      03-10-2008, 05:01 AM   #1
Numb3rs
13
Drives: Looking
A new article from Steve Dinan
The future of the internal combustion engine
The future:
Whether or not you believe in global warming or the world wide shortage of oil, one thing is certain: the price of fuel is going up, and governments all over the world are putting laws into effect to improve fuel economy and curb CO2 output.
This will have profound effects on the cars we love to drive. The only way to make a high performance car engine that produces good power output on demand, low fuel consumption and CO2 output is to decrease the size of the engine and add turbocharging. The 335, 535, and 135 models are just the first few in a long line of cars BMW will likely produce. As we move forward it is likely that displacement will reduce, redlines will lower, and boost will increase. I am sure you all have heard of the new 4.4L Twin Turbo V8 coming out in the new X6. This engine will likely proliferate its way through the entire V8 product line over the next few years. Additional new engines will come out with a constant reduction of displacement and increased boost.
To get the engines to make ever-increasing power output for their size, material strength will become more important. Once BMW has had a chance to evaluate the long term wear of the new 3.0l inline six, Dinan believes BMW will upgrade the block and crankshaft rods and pistons inside the engine. They will likely increase boost as these upgrades are made, and as their confidence grows. Water jackets will be altered, and heat exchangers will get improvements to handle the extra load.
Great days ahead:
With the introduction of turbos, we can now make big power gains at low cost. The software has become incredibly complex, but even expensive software costs a lot less than making a whole turbo or supercharger kit. We are going to be making a lot of really fast cars for relatively low cost.
Be carefull:
Turbos are like drugs. Every time you add boost the engine makes more power, and so you just want to keep adding more! The problem is that long-term durability can be compromised. Things that will not show up in the first few thousand miles, or even 10k or 20k miles, will eventually show up as the car gets old. So it’s prudent even for us serious enthusiasts to add boost carefully and let the long-term ramifications of our decisions shake out before we go wild. In addition, as the factory upgrades the material strength of the engines themselves, we will be able to increase boost even more. In other words, the next generation of the 3.0L inline six will safely produce a lot more power than the current one.
Pitfalls of small turbos:
Turbos of old had a lot of lag. In an effort to reduce this, turbochargers have become very small and are now turning some incredible RPMs. It is very easy to exceed the rpm limit of the turbo, causing it to burst!! So before we can make a lot of boost at high engine RPMs, it will be necessary to increase the size of the turbos. One side affect will be increased lag.
Computer controlled boost issues:
With mechanically driven superchargers, like those in our kits for the E36 and E46, any reduction of inlet restriction or improvement to intercooler pressure drop will cause the engine to see an immediate increase in boost and power. On the other hand, with a new computer controlled waste-gate on a turbocharged engine, like that of the 335i, modifications like cold air intakes or intercoolers with improved pressure drop hardly change power output! This is because the computer will lower the turbo RPM to compensate for reduced restriction, causing the engine to continue to see the programmed boost setting and almost the same power output. A small power gain will be realized as the turbo bypasses more exhaust gasses through the waste gate and less through the turbine. Additional power can be had from a gain in intercooler thermal efficiency, but not as much as one might expect. Our testing of intercoolers and cold air intakes has yielded much less power than people are advertising. Good news though, since these modifications reduce turbo RPM, we can increase the boost at high rpm where it’s falling off, increase peak power output, and extend the rev band without over-reving the turbos.
I hope you all enjoy the new direction at BMW. I know I will!
Steve Dinan
      03-10-2008, 07:58 AM   #2
vivid
vivid's Avatar
England
40
Drives: 135i, 323i
interesting read, thanks for posting.
Current: 135i, 323i wagon.
Sold:GTI
Sold: FX45
Sold: E36 M3
      03-10-2008, 10:47 AM   #3
0002s
Mein Führer! I can walk!
0002s's Avatar
45
Drives: Not a BMW
Where did this article come from?
      03-10-2008, 01:41 PM   #4
blacknbean
Drives: e92 335i 6MT
cant wait for the n54 v2! alot the engine issues on e90post make me cringe..im waiting to see the long term issues with increased boost
good read..thanks!
      03-10-2008, 02:35 PM   #5
sohc sti
Drives: 1999 Subaru Impreza
I don't think I can wait even longer for the v2.
      03-10-2008, 02:56 PM   #6
ersatzS2
Drives: 135i
I will be surprised if there aren't a lot of incursions by tuners in the Audi community into the BMW aftermarket. All this is very old news on that side of the fence: They were all memorizing Corky Bell's "Maximum Boost" in the late '80's.
135i built 2/14/08 SGM w/Black and AL, 6 forward gears
      03-10-2008, 03:01 PM   #7
Matt60158
///M
13
Drives:
Great read.
"She blows more than my mind" - RHCP
*Aerodynamics are for people who can't build engines.
      03-10-2008, 08:36 PM   #8
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
interesting
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      03-10-2008, 11:30 PM   #9
curtdragon
Car'a'carn
473
Drives: Audi S4
2015 Audi S4  [0.00]
I was thinking the same exact thing.. he is talking like this is new news or something
      03-11-2008, 08:40 AM   #10
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
His comments about the frailty of the N54 are somewhat disconcerting.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      03-11-2008, 08:54 AM   #11
curtdragon
Car'a'carn
473
Drives: Audi S4
2015 Audi S4  [0.00]
where does he say anything about it being frail?
      03-11-2008, 09:31 AM   #12
0002s
0002s's Avatar
45
Drives: Not a BMW
Again, what is the source of this a article? How old is it? Is there other parts to it?
      03-11-2008, 10:03 AM   #13
E82tt6
E82tt6's Avatar
103
"So it’s prudent even for us serious enthusiasts to add boost carefully and let the long-term ramifications of our decisions shake out before we go wild. In addition, as the factory upgrades the material strength of the engines themselves, we will be able to increase boost even more. In other words, the next generation of the 3.0L inline six will safely produce a lot more power than the current one."
Seems to imply that the N54 isn't as durable as some other engines.
Also: "Once BMW has had a chance to evaluate the long term wear of the new 3.0l inline six, Dinan believes BMW will upgrade the block and crankshaft rods and pistons inside the engine. They will likely increase boost as these upgrades are made, and as their confidence grows. Water jackets will be altered, and heat exchangers will get improvements to handle the extra load."
-ChuckV
      03-11-2008, 02:24 PM   #14
blacknbean
someone from dinan posted it on the m5 board
http://www.m5board.com/vbulletin/sho...d.php?t=114275
      03-11-2008, 05:28 PM   #15
0002s
0002s's Avatar
45
Drives: Not a BMW
Thank you....:w00t:
      03-11-2008, 06:36 PM   #16
foxtrot
Drives:
Or perhaps, when combined with,
"With the introduction of turbos, we can now make big power gains at low cost. The software has become incredibly complex, but even expensive software costs a lot less than making a whole turbo or supercharger kit. We are going to be making a lot of really fast cars for relatively low cost."
he may simply be saying, "Gee, they've made it awfully easy for us to blow these things up, now, haven't they?" For all we know, the N54 may be MORE robust than what it replaced-- but if the amount of power it can make with turbo tuning is even more than the increased robustness, we'll still see increased failure rates.
I'm not saying the N54 is or isn't more robust than any other motor-- I'm just saying I don't think Steve Dinan is saying anything about it in the parent article, either.
      03-18-2008, 07:06 PM   #17
SAM_702
Drives: Slow Car
The N54 is an aluminum block with iron sleeves. With immense boost and heat buildup, it may warp the sleeves due heat expansion rate difference between the iron sleeves and the aluminum block. That's why iron blocks are preferred for turbocharged engines. We'll see what happens. I think Porsche have known this for a while, which is why they went with nickel plated aluminum, hence the price factor. Correct me if I'm wrong.
      03-18-2008, 09:40 PM   #18
FleaDog
Drives:
i thought boost = fuel + air; more boosting, forget about your fuel economy.
      03-20-2008, 06:58 AM   #19
Numb3rs
13
Drives: Looking
:iono:
I thought it was magnesuim and aluminum. With some special crystalized/diamond like coating embedded into the cylinder walls..?
1addicts
