07-18-2019, 07:02 PM | #1 |
Rep 4,154
Drives: 1/18 Monte Carlo Blue E92 M3
Anyone running 10mm spacers front/rear with stock wheels? Any issues/rubbing?
Looking to do spacers on my stock M2C wheels, considering 10mm front/rear but don't want any rubbing on full lock/with passengers/over bumps/etc.
07-18-2019, 07:25 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
That depends entirely on your ride height. If you aren't lowered at all it won't be an issue. If you're slammed then it could be a problem.
NYC Bimmer259.50 |
07-18-2019, 09:24 PM | #3 |
Rep 4,154
07-19-2019, 12:10 AM | #4 | |
Rep 4,551
Most people here (with stock wheels/tires) will run a 12 front and a 10 rear. That's what was suggested to me when I was new here so that was the first set up I tried. Turns out that wasn't the right sizing for me. I don't like my wheels tucked inside the fenders, I like them flush, so I sold those and bought 15's. That spacer width allowed the rims to fill the wheel arches just about perfectly. I could increase the fronts to 18's but at my ride height that would probably cause issues so I've decided to stay put at 15 on all four corners. You can zoom in on these photos to examine the fitment: (Note: The OG M2 has the same OEM wheel and tire dimensions as the M2C) |
4
07-19-2019, 03:24 PM | #6 | |
Rep 450
GassBoy33.00 |
07-19-2019, 04:39 PM | #7 |
Rep 943
i read somewhere here that the fender liners are different on the M2C which might cause rubbing. i just recently added spacers and went very conservatively with 5mm all around. i just wanted a slight push out of the wheel to be about even or slightly under the top of the fenders since i am at the lowest setting on the M Performace coilovers (installed rears without the perch).
808F901.50 |
07-20-2019, 07:10 AM | #8 |
Rep 35
I’ve been running 10mm all around on stock setup. No issues, still a lot of clearance.
M2C Build | Instagram: @christopherkriens
natmad667.00 MarlboroM2C237.00 |
07-20-2019, 08:46 AM | #9 |
Rep 833
Any gotchas running wheel spacers besides possible rubbing in specific cases?
Is the idea of spacers being hard on bearings not a thing anymore? Any alignment issues? Looks awesome!
///M
M2Cnme33.00 |
07-20-2019, 10:06 AM | #10 |
Rep 4,154
Picked up 10mm/12mm from BMS yesterday, will see how they look once I get them on today hopefully.
07-21-2019, 04:05 AM | #11 |
Rep 341
For what its worth, I tried out 10mm all around on stock height and wheels for a M2C. The front looked fine, but the rears poked out too much for me. The rim was slightly past the fender looking top down. Ended up with 5mm all around, gives me some room to move to a 255/275 setup later
If you're lowered, I'd go with larger spacers as the wheels tuck in more when you drop. |
natmad667.00 |
07-21-2019, 05:04 AM | #12 |
Rep 1,237
Drives: M2 Competition
Having a M2C with M Performance Coilovers (-2cm f/r) and stock 788M.
What spacers should I be looking for to get a flush look?
08-08-2019, 04:31 PM | #13 |
Rep 4,551
It's personal preference. I would just buy a few sizes to test and then return/sell the one's you end up not using.
NYC Bimmer259.50 |
08-08-2019, 08:06 PM | #14 | ||
Rep 426
MarlboroM2C237.00 |
08-09-2019, 04:31 AM | #15 | |
Rep 1,237
10mm all around would be ok but no hub-centric available.... Get a 11mm set next week for testing from a friend, will see.... Buying all i consider and send back what I don't want also not possible in Switzerland. That type of shopping works only for clothes and also only in certain stores.. Tend to buy new set of half inch wider wheels for next season. Would be the better solution for various reasons..
08-09-2019, 08:02 AM | #16 | |
Rep 4,551
https://www.ecstuning.com/News/ECS_W...nt_Kit_Global/ You can rent and return it for a small fee. |
NYC Bimmer259.50 Rumbloki176.00 |
09-07-2019, 01:38 AM | #18 |
Rep 1,237
H&R TRAK+ 10mm all around. Was the right decision together with the mp coilovers (-20mm).
Rubbing/contact impossible even under maximum load (tested). Actually plent of space left... 👍🏼
09-07-2019, 09:44 AM | #19 |
756
Rep 2,149
That's what I have right now. 255/275 Conti's with 5mm spacers. Front could stick out a bit more, or maybe that's the illusion because of negative camber. But otherwise they're good. I bought the 5mm spacers to use before upgrading to 265/285 tires.
Faikius52.00 |
09-07-2019, 08:30 PM | #21 |
Rep 130
Pics? Would you have gone with 10mm if not planning to move up to 265/285?
09-07-2019, 10:53 PM | #22 |
756
Rep 2,149
No, I wouldn't. The wheels stick out past the fenders, but the tires are still stretched, so the tops of the tires are in the fenders. I don't have a good picture. I don't take pictures of car. But I put it on my todo list to get you one tomorrow.
