EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      12-01-2013, 01:49 PM   #1
Powerslide
Drives: 2018 F80 ZCP
Estimated weight of your new M3/M4
So just for fun/discussion - what would be your guess for the way you would equip your own F8x M3/M4? Obviously we will know more about weight after Detroit debut - but until then, here is my guess:
First - Assume 3305 lbs for an M4 with new manual transmission, CCB, carbon fiber roof and lightest OEM wheels available as a "baseline" (as new M4 will be "under" 1500kg or 3306 lbs):
F80 M3: maybe 35 extra pounds just for body (approximate weight difference between E90 and E92 M3); 11 extra pounds vs CF trunk on F82; 2 extra pounds roof (F82 CF roof weight savings is 13lbs, vs only 11lb weight savings for F80); 70 lbs for DCT transmission (old manual 44 lbs lighter than DCT in E9x M3 - new manual 26lbs lighter - so assuming new DCT (from current M5/M6) same weight as DCT from E9x); and finally - steel brakes instead of CCB - 40 lbs.
So - my F80 M3 as I would
Equip it would be approx. 3463 lbs. (3305+35+11+2+70+40). Actually - I just remembered EDC v. Non adjustable shocks probably would add weight on top of that - no idea how much more though.
Anyone hazard a guess of weight difference for EDC v non adjustable shocks?
      12-01-2013, 01:56 PM   #2
Powerslide
Actually I just thought of something else - the approximate 35 lb difference between E90M3 and E92M3 assumes carbon fiber roof on E92, but steel roof (no moon roof) on E90. So I may have "double counted" the weight of roof on F80 - which would mean reduce my estimated weight by about 11lbs (now 3452 lbs)...
But still need a guess as to weight difference between EDC and non adjustable shocks...
      12-01-2013, 05:32 PM   #3
turbolag
is nonexistent with N/A
turbolag's Avatar
21
Drives: .
3450lbs.
Full leather, DCT, heated seats/ventilated seats, nav, and 19" wheels.
      12-01-2013, 05:40 PM   #4
solstice
Drives: 2015 M3 6MT
I've seen estimates of the EDC option to add ~10 lbs.
      12-01-2013, 10:51 PM   #5
khanyam4
Ring Leader of G8X Trolls
khanyam4's Avatar
Cambodia
802
Drives: NA
Originally Posted by turbolag View Post
3450lbs.
That sound good.
      12-02-2013, 02:04 AM   #6
Robin_NL
S0THPAW
Robin_NL's Avatar
8719
Drives: HS M2 Competition
3450lbs.
Well I weighed my car a few months ago. Electric/heated seats and satnav, it was filled up. 1518kg.= est 3350lbs.
I really hope a bigger car with DCT etc will weigh only 100lbs more.We'll see.
Cheers
Robin
      12-02-2013, 03:31 AM   #7
Chill72
Chill72's Avatar
Drives: 10 E92 M3 (RIP)
Cheers
Robin
Have a little faith.
      12-02-2013, 06:34 AM   #8
Black Gold
Drives: M3
M3
AW / tan
6mt
CF roof
Leather
Nav
18s (or comp if available)
Hopefully 3400 lbs or so
      12-02-2013, 07:26 AM   #9
JoeFromPA
Drives: '15 AW M3 6MT Stripper
My guess is 3,500 pounds if I weighed it myself with all fluids and 1/4 tank gas - no driver.
Manual trans, maybe full leather interior, no other options, sedan.
      12-02-2013, 09:05 AM   #10
gee-m-w
gee-m-w's Avatar
74
Drives: S4
I think this is spot on, around 3470 - 3510 when you throw it up on a corner balance scale. Power seats and a heavy battery are your easy weight reductions.
http://thmotorsports.com/i-318546.as...FUPl7AodE3wAVg
http://thmotorsports.com/recaro/reca...5/i-70578.aspx
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust
      12-02-2013, 09:20 AM   #11
z00m
z00m's Avatar
37
Drives: E92 m3
1655-80=1575kg (3472 lbs)
As i understood M4 gone weight ~80kg less then E92 m3.
So on the documents standart option m4 ~ 1575kg or 3472lbs
And around 1500 (3306) on scales
      12-02-2013, 10:16 AM   #12
Black Gold
Drives: M3
..........that battery costs 1700 dollars! that is crazy
f80post
