05-09-2020, 10:07 AM | #1 |
Rep 4,551
Drives: 2015 328d xDrive
My OG OEM+ Build Thread
Sold June of 2021
Hey all. Just realized I've had this car for a while (since Dec '16) and never made a thread documenting all of my modifications. A lot of it is coding and cosmetic stuff because my goal with this build is to be OEM+. I'm not interested in making it the fastest thing on the street nor do I want it to be the car that stands out the most; I just want it to look and behave the way I personally feel it should've left the factory. In the spirit of that mentality, I've tried to keep most of my mods as subtle and stock-looking as possible. I've included hyperlinks for every part and DIY where possible. Thanks for looking! Basic Info Year: 2017 Model: M2 Color: Black Sapphire Metallic Transmission: 6MT Interior seat/trim color: Black Dakota Leather w/Polar Blue Contrast Stitching and Matte Carbon Trim Package Options: Apple Car Play, Executive Package Delivery Day With Dad Exterior Modifications Autotecknic Dry Carbon Fiber Key Case Ceramic Coated Calipers Golden Wrench Blackline Taillight Overlays IND Gloss Black Front Grille Surrounds IND Painted Keyhole Cover IND Painted Reflectors Front + Rear IND Painted Roundels Front + Rear IND Painted Floating Center Caps - Gloss Black IND Painted License Plate Frame - BSM IND Painted Trunk Emblem - Matte Black LED Front Turn Signal Bulbs LED Reverse Bulbs M Performance Side Gills M Performance Rear Spoiler - Painted BSM OEM Valve Stem Caps - Black w/M Logo OEM LCI Taillights - Euro Spec OEM LED Door Logo Projectors - M Logo OEM M2C Mirror Retrofit OEM Aspherical Wide Angle Mirror Glass ONEighty Headlight Blackout Philips WhiteVision 5000k Low/High Beam TAG Painted Brake Calipers - Gloss Black AMS Painted Brake Rotor Hats - Satin Black X5M Razor Key Conversion Xpel Ultimate Paint Protection Film Interior Modifications 2018-1 Map Update Full Screen Apple Car Play IND Matte Carbon Shift Knob + Ebrake IND Euro Sun Visors IND Custom Front Seat Belts - Polar Blue IND Start/Stop Button - Polar Blue IND Ignition Bezel - Gloss Black IND M1/M2 Buttons - Polar Blue ISTEP Update - NBTevo N18092I M Performance F8X V2 Steering Wheel w/Matte Carbon Trim M Performance Stainless Steel Pedals OEM Airfresheners OEM Amplifier Splash Guard OEM Euro Headlight Switch OEM F8X Steering Wheel Multi Switch OEM LCI Instrument Cluster Retrofit OEM LED Luggage Compartment Light OEM Parking Sensor Switch Technicpnp ASD Bypass Harness Wheels/Tires 437M Powder Coated - Matte Dark Bronze Michelin PS4S - 245/265 Acer Racing 2 Piece Black Titanium Lug Bolts Black Valve Stems + Wheel Weights Burger Motorsports 4x15mm Spacers Suspension KW HAS Engine/Drivetrain Modifications E9X Slave Cylinder (CDV Delete) Exhaust CG VSC-1 Precision Variable Sound Controller Fabspeed 200 Cell Sport Cat Remus Cat-Back Exhaust + 98mm Black Chrome Tips Coding Bimmercode: (Easy Mode) Activate PDC While Moving Backwards Alarm - European AM Radio - Active Auto Lock - 1 Min Air Con On w/Auto - Off Air Con Memory - Active Air Circ Memory - Active Active Sound Shut Off Additional Video Codecs Angel Eye Brightness DRL - 100% Angel Eye Brightness Low Beam - 8% Brake Force Display Act Force - Weak Brake Force Display Flash - 5 Times/Sec Brake Force Display Location - Brake Lights Brake Force Display Mode - Flashing Brake Force Display Speed - 5kph Change BMW Gongs To BMWi Close Windows + Sunroof w/ Keyfob Comfort Opening/Closing Delay - 0.5 Sec Daytime Running Light Brightness - 100% Disable Headlight Washers Disable Legal Disclaimers Disable Orange Side Markers Disable Seat Belt Chimes Disable Windows Up Safety Feature DVD In Motion Enable Door Handle Lights In Reverse Enable Video Playback Via USB Fog Lights Can Be On With High Beam Fold/Unfold Side Mirrors w/Keyfob + CA Fuel Range Warning 2 - Not Active Indicator Flashing On Unlocking - Off Mirrors Fold/Unfold - 50kph No Horn On Lock w/Engine Running Passenger Mirror Reverse Tilt - 60% Radio/Nav Shuts Off When Door Is Opened Road Edge Warning - Grass + Curb Stone Unlock Doors When Car Is Shut Off Welcome Lighting - 60 Sec Welcome Lighting - DRL Soft On Welcome Lighting - 100% Brightness (Expert Mode) Amplifier EQ Coding Anti-Dazzle/GFHB Brows Shut Off Fog Lights Operational w/ Parking Lights ID6 Lite LCI Tail Light Coding Rear Fogs Side Markers Coded To Front Fogs Variable Light Distribution VLD Highway Light Set To 50mph ESYS Coding: LCI Instrument Cluster Coding MDM Country Identifier - ECE Thor Flasher: M2C GHAS M2C MDM M4 GTS EPS Cables Enet Lightning Adapter Photos And now for some photos. These go in order of most recent to oldest. And finally, back to where it all started: And there you have it. My love affair with the M2 Last edited by AndrewC1989; 06-20-2021 at 08:52 AM.. |
18
NYBulldog1310.00 NYC Bimmer259.50 philinit23.00 SeanWRT3179.00 DeadRabbitM216.00 WOT Bimmer1226.50 samsamdar584.50 4BMWGarage371.00 BruceM984.50 nelsdvn229.00 nioh_lbbm21716.50 Jcon157316.50 JackyStuntin154.50 HONGCHUMZI233.50 ///MFrankie350.50 dtmurf481.50 Drifter2090909.50 VicF87OG72.50 |
05-09-2020, 12:36 PM | #2 |
Rep 2,577
It's impressive so many things you did with attention into the details, and yet the car turns out OEM clean and beautiful. I'm a big fan of OEM+ mentality.
And it's been a blessing for the community to have you.
Lemania 2320
AndrewC198910931.00 |
05-09-2020, 12:47 PM | #3 |
Rep 4,551
Thanks for the kind words, Sean. Means a lot coming from you
NYC Bimmer259.50 dk2315.00 |
05-09-2020, 04:06 PM | #4 |
Rep 69
Throughly enjoyed this post ...tastefully appointed !
Thank you & may the love affair continue ! |
05-09-2020, 04:21 PM | #5 |
Rep 72
very well done man
05-09-2020, 08:43 PM | #6 |
Dom
1080
Rep 1,714
Awesome clean build. Well done.
05-09-2020, 09:00 PM | #7 |
Food Critic
1086
Rep 1,015
LOVE IT!
05-09-2020, 09:04 PM | #8 |
6634
Rep 4,145
Drives: '18 M2 6MT
Great car, and some cool shots.
05-09-2020, 09:43 PM | #9 |
Rep 1,126
Amazing build thread! I especially love the delivery day picture with your dad. Reminds me of the day I bought my first BMW.
You officially convinced me I need to sell my M40i and get an M2. |
05-10-2020, 04:07 AM | #10 |
Rep 757
Looks great, well done!
'17 M2 DCT Long Beach Blue
05-10-2020, 11:08 AM | #11 |
Rep 408
Great thread and amazing car!
05-10-2020, 02:15 PM | #12 |
Rep 1,153
Nice car, nice shots! Really like the links, too. That took some work. Really appreciate it.
That cdv delete, is it really a straight swap with the stock slave? The link does not list the M2 as a car it will work with, but it works fine? |
05-10-2020, 04:08 PM | #13 | |
Rep 4,551
It's an e90 part and yes it's plug and play. Literally identical but without the restrictor.
05-10-2020, 05:52 PM | #14 | |
Rep 1,153
But if you've done it, and it fits, and works right, then that's the answer... |
05-10-2020, 05:56 PM | #15 |
Rep 4,551
Well it's technically an E90 part not an F87 part according to bmw so yeah it's not going to be listed as compatible for that reason alone, regardless of if it fits or not. That's how the compatibility check works.
BruceM984.50 |
05-11-2020, 10:13 AM | #16 |
Rep 1,968
I prefer OEM+ -- any time I get bored and want some new little detail for my car, I'll just refer back to this list.
BTW, do you get hassled for no front plate in NJ? (Or do you just remove it for pictures?) |
05-11-2020, 10:22 AM | #17 | |
Rep 4,551
I've only gotten one no plate ticket since taking delivery (2016) and it was added on to a moving violation. This isn't my daily driver so not worried about it being a frequent issue. My F30 has a front plate. |
05-11-2020, 10:49 AM | #18 |
24185
Rep 190,777
Very nice build
09-22-2020, 04:12 AM | #19 |
Member
76
Rep 69
This is one of my favorite M2's I've seen on here. Simply stunning.
09-22-2020, 08:37 AM | #20 |
Rep 4,551
NYC Bimmer259.50 |
09-22-2020, 11:50 PM | #21 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
Great build! love how you documented all of it as well, sometimes it's hard to remember the little details as time goes by
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
09-23-2020, 12:35 AM | #22 |
Rep 789
OG frontend gets me every time ! Nice work !
