      12-22-2011, 10:37 AM   #1
BMW Gator
BMW Gator's Avatar
61
Drives: C8/R8/1M/X5/JK Rubicon/FJ40
2 Part Question Re: Catless DP's and CEL
1. Is there any solution available without installing a tune that will turn off the CEL when running catless DP's?
2. When a CEL is activated due to catless DP's what technically is happening (other than lighting up the dashboard)? Will the car go into "limp" mode? Will the DME attempt to alter the a/f ratio? Will there be performance degradation?
I don't yet have DP's installed but just doing some homework
Thanks for any insights!
      12-22-2011, 11:21 AM   #2
robertm
Drives: 2020 M2 Comp
Part one here you go:
http://www.burgertuning.com/dpfix.html
      12-22-2011, 01:11 PM   #3
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
1. You would have to run the BMS V3 O2 Sim
2. With the CEL light turned on, you won't lose performance. You will just have an annoying orange light on your dash.
      12-22-2011, 02:36 PM   #4
BMW Gator
BMW Gator's Avatar
61
Originally Posted by robertm View Post
Thanks robertm - but - I thought I read that this was not compatable with the 1M N54? Are you running it or know anyone who is running this on a 1M?
      12-22-2011, 04:02 PM   #5
robertm
From the weblink in bold letters:
Compatible with all N54 twin turbo motors. Not compatible with 2011+ N55 twin power turbo motor.
There are hundreds of people using it on our motors.
1addicts
