ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Cosmetics Modification (Exterior/Interior) Discussions
  TireRack
      10-04-2008, 01:34 AM   #1
GooDy151
GooDy151's Avatar
Drives: BUS
++how to pop the front reflector out in 07?++
Do i need to take of the bumper ?
      10-04-2008, 10:50 AM   #2
Starscream
Starscream's Avatar
135
Drives: ///M Roadster + E92 335i 6MT
M or Regular Z4?
Actually easier just telling you both,
For the non M half moon looking ones there is 2 10mm nuts holding the reflector on from behind,
You can get to them from the headlight/foglight access panel its a little tricky but can be done,
The M is slightly easier,
again you will need the headlight panel in the wheel well off (easier if you take the wheels off for ******* and you push from the front of the reflector and they are just held on by double sided tape,
BUT
Try not to drop them as you push them in, If you drop them they are a PITA to retrieve
you have to push them and hold them from the back at the same time,
are you painting them?
Imola Red Roadster
zpost
