10-09-2019, 03:49 PM | #1 |
Rep 40
Need valve cover gasket. What to upgrade?
Greetings. I unfortunately need to replace my valve cover gasket and a oil filter housing gasket. Any upgrades recommended while this is going on?
Thanks much. 2012 135i |
10-09-2019, 04:22 PM | #2 |
Rep 192
If your completely OEM intake system including all hard piping is pretty much a must. Also if your spark plugs are going to be due anytime soon might as well get it out the way.
12 135i: DINAN S3, ARM 7" FMIC, MADDAD MIDPIPES, REMUS EXHAUST, INJEN INTAKE, ARM CP
Dboyz3210.00 |
10-09-2019, 04:54 PM | #3 |
1Addict
3239
Rep 7,903
Good time to take a look at the injectors, clean them. Replace plugs and coils if mileage is right. Good time to plug the PCV ports in the head of you are going to do external low side PCV to reduce blowby at idle. Otherwise...
I'd recommend replacing the valve cover entirely if high mileage, which comes with a new gasket anyway. Hard to tell sometimes if the valve cover is actually cracked, and I'd cry if I replaced a gasket on a cracked cover.
10-09-2019, 05:16 PM | #5 |
Rep 6,196
As others have said, replace the entire valve cover, not just the gasket. Also a good time to do plugs and coils.
