06-02-2019, 10:39 AM | #2289 |
Rep 649
I think dealerships that behave in such a manner should be named on the forums so that the enthusiast community knows to avoid them.
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels |
BM235iW97.00 |
06-03-2019, 01:33 AM | #2290 |
Rep 3
Hi all, I'm relatively new to coding, I have coded both a 2017 M2 and a 2018 M4, simple things such as folding mirrors, auto memory for start/stop, remove disclaimers and power off idrive system when opening door. What I have noticed on both cars is that the anti-collision no longer works, I can practically ram someone from behind and I get no notification like I use to prior to coding. Is there an option that enables/disables this function. I cannot see anything that may be related. Any help would be appreciated.
Thanks in advance. |
06-03-2019, 05:03 AM | #2291 | |
Rep 86
Current drive: 2018 M2 Competition DCT, Sunset Orange
Previous: BMW X3 xDrive 30d |
06-04-2019, 03:05 PM | #2292 |
Rep 443
Anyone start noticing funky issues after simple coding? I removed the seat belt chime / warning and now my alarm has randomly gone off and the audio system shut down and rebooted while driving. Very bizarre as there were no electrical issues with the car earlier.
06-09-2019, 02:32 AM | #2293 |
Rep 2,384
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
So I've recently been seeing posts about full screen car play and rather than pay someone to do it I was curious if anyone has details on which parameters need changing to code this up.
Regards!
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-09-2019, 11:05 AM | #2294 |
Rep 1,899
You can't do it with just coding. IIRC It requires coding in conjunction with files that need to be uploaded (akin to a custom "update") in order for full screen carplay to work
06-12-2019, 05:05 AM | #2295 | |
Rep 2,384
Follow my builds:
06-14-2019, 08:07 AM | #2296 |
Rep 467
Hi all,
After reset (BMW Garage) I wanted to put again ASD off and other modifications on my 2017 M2 But, I can’t connect BimmerCode with VGate 2 Is BimmerCode update modifying VGate communication ? Do I change plug-in ? Thanks in advance |
06-17-2019, 02:23 PM | #2297 |
Rep 1
I just did mine with Bimmercode Apps. Works great! I bought the App and an ODB2 bluetooth, was very easy to code in normal mode and also tried the Expert mode to modify some options that were not available in normal mode.
07-04-2019, 04:36 PM | #2299 |
Rep 181
This is random however I've recently had my ISTEP updated from evo_jxxx to evo_qxxx. This update wiped out all my bimmercode settings. I've been able to re-apply all except for one feature - 4 blinks for turn signal indicator cycles.
It's no longer located under FEM in simple mode, and in expert I can't find 3060 à BLINKZYKLEN_ANZAHL_TIPP - simply not there. Any ideas? |
07-05-2019, 12:33 PM | #2300 | |
Rep 1,237
Drives: M2 Competition
07-11-2019, 02:31 AM | #2301 |
Rep 17
Upgrade screen 6.5 to 8.8 with Bimmercode
Hi
My car is 330 Touring, F31, year 2017. I have screen 6.5 on my car. I already bought 8.8 screen from a BMW 330, F31, year 2018. Will install 8.8 screen on my car soon. Can I use Bimmercode app that I can coding my screen? DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 DISPLAY_VARIANTE = breites_display Is this what I need to coding, so screen will work properly? Or I have to use computer with a software, E-Sys to execute FDL Coding? |
NyC fireman4.50 |
07-15-2019, 04:40 AM | #2303 | |
Rep 17
Do I have to disable negative battery first BEFORE I´ll remove my old screen? When everything is done, I will put negative back on the battery. I notice I have Bimmercode app but not full version. So I think I have to buy a full version first, right? Sorry for my bad english. |
07-15-2019, 10:52 AM | #2304 | |
Rep 1,028
You don't need to disconnect the battery for this installation. You do need to buy Bimmercode app. Simply removethe trim, unscrew the bolts on the old screen, remove power/display cable and do inverse installation with the new screen Once you've done that, enter bimmercode and find the two options. (Bear in mind, last time I did it the options where hidden on a long misc list, so if you don't find them, keep looking). Once you've changed the two options, press code, wait for the car to switch off and on, and then new screen should work. |
07-16-2019, 03:37 AM | #2305 | |
Rep 17
07-18-2019, 02:10 AM | #2306 | |
Rep 17
What I got information about my car. It´s HU_NBT and I found : Display size resolution : 10,25_1280x480 Display variante: Schmales_display. I´m surprised about resolution that show 10.25... because my screen is 6.5. But it works on my 6.5 So I wonder if I only need change display variante to breites_display? Last edited by Azze73; 07-18-2019 at 04:24 AM.. |
07-22-2019, 03:23 PM | #2307 |
Rep 4,554
Drives: 2015 328d xDrive
Was coding maxsaint 's LCI last night and everything worked except the angel eye brightness at 100% with the low beams on. Does anyone know if this a common issue with the LCI adaptive LED cars?
07-22-2019, 10:47 PM | #2308 | |
Rep 17
Yesterday I remove my old screen to new bigger screen 8.8. After I did coding with app and screen is working perfect! Next step is apple car play... I found out that my car have EntryNav, not NBT. I think I have two choice, buy Apple car MMI Plus from Bimmertech or change my EntryNav to NBT then upgrade software. If I want buy NBT from Ebay, I need change cables? I only know that EntryNav red(color) contact is different and need use a new cable that will fit with NBT. If yes, so where can I buy these cables? Is this worth? Too expensive? MMI plus is a better choice? I would appreciate for your suggestion. Thxs Last edited by Azze73; 07-23-2019 at 02:08 AM.. Reason: Wrong information |
07-29-2019, 02:34 AM | #2310 |
Rep 8
Deactivating startup gong (seatbelt), startup warning, door open alarm: 2018 330e
Hi I finally have bimmercode and a VGate BT dongle but the submenus under the Head Unit don't show the things I want to code.
The 3 most important things for me to code are 1. the alarm when I push the start button without pressing on the brake before closing the door 2. the gong alarm when I start the car (push start while pressing on the brake) without my seatbelt buckled 3. The iDrive warning at startup that makes me push "OK" when I start the car Am I looking in the wrong place? Is it different for the 330? Has that functionality been removed from the app? |
