07-08-2012, 11:04 AM | #1 |
Rep 574
Spark plug replacement
So I had my oil changed at the dealer this weekend (and got them to change the transmission fluid - MTF-LT-5 per my instructions) without incident. Price was a bit steep so I think I'll be doing my own "in-between" oil changes from now on.
Anyway, while the service advisor was going through some of the other 1M service intervals he noticed that the spark plugs were to be replaced at the third service interval (third oil change at ~31k miles). I thought the spark plugs would be good to 60k or at least 45k. I guess it'll be covered under the free maintenance plan, but anyone know why the change so soon and will the need to be changed every 30k miles?
there is no effing automatic
07-08-2012, 11:49 AM | #2 |
Other car was a submarine
94
Rep 704
Just a shot in the dark because I have a 135 and not a 1M, but the spark plug change interval is 45K for my N54 and you have a more "tuned" N54 than I do so I would think a shorter interval of 30K would make sense.
I know that anyone that has a piggyback or ECU reflash is recommended to change at 25K, so that kind of falls in line with my logic. |
07-09-2012, 04:43 AM | #4 |
Rep 13,161
1M with already 40K kms ? Wow, you must have the highest 1M mileage to date.
///M is art ↔ Artemis
07-09-2012, 07:19 AM | #5 |
European Editor
10628
Rep 22,992
Makes sense... BMW says to change them very 45K miles for a N54/N55. And all the tuners say to change them at half that interval.
I think spark plugs are like oil changes, transmission oil and diff oil services too... they cost is so low but the pay offs are so large. It should be done IF you plan on keeping your car for the long haul.
07-09-2012, 08:18 AM | #6 |
72
Rep 2,070
This past Dec I had the PPKI installed on mine. At that time they stuck a sticker on my fan shroud reminding to change the plugs at 45K due to the PPK. I didnt know that was for a stock 135 also. Guess I need to refresh my memory about the car by reading through the owners manual again. After 2+ years I forget alot it seems.
07-09-2012, 08:38 AM | #7 | |
European Editor
10628
Rep 22,992
Also strange is that BMW says first to change them at 67K kms and then every 60K kms! Also... my Spark Plug DIY might be of interest to anyone who wants to change their plugs. Watch the Cobb video... its very helpful. 135i Spark Plug replacement DIY... http://www.1addicts.com/forums/showthread.php?t=602804
07-09-2012, 08:43 AM | #8 |
72
Rep 2,070
Thats basically the same sticker installed on my shroud, except in English. It also has the nicer metal sticker installed on the radiator support and another cheap paper one on the drivers side door jamb. That one is starting to fall of already after only a couple months.
Read through you DIY plug swap and will refer to it in the future after the warranty expires. Great info there. |
07-09-2012, 06:07 PM | #10 |
Database Hackmeister
Rep 2
My advice, based on experience, is to use the stock plugs. I have seen problems with aftermarket plugs.
(such as a slight misfire on cold start) |
07-09-2012, 08:25 PM | #11 |
Rep 574
Ah well, good to know and keep in mind. I assume the spark plug placement is the same in the 1M as the 135i?
