      02-14-2008, 01:08 PM   #1
Advevo
581
Drives: M2 Competition, E30 M3 DTM
LSD and Ediff
My 135i has the mechanical LSD mounted. And there is NO problem with Ediff kicking in.
When everything fully turned off. The mechanical LSD does it work and no braking thru the ediff anymore. Long slides Lovely.
pffff happy.
      02-14-2008, 01:35 PM   #2
PhAzE
29
Drives: AW 1m (soon)
Which aftermarket LSD did you install? How hard was the job? Post some vids!
      02-14-2008, 02:18 PM   #3
Fast Kiwi
Drives: Si Z4R & Si X3
what kind of money was that install?? so many questions..
This thread may get VERY interesting given the subject matter!!
      02-14-2008, 02:21 PM   #4
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
How can you post that without the requisite Advevo-esque youtube links! :wink:
      02-14-2008, 02:24 PM   #5
larryn
Here's what Advevo posted a few days ago about the LSD:
Originally Posted by Advevo
First thing i am going to do is mount eibach pro kit springs. Second is a Drexler limited slip diff.
http://www.drexler-motorsport.de/ind...n&siteid=about
      02-14-2008, 02:28 PM   #6
ChrisK
ChrisK's Avatar
Drives: '19 M2C
www.ReTuneTheDeTune.com
      02-14-2008, 02:34 PM   #7
angelr
Drives: 07 aw/ir m coupe, 2013 S4
If I end up with a 135 a proper diff is high on my priorities. I too am curious which unit it was and the approximate costs involved. Not that I'm likley to pay the same here in Florida as you did in Holland, but it's a point of referrence.
      02-14-2008, 04:07 PM   #8
imported_MPower
Zoom Zoom
38
Drives: 2022 M3 6MT
Seriously... My heart rate jumped 80 beats just thinking about video of this machine.
In the garage: 2022 G80 M3 Manual - Portimao Blue
      02-14-2008, 04:08 PM   #9
WAY
458
Drives: Fast ones
Advevo is a racing driver, so he probably got his race team to do it for free. Haha.
Really good to hear though. What are the down side with the LSD on the road? I have never had any non-factory LSD before. I am very keen on this.
      02-14-2008, 05:07 PM   #10
Advevo
581
I make some driftmovies for ya guys but with my new car i mostly drift on wet roads. On dry roads my tires are to pieces in no time
Drexler is very expensive because its a base racing diff. It has 40procent lock and 30procent lock on braking. Drexler is about 2000 euro s for the diff. But at quaife you can get one much cheaper.
      02-14-2008, 05:50 PM   #11
BMWeber
Drives: 08 135i
does the 135i have the ring gear welded to the chuck. if not did you just replace the chuck or get a whole unit
      02-15-2008, 12:52 AM   #12
aus
Drives: Odysse
Here's a Qaiffe LSD for the E90 for $1,700 shipped.
http://www.e90post.com/forums/showthread.php?t=70397
      02-15-2008, 01:27 AM   #13
WAY
458
Drives: Fast ones
Good question. And what is the advantage of the Drexler one over the mass market Quife one? I am really keen on putting one on my car.
      02-15-2008, 05:08 AM   #14
Advevo
581
I have ordered a diff from an automatic 135i. Which has a shorter gearing. In that diff the ring was not wealded.
Only problem was the automatic diff housing was 2.1 cm shorter. So my middle bearing did not fit anymore from my propshaft. So i needed to change something to my bearing to get it fit.
If you go with a manual diff housing you don t have that problem. But then you don t have the shorter final gear.
I have no 3.46 instead of 3.06. The car goes so damn fast. My dealer said it s now faster than the z4 mcoupe which i drive now.
      02-15-2008, 05:09 AM   #15
Advevo
581
When you go over a curb and you have one wheel off the ground a quaife diff works like an open diff then.
Drexler don t.
But he now you talking extreme. Quaife is enough. But i have good contact to drexler that s why i use them.
      02-15-2008, 09:23 PM   #16
aus
Drives: Odysse
Quaife with a 3.06... drool
      02-15-2008, 10:16 PM   #17
WAY
458
Drives: Fast ones
Wow, with a 3.06, the acceleration would be mind boggling. Add ECU remap to that, and you have a rocketship! I wonder what the top speed is with the shorter gearing? Some of the tracks I go to like Phillip Island (the MotoGP track) are very much a high speed track, and something like the 135i would probably hit 240kmh in various parts.
      02-16-2008, 01:16 AM   #18
ehnaych
Drives: 2001 325xi
The American manual 135i comes standard with a 3.08, the change Advevo is talking about is to the automatic's 3.46. With the 3.46 the car could theoretically reach a mechanically limited top speed of 165.7 mph or 266.67 kph.
~Noel
      02-16-2008, 04:09 AM   #19
WAY
458
Drives: Fast ones
Sorry I meant 3.46. What is the theoretical limit of the 3.08?
      02-16-2008, 04:55 AM   #20
Advevo
581
3.46 is perfect because you can stil hit the limiter. Thats why i choose that.
The best is to just order a quaife and a 3.46 gearing and put it in orginal 3.08 diff housing. Then you have no fitting problems like i had.
My car goes real fast imagine a chip to 360hp or more with 3.46 gearing. you better get good tire deals then
      02-16-2008, 07:55 AM   #21
WAY
458
Drives: Fast ones
Sounds like that is what I should be doing. I think for anyone not concerned about fuel consumption, that is perfect. But tell me, why did you go with a auto diff housing? Why didn't you just use a 3.46 gearing in a manual diff housing?
      02-16-2008, 12:15 PM   #22
Advevo
581
Why
Because i want to keep my orginal diff in the garage if i sell the car it goes back on.
So i ordered a new complete diff from bmw. I had 2 choices.
Order a 3.08 diff and send it to drexler and build in 3.46 and LSD
or
Order a 3.46 diff and send it to drexler and build in LSD.
Choice 2 is cheaper. But what i did not know was that a 3.46 automatic diff is 2.1 cm shorter. So i needed to make some adjustments on the propshaft middle bearing. Nicer would be if it was bolt on.
So next time i order a complete diff from drexler with the good final gear. Which is bolt on.
1addicts
