M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      03-12-2013, 12:49 PM   #1
Simon H
Simon H's Avatar
876
Drives: M5 Competition
understanding the exhaust valves opening ?
Hello Fellas,
Just got my M5 this week, and today, i had a quick look at when the exhaust valves are open, and shut etc.I notice they didnt open when stationery, on warm up, with any throttle sport setting, but when i returned, with a hot engine, they were continually open. Do they just open, then stay open, when the car is up to temperature, or am i missing any other settings/openings etc ?, Thankyou, regards, SIMON.
      03-12-2013, 01:20 PM   #2
Boss330
Boss330's Avatar
Drives: BMW
My understanding is that the valves are there to increase backpressure during warm up to speed up catalyst heating.
      03-12-2013, 07:42 PM   #3
ColdList
ColdList's Avatar
154
Drives: McLaren 675LT / C7 Z07
They are completely for noise control.
      03-12-2013, 08:47 PM   #4
py0413
py0413's Avatar
110
Drives: Slow
+1
Must stop eating..............
      03-13-2013, 03:51 AM   #5
Simon H
Simon H's Avatar
876
I know they are for noise control guys, im just trying to understand ,when they are open and shut. On some vehicles, when you press the sport button, their exhaust valves open etc. On the M5, are they just open all the time, when up to temperature ?, many thanks.
      03-13-2013, 07:05 AM   #6
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
I'm by no means an expert, but I spent some time playing around with the exhaust valves the other day. Based on my visual inspection, the only thing leading to the actuator that controls the valve is the vacuum line. I had read some comments in this and other threads that the valves open when the cats warm up or Sport+ mode is selected on the throttle control. Again, I may be wrong, but I do not think either of these is correct since there is no electronic control of the valves - it appears as if the valves can only be opened by sufficient pressure built up in the vacuum line. From moving them by hand I can tell you it's a fairly stiff spring, so a lot of pressure will be necessary - likely once the engine is above something in the 5,000 to 6,000 RPM range. I looked at a schematic of the exhaust on realOEM.com and there is an in-line electronic value farther up the vacuum tube which may control whether or not the exhaust valve is "active" based on certain settings or other conditions, but I do not think it can actually control the valve itself.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      03-13-2013, 07:15 AM   #7
Simon H
Simon H's Avatar
876
Thanks AGS.
      03-13-2013, 08:22 AM   #8
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F97 X3MC / F80 M3 / F90 M5
The valve is part of the BMW Active Exhaust and is purely for noise reduction.
It is operated by a vacuum pump underneath the trunk (a common mod on the E90s is
to disconnect the pump via the electric connector in the trunk to keep the valve open).
The basic system was initially introduced on the E46 platform and the electrical function
of the exhaust flap operation is controlled by the MS 41.1 module.
Where at idle speeds, up to 2500 RPM: the exhaust flap is closed with vacuum applied to the actuator. This causes the exhaust gas to pass through the long resonator pipe, reducing the low frequency noise that is generated.
On the F10 it is now reverse where vacuum applied means the exhaust flap is opening
There is no button/setting which will keep the valve permanent open ,the only option is to
"hard wire" the valve in the open position and seal/plug the vacuum line.
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      03-13-2013, 10:10 AM   #9
AGS
AGS's Avatar
501
Thanks for the info! Just one clarification I have to your comments. In your last sentence, if you leave the vacuum line connected to the valve actuator you do not need to plug the line, you can just wire the valve open. I did this last weekend with no impact on perfromance that was reported by members that discsonnected the vacuum line but did not plug them.
      03-13-2013, 10:15 AM   #10
jmh
jmh's Avatar
That's correct
Easy enough just leave the line plugged in as is.
Good advice
      03-13-2013, 10:38 AM   #11
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Interesting info, thanks. Since BMW seems to be concerned with the drain on the battery from the various systems in the car, and will actually shut down non-essential components if the battery is getting low to allow the car to continue to run, for those of us who will be/are using exhausts without the valve, is there an easy way to remove the vacuum pump entirely? I'd prefer to physically remove it, but I suppose a simple fuse removal would stop the electrical drain? Just thought of another question. If the vacuum needed to open the valve is generated at the pump beneath the trunk, and presumably the pump is activated electrically from a RPM sensor on the engine, why would leaving the vacuum line open affect the running of the engine?
      03-13-2013, 10:41 AM   #12
nv6425
Drives: X7 Dark Shadow
This is all fantastic information, I want to do this to get a bit more exhaust note from my OEM exhaust, has anyone done this permanently that can provide a DIY and a list of parts/supplies needed? WARNING: I'm not very mechanically inclined... so more details, the better!
///M
      03-13-2013, 10:43 AM   #13
jmh
jmh's Avatar
I
think you're trying to solve a non-issue
The pump itself won't draw any power if the car is shutoff , as long as the car is running the alternator will provide enough power.
If you're concerned about power usage you better not turn the radio, headlights, seat heater/ventilation etc on either
As a side note pulling the plug/fuse will log a fault and will be reported to the BMW diagnostic system if your car is at the dealer. Which in turn will likely have the side effect of them "fixing" it.
      03-13-2013, 10:47 AM   #14
jmh
jmh's Avatar
This thread has a lot of info in it and is also applicable to the F10 platform
http://f10.m5post.com/forums/showthr...=808507&page=2
also thread at
has useful info in it
      03-13-2013, 11:01 AM   #15
Used2be
Perennial PFC
Used2be's Avatar
I think you're trying to solve a non-issue
Of course you're correct, but I just like to get non-essential stuff out of the way when I can. And, in a worse case scenario when the alternator isn't working for some reason, it is one less draw to allow the battery to function just that little bit longer. I have been in desperate situations while trying to drive home on just battery power and it's frustrating when you don't quite make it. Would the removal of the pump from the car also log a fault if the fuse is still in place? I imagine it would, but that would hopefully have the BMW service department calling you to OK the pump replacement before they "fixed" it.
      03-13-2013, 11:57 AM   #16
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Interesting. I've observed the car warming up, valves are closed. After a couple minutes the valves open, and I have assumed that they stay opened.
Are you all saying that at some point when driving the valves close again?
Current: '16 GT4
Past ///Ms:
'13 F10 M5, Alpine Weiss III/Sakhir Orange Full
'10 E60 M5, Space Gray/Black
      03-13-2013, 12:06 PM   #17
AGS
AGS's Avatar
501
I just wired the valve open this past weekend. You will need three things:
1. Uncoated aluminum wire (available at most hardware stores)
2. Wire cutters
3. A 1/2 inch square by 1 foot long piece of wood
It's then a fairly easy process to wire open the valves:
1. Maually open the valve with your finger and insert the piece of wood up the outboard tailpipe to hold the valve open.
2. Cut a length of wire about 6 or 7 inches long.
3. Fasten one end of the wire around the joint in the valve control arm.
4. Pass the other end through the hole in the bracket that mounts the valve actuator to the exhaust system and fasten it tightly.
5. Remove the piece of wood from the exhaust pipe and ensure the valve remains open.
      03-13-2013, 03:00 PM   #18
nv6425
1. Uncoated aluminum wire (available at most hareware stores)
2. Wire cutters
Awesome AGS, thanks!
///M
      03-13-2013, 05:21 PM   #19
ColdList
ColdList's Avatar
154
also thread at
You just HAD to bring up[ that thread didn't you?-lol
Here are a few pics of when I had the OEM exhaust on and the valves wired open with aluminum wire. They are stiff but mechanically it is a very simple process.
      03-14-2013, 08:35 AM   #20
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
The next step in this process would be to gut the OEM muffler. Sure thinking about that mod next.
2021 M340i
2020 X3 M40i - her car
2019 M5, AW, DP's, MSR CAI, BM3, SOLD
2020 Chev. ZR2 Bison truck, Daily Driver
      03-14-2013, 09:17 AM   #21
ColdList
ColdList's Avatar
154
I am running a modified OEM muffler setup on my car. You can actually get those from Performing imports. It removes the valves altogether and replaces the OEM 45mm pipe with a 65mm to make it basically a straight thru system. Sounds very nice as well. Nice throaty V8 sound without any raspiness or over the top noise. They are also now in the process of developing prototype tips to enhance the look over the small OEM ones.
      03-14-2013, 10:13 AM   #22
bm5bullit
bm5bullit's Avatar
Thanks for the update, Coldlist. I just responded to you on the ECU tune with regards to Performing Imports. I will definitely contact Ron about the exhaust mod.
2021 M340i
m5post
