11-28-2011, 12:59 PM | #1 |
2868
Rep 11,374
Akrapovic E82 1M Downpipes
Akrapovic's new 1M downpipe is one of their most thoroughly developed pieces to date. The ends of the downpipe are cast in stainless steel to allow the best possible exhaust flow, the flex bellows in the downpipe ensure that the exhaust system can move safely without damaging the turbochargers, and reinforced brackets will last for years. O2 sensor bungs are positioned in the factory locations for easy install.
11-28-2011, 01:06 PM | #2 |
Rep 2,366
Drives: 1 M Coupe
Can not wait, the system is just amazing. Now for the WHP gains.
11-28-2011, 01:27 PM | #3 |
262
Rep 5,018
Drives: VALNCYA
quality!
quanto? |
11-28-2011, 02:02 PM | #5 |
Rep 234
Impressed! Beautiful construction.
1. Dyno results would be nice to see when available. 2. Are these Akra's 2 1/2 inch while the A/R's are 3 inch? 3. $$ |
11-28-2011, 03:34 PM | #7 |
H O O N
86
Rep 694
Beautiful pieces as usual looks to be 2.5" from the bellmounths to the end, curious on how these compare to CP-E pipes as these look similar with exception to the flex joint and brackets.
U WOT M8? |
11-28-2011, 03:49 PM | #8 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Everything they make is like a work of art!
11-28-2011, 07:52 PM | #9 | |
Rep 846
a) How does the composition of the "ends of the downpipe" affect flow? Wouldn't the shape be the determining factor? b) Does this mean that entire DP is not 100% SS? |
11-28-2011, 09:48 PM | #11 |
Rep 854
Curious to see this item. I have had some BAD experiences with vibration in the past with that type of flex section but interested in seeing it perform. Will these also fit the 135i's N54?
11-28-2011, 10:03 PM | #12 |
NCOIC of Kickin It
78
Rep 946
im guessing since akrapovic did their dp's 2.5" all the way through, that all the other manufacturers wasted their time, materials, and valuable space, having a 3" pipe tapering to 2.5" at the outlet?
If I, for whatever reason, replaced my dp's, i would go with 2.5" pipes and heat wrap them. |
11-28-2011, 10:19 PM | #13 | |
Rep 234
11-28-2011, 10:29 PM | #14 |
NCOIC of Kickin It
78
Rep 946
hate to be the pessimist, but i dont think a comparo will happen until eurotuner or somebody does it. its a lot of money and a lot of work to even do 4 or 5 sets of pipes.
11-28-2011, 10:40 PM | #16 |
Rep 2,366
Drives: 1 M Coupe
this system makes me wet
11-29-2011, 12:15 AM | #17 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Yes, all N54 135i 335i and 1M use the same DP's. AR designed versions have been installed on the 1M already.
11-29-2011, 12:32 AM | #18 |
Rep 323
I think that for relatively tame power levels (bolt ons/tune) the 2.5" should be sufficient. If you go to a 3" you will lose some low end torque/spool up but gain some deeper sound and possibly top end power depending on how restrictive the rest of the system is. It's all about the goals you want to achieve. All in all these are beautiful pieces!
11-29-2011, 12:36 AM | #19 |
1277
Rep 17,493
Drives: like I'M BOUT THAT LIFE
this's str8 up dp porn :fapfapfapfap:
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM |
11-29-2011, 07:14 AM | #20 |
Rep 234
11-29-2011, 09:52 AM | #21 |
Rep 672
+1. I am new to the bmw world but have been having fun with turbo cars for a long while. I am shocked to see so many people not looking for a true 3" setup. Is it because the majority of people running these engines retain the stock turbos thus you dont need the larger plumbing?
11-29-2011, 10:23 AM | #22 | |
NCOIC of Kickin It
78
Rep 946
