07-22-2013, 11:03 AM | #1 |
Rep 268
Downpipes and Emissions
Hey guys,
I have AR Catless downpipes for my N54. Also have COBB AP stage 2+ installed. Took car to local autoshop last week and failed emissions. They said that 1. The computer was recently 'reset' and is not ready for testing 2. They saw that I had no Cats Looks like my two options are go back to stock and pass emissions (due in 9 days) and sell the AR pipes or Go back to stock and pass emissions then reinstall the catless DP. I really figures having the AP installed would allow me to pass state emissions. I could also take the car to a small town south of where I live where they are more lenient, but I hear once a car has failed emissions the problem needs to be fixed with proof. Anyone have any other ideas? Thanks for all your help |
07-22-2013, 11:07 AM | #2 |
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
Well why would you do your emission test without taking the downpipe off. Everyone here knows that man. You'll guarantee a fail if you have catless downpipe. Always and I means always put your car back to stock when taking it to bmw or when your doing emissions man.
My 2 cents are take the dp off, uninstall cobb and take it in and once u pass reinstall it.
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
07-22-2013, 11:12 AM | #3 |
Rep 2,251
+1
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
07-22-2013, 11:26 AM | #4 |
Rep 268
That's what I was thinking. I contacted a small local shop to see if they can do the swap to stock and then back to AR without breaking the bank.
Would this have been avoided with the downpipe fix from BMS? |
07-22-2013, 11:27 AM | #5 |
Rep 1,362
There's a lot of misconceptions when it comes to emissions testing and DP's. First of all there's two kinds on emissions testing and depending on what test your state does will affect your fix.
1. The first test is through the OBD2 port called a readiness test, which is what it sounds like the OP's state does. The misconception is that with a tune ie Cobb, JB4, ect you will pass this test. This is wrong. All these tunes do is suppress the codes but they do not leave the ECU in a "ready or pass" state. To fix this you will need to run a DP fix from Burger Tuning or such. This will allow you to pass the readiness test with catless DP's. 2. The second is is the sniffer test. This is where they hold a sniffer at the end of the tailpipes and take a reading. The only way to pass this test is to have cats that are working. The DP fix won't do diddly squat for this test, though most states do not use this test. In short OP if they do not use the sniffer test all you need a DP fix and go to another shop that doesn't know you have catless DP's and you'll be good. |
07-22-2013, 11:32 AM | #7 |
Rep 1,945
Just put your car back to stock. Invest in some ramps and tools and learn to do it on your own. Yes it'll suck the first or second time but you'll save a ton of money!
Just a heads up man. Never take your car in anywhere someone is gonna inspect it and look at it. You'll get notes on your account and it's hard to change that perception later. Once a shop or bmw sees your car is modded they'll flag yoir account and next time you go in and your cars back to stock, they'll still know. I've got some mods on my car and it's a pain in the butt to put it back to stock but man, it pays off bro.
07-22-2013, 11:41 AM | #8 |
Rep 268
To Angerman's point. ONce it's back to stock and I uninstall COBB i'll probably have to drive around for a week until the ECU is 'test ready?'
07-22-2013, 11:46 AM | #9 |
Rep 522
What happened to your secondary midpipe cats? Did they even do the sniff test?
07-22-2013, 11:51 AM | #10 |
Rep 722
ohh the joys of living in non emissions testing states.... Cats? What are Cats??
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-22-2013, 11:53 AM | #11 | |
Rep 1,945
07-22-2013, 12:00 PM | #13 |
Rep 1,945
Everyone is in the same boat when we install catless downpipes. You will guarantee fail.
It's better to be safe than sorry so always becareful man
07-22-2013, 12:02 PM | #14 |
Rep 722
Im originally from california where they are obviously strict about it but living in florida has its advantages for its Tuners
07-22-2013, 12:08 PM | #16 |
Rep 722
I thought there were ways to beat / cheat emissions testing?
07-22-2013, 12:22 PM | #17 |
Rep 1,945
Not sure if u can change on of the dps. You might aswell take them both off if your already down there.
You can probably cheat the test if they only do the obd test and u have the bms dp fix. You may want to ask someone. I'm not to sure myself.
07-26-2013, 09:29 AM | #18 |
Rep 268
Took my car to a chain oil change place and they passed my emissions today, catless downpipes and all. Guess my ECU was ready this time. .
07-26-2013, 09:57 AM | #19 |
Rep 690
I would like to know where to find a list of states that require these testings, just in case I ever get stationed in one, or when they are needed to be done, since I have yet to get one.
07-26-2013, 05:51 PM | #21 |
Rep 294
Here in Ontario Canada they recently switched From the tail sniffer and dyno test to a simple obd readiness check. I have cobb installed with AR catless and the car passed the scan. I didn't do anything special to prepare.
You're allowed to fail one readiness check and they will still pass the car. There is no visual inspection either. |
