04-10-2011, 11:44 PM | #1 |
aiming for 450.....
304
Rep 2,910
BT Street Performance Exhaust and N55 Midpipes
The latest and greatest. I got the midpipes from E46M3to335i about a month ago and finally installed them on saturday. Nice startup and mellow sound. Also a nice difference that eliminating secondary cats can do. You can definetly feel a little better breathing. Pics will come this evening but for now, a small startup clip
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
04-11-2011, 02:56 AM | #3 |
European Editor
10596
Rep 22,992
Nice Nick. I gotta install mine. I think installing the N55 center section exhaust pipe has gotta be good for the sound AND throttle response. Do you notice less turbo lag? Or can you hear your turbos more now?
Here is my N55 mid pipe... |
04-11-2011, 06:29 AM | #4 |
aiming for 450.....
304
Rep 2,910
I am gonna do some recording at speeds and WOT today after work. I can definetly hear the turbos more and ALOT less turbo lag. I will have some pics of the install today.
04-11-2011, 02:49 PM | #5 |
aiming for 450.....
304
Rep 2,910
As promised, here are some pics when I swapped the mids out.
Always make sure that you purchase a new set of bolts, nuts and gaskets just in case Removing the mids is easy. A total of 7 bolts/nuts and that is it. 2 are 17/19mm rear, torx socket for the middle hanger and 12mm for the DP bolts. make sure you use a decent breaker bar cause they will be hard to remove. Also, even though on the pics the N55's look longer than the N54 mids, they fit with no issues Final result They are lighter than the N54 mids Also, a look inside one of the cats.......how does exhaust go through there??
05-03-2011, 01:54 PM | #8 |
Rep 27
Drives: BMW E87 118d LCI
Very nice sound
I will put a double pipe pointer in my now, and I'm wondering if I that the cats out or not |
