03-25-2013, 10:38 PM | #1 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
New Borla Rear Diffuser for Borla 1M Muffler Owners
BORLA® Performance Industries is proud to offer a truly unique product to the aftermarket Cat-Back™ industry we started over 30-years ago. Inspired by motorsports aerodynamics, BORLA® Performance now offers racecar-styling for your BORLA® Cat-Back™ equipped street car. The BORLA® Exhaust Diffuser is both an aesthetic and functional component adding a subtle, track-inspired look to your vehicle while decreasing turbulence below your BORLA® Cat-Back™ exhaust at highway speeds.
The BORLA® Exhaust Diffuser is not an afterthought product to our Cat-Back™ exhaust systems. They are styled to compliment your vehicle aesthetics, incorporating visual contours and multiple-fin elements for a subtle race-inspired look. The BORLA® Exhaust Diffuser is developed concurrently with exhaust system R&D for proper static and dynamic thermal ventilation, adequate vehicle ground clearance, and combined system weight savings over your factory exhaust system. The kit includes stainless steel hardware/installation instructions and mounts directly to your BORLA® Cat-Back™ with NO need to drill or remove any factory body-panels. The diffuser body construction is lightweight aluminum finished in a durable silver metallic powder coat. The finish can be customized to match your ride and can be easily removed for vehicle access or cosmetic touch-up. Be unique and one of the first to add a BORLA® Exhaust Diffuser accessory to your vehicle. Installation instructions: http://www.borla.com/products/77010.pdf Last edited by HP Autosport; 03-25-2013 at 10:45 PM.. |
03-26-2013, 07:45 AM | #3 |
Rep 3,070
I have asked this in the past; answer from Borla was no, exclusive for their exhaust.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
03-26-2013, 08:07 AM | #4 |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
Chance is not equal to zero, but the L-shaped brackets connect to the Borla exhaust. Without that exhaust the mounting is DIY including the assuming your non-Borla exhaust has ~equivalent dimensions.
Borla's distributors would not likely test Borla exhaust ownership, just don't expect DIY support. |
03-26-2013, 03:55 PM | #6 |
3886
Rep 54,510
Drives: F80 M3
