06-06-2019, 01:03 PM | #1 |
9587
Rep 10,878
IND | Fall-Line Motorsports Harness Collar Set
The perfect finishing touch to your interior safety, these harness collars are precisely sized to fit all Fall-Line Motorsports roll bars (1.75" diameter). With these secured in place, your shoulder straps can never slide out of position on the bar. As a result, your belts won’t slide off your shoulders while you’re pushing the car to the limit and you’re able to drive with maximum confidence. Designed to fit all 1.75" OD Roll Bars NOTE: The inside edges of your shoulder belts should be positioned no more than 3” apart on the roll bar for maximum performance and safety. Please ensure you take proper measurements before affixing these harness collars to your bar. This measurement is particularly important while using a HANS device. Product Details:
The Fall Line Motorsports Harness Collar Set may be viewed at the following link to our online store: https://ind-distribution.com/product...ess-collar-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
