06-22-2012, 02:52 PM | #1 |
Rep 677
N55 mid pipe part number?? And U.S. pricing
Would anyone have the part number for the N55 mid pipe, also what is the cost @ a U.S. dealership for this mid pipe?
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
06-22-2012, 03:46 PM | #2 | |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
http://www.realoem.com/bmw/showparts...70&hg=18&fg=10 http://www.trademotion.com/parts/ind...&siteid=214672 Pictured N55 and N54
06-22-2012, 04:08 PM | #3 |
Rep 677
Is there welding involved? Or is this a direct replacement?
06-22-2012, 04:27 PM | #6 |
Rep 5,069
+1, I'm just not sure what if effects it will have on emissions?
06-22-2012, 05:18 PM | #7 |
Rep 612
Drives: On a good day, AW 1M coupe
Is either of the following possible:
1. Modify the 1M mid pipe to somehow get rid of the drone, or 2. Are there any compatible mid pipes out there that a) have secondary cats and b) don't drone? It's hard to imagine that our options are so limited. |
06-22-2012, 05:44 PM | #8 | ||
Rep 388
06-22-2012, 06:23 PM | #9 |
Rep 562
Drives: 2011 1M VO
Would effect a "tail sniff", but even in IL they don't do that anymore; has NO effect on anything else because aft of all other emissions equipment; if worst came to worst and you flunked such a test, could just swap out to OEM and be back in a heartbeat with a set of cats that are fresh as daisies!
06-22-2012, 08:00 PM | #10 | |
Rep 612
06-23-2012, 06:20 AM | #12 |
Rep 4,836
Aren't the gains minimal with the N55 pipe as compared to something like MadDad? Just curious why the need to replace the stock pipe if the result isn't all that noticeable.
06-23-2012, 06:45 AM | #13 |
Rep 1,035
FWIW From what I've heard/seen theres a much nicer exhaust tone while keeping stock appearence.
06-23-2012, 11:28 AM | #14 | |
228
Rep 3,094
06-23-2012, 12:44 PM | #15 |
Rep 677
I sure hope this is a direct replacement guys
Just left my dealer, part is ordered and in transit from Jacksonville. The parts department rep. was very helpful and warned me that the system did not show the N55 part to fit on an N54 motor. Obviously this is normal correct? But the part does in fact fit? I sure hope so as my dealer charged me $441.23 after tax : / Is this really a simple no-weld-required swap out? I know I have already pulled the trigger but peace of mind would be nice...
06-23-2012, 01:10 PM | #16 | |
European Editor
10626
Rep 22,992
I would recommend you to buy new exhaust gaskets (two up front and one in the rear) and also new spring bolts for the rear part. The bolts tend to break when R&R-ing them. Adds like $60 in parts. http://realoem.com/bmw/showparts.do?...70&hg=18&fg=10 you will need... #2 & #11 (2) 18307553603 gaskets (1) 18117553130 gasket/ring #12 & #13 bolts & springs (2) 18307790610 spring (2) 18307561670 bolts
06-23-2012, 02:54 PM | #17 | ||
Rep 677
06-23-2012, 09:51 PM | #19 |
Rep 192
I thought the gains are identical to MD mids (roughly 10 hp). My car is definately more responsive (in limp mode I sometimes chk to make sure I'm not driving around in traffic in M mode) As for sound... There is definitely a difference; ESP above 3k rpm.
06-24-2012, 06:45 AM | #20 |
Rep 4,836
Do you go into limp mode often?
06-24-2012, 09:53 AM | #21 |
Rep 192
06-25-2012, 08:21 AM | #22 |
Rep 13
Today My local dealer told to wait with the switch to N55 mid pipe, said it could trigger fault codes for incorrect back pressure that would take away the engine guarantee. Isn't this the case when you switch the DPs but not for the mid pipe?
Br, ///M |
