05-03-2013, 04:55 PM | #1 |
Rep 481
Excessive Oil On Under shield?
I was wondering how common this excessive oil collection on the under shield of our cars? My friend has a 335i with the same amount of oil collected, also in our inter-coolers when we switched.
I was putting his old ER FMIC on today and installing a oil drain valve and noticed all this damn oil everywhere.... I know I have a dry rot seal on the bottom drain of my oil catch can, but I highly doubt that it dumps this much oil. |
05-05-2013, 01:10 PM | #2 |
Rep 2,926
Drives: Cayman GT4, 135i
That doesn't look normal. Your oil pan also has a lot of residue around it and substantial discoloration. Do you have to top-off your oil frequently?
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
05-05-2013, 03:17 PM | #3 |
European Editor
10616
Rep 22,992
Looks like its from your rear crankshaft seal. See that serial number stamping... there is lots of oil around those e-torx bolts. And the rear crankshaft seal has been known to leak and cause weird fluttering(cricket) noises.
05-05-2013, 03:41 PM | #4 | |
Rep 481
I normally have to add a quart between oil changes.
05-05-2013, 03:50 PM | #5 | |
European Editor
10616
Rep 22,992
Having to add a quart between BMW's long oil change intervals is normal.
What is not normal is the amount of oil under your car(and your buddies). You obviously have a leak. Take it into your dealer. Quote:
That noise as you shut off the engine is your dual mass flywheel, as the rpms come to a stop. Your car is a manual right>? I normally just press down the clutch as I switch off the motor - to avoid that noise. But its not harming anything. Then you have that "other: noise just before the engine stops(the noise when your headlights go off)... kind of sounds like your clutch release bearing.... but you were not inside the car on the clutch? Not sure what that very last noise is. ???
