      09-04-2011, 11:35 AM   #1
mpower2
mpower2's Avatar
Germany
49
Drives: M4 Coupe
Topspeed with tune?
How fast is the 1M with a tune. (Topspeed)
The tune with 345-355PS at the Wheel.
      09-04-2011, 12:54 PM   #2
BimmerMat135
700
Drives: E82M/S213 E450 A/T
Is yours tune? If yes you should post a video your the one living in Germany
      09-04-2011, 02:03 PM   #3
Dan Parker
Drives: 2012 Golf R
351 rwhp (dynojet) indicated 186 mph on GPS. The rev limiter was very close but "the driver" didn't hit it in 6th. This was with a tail wind.
Dan Parker
      09-04-2011, 02:17 PM   #4
mpower2
mpower2's Avatar
Germany
49
Drives: M4 Coupe
not in the 6th? what was the rpm?
      09-04-2011, 04:40 PM   #5
Dan Parker
Drives: 2012 Golf R
At that speed it's hard to look at the gauges but rpm's must have been 6700-6800 by my guess.
Dan Parker
      09-04-2011, 04:47 PM   #6
MPFit
MPFit's Avatar
4
Drives: 2012 BMW 135i CSM
      09-04-2011, 05:35 PM   #7
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
Drives: Topless Brute/Hybrid Boogaloo
Go drive and find out
      09-05-2011, 12:01 PM   #8
mpower2
mpower2's Avatar
Germany
49
Drives: M4 Coupe
Can not believe that the 1M runs 186 mph.
Maybe with 10% slope and a strong tail wind.
The Aerodynamics is bad and not suitable for top speed.
CW value is 0.35. With 350rwhp it´s real 177mph by 6300rpm
I have no tune.
What´s the V-Max open without tune? Think 169mph.
What do you think?
      09-05-2011, 12:17 PM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I think a 1M with tune will do about the same V-max as a 135i with a tune.
I know with my 135i (I have a flash tune 380 PS and 520Nm of Tq and an open V-max) that I have seen 274 kph with my Navi (TomTom), that was in 6th at 6,100 rpms. I also know... quite a few tiimes I have seen 6,300 rpms - but with no Navi. I think that is 177 mph (287 kph) real speed. Not what shows on the speedo! Speedos read higher than true vehicle speed. My car still felt like there was more speed left in her. Btw... I have PS3's 225's and 255 tires on stock wheels.
Most of the 1erforum.de guys say a tuned 135i should do around 294 kph (actual speed). You only need the right (empty) autobahn and enough of a lead foot to do it. The one series is NOT the best high speed car I have driven. It makes for a bumpy skippy ride at anything over 140 mph.
A stock 1M is limited to 255 kph. Some 1M guys have said they have seen 274 kph... but IF you figgure in that the speedo read 5% high... that is really a 260 kph speed. Ad M has said no higher V-max chip for the 1M like they offer for other M models to go up to a real 280 kph V-Max. I think its because of the jumpy handling of the one series.
      09-05-2011, 12:29 PM   #10
Dan Parker
Drives: 2012 Golf R
http://androidheadlines.com/2010/05/...pp-review.html
This is what the driver used. Windows up, no A/C, and a very good road with nearly a 3 mile straight. Before the straight he hit around 110 and then let it go starting in 4th gear.
Dan Parker
      09-05-2011, 12:38 PM   #11
marcel b
marcel b's Avatar
132
Drives: F31 340i
not sure, as the 1M has worse aerodynamics.
      09-05-2011, 12:52 PM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Maybe we need a real world race.
The 1M might have slighly worse aerodynamics, but it des have thar air curtain! I am very curious as to how a tunes 135i vs a 1M vs a M3 would fare in a V-max race.
      09-05-2011, 01:29 PM   #13
Dan Parker
Drives: 2012 Golf R
Worse aero meaning the front end? Between the air curtains blasting turbulent air out of the wheel wells (reducing front end lift) and the larger openings for the oil coolers and intercooler I doubt there is any significant difference.
Dan Parker
      09-05-2011, 02:02 PM   #14
mpower2
mpower2's Avatar
Germany
49
Drives: M4 Coupe
Is anyone here can confirm Dan Parker's statement (186mpH)?
      09-05-2011, 06:12 PM   #15
Dan Parker
Drives: 2012 Golf R
Ok, I didn't want to do this but I'll take a screen shot of the top speed. If the driver ends up behind bars he is blaming you guys.
      09-05-2011, 06:18 PM   #16
Moo
Gold Member
Moo's Avatar
Drives: PSYWGN
Would be curious as to what the car's speedometer indicates @ 186mph (GPS).
      09-06-2011, 03:28 PM   #17
mpower2
mpower2's Avatar
Germany
49
Drives: M4 Coupe
Is here someone who has more data.
I was thinking here have more a tune.
Come on, let it out.
1addicts
