor when you replace a battery with one of the same kind. So when you register a new battery, it is resetting the algorithm it's using to charge the battery. I'm not particularly sure this is a good idea to do if you're replacing your battery with a used one. "The negative battery cable has an electronic control unit on the battery end of it called an intelligent battery sensor (IBS). The IBS measures the state of battery charge and sends this information to the ECU. The ECU uses this information to control how much charging voltage is needed from the alternator to support vehicle electricity needs. A battery deteriorates normally over time and depending upon service demands and driving profile. The IBS reads this and the ECU tells the charging system to increase voltage and amperage output incrementally as the battery matures. Therefore, at battery replacement time, if you don't tell the ECU it has a new battery it will overcharge the new battery causing it to wear out faster. The registration process takes place in the ECU, which is the main player in this system. Also, when the IBS sees that battery voltage is too low for normal vehicle operation it can start shutting down vehicle functions to conserve power while keeping the vehicle operational. This would be accompanied by a check control warning of excessive battery discharge.” https://www.1addicts.com/forums/show....php?t=1338304 |
///M Houbi1655.00 |
01-27-2020, 03:13 PM | #20 | |
9105
Rep 7,563
Within a year, the battery was dead, I mean completely. So it's one thing to make armchair assumptions about whether or not you "need" to register the replacement battery but it's completely different to witness it before your eyes. BTW, his new battery, after the one that died, which was registered the second time around, lasted 4 years going into 5. It's your car and money, so do whatever helps you sleep better at night but factually, if you don't register the replacement battery, it will die prematurely. Just some friendly advice based on personal experience. |
01-27-2020, 05:28 PM | #21 | |
756
Rep 2,149
When I said "need is the wrong word" is because you used it in context for used batteries. Which it would be potentially harmful for. Here are more facts about how the IBS system works. It's apparent to me there are situations where registering a battery could be counter-productive. https://bimmerscan.com/bmw-intellige...ry-sensor-ibs/ |
01-27-2020, 07:26 PM | #22 | ||
9105
Rep 7,563
https://www.newtis.info/tisv2/a/en/f...older/F6WrZ7vI But forget it, I already see you're not the type to let supporting data get in way of your argument. Good luck with all that. For those that actually care to preserve the life of their replacement battery, it certainly needs to be registered, as stipulated by ISTA+ dealer program. Even manufactures like Ford now requires it. I've done the registration process a few times and with the right software, it takes less than 10 mins. Here's snapshot of the process. |
