10-26-2018, 03:52 PM | #1 |
Rep 341
Preparing for winter. I have a new set of winter wheels (already has tires and is balanced). I have jacks, jack stands, etc. I am able to swap them myself right? TPMS is already in the new wheels. Someone told me the suspension will mess up? Lol
I have 19" on the car now. The winter wheels are 18". Is it ok to lift the car from the front first, swap out the front two, then lift the back two wheels and swap them out? Thanks in advance |
10-26-2018, 03:58 PM | #2 |
Rep 471
Drives: F80 AW 6MT
Nothing will happen with the suspension. Never listen to that person ever again in your life for any reason whatsoever at all.
You do need to be able to torque them with a torque-wrench to the specs, which is 140Nm (103.26 lb/ft).
Gabe - F80 AW Cloth 6MT - HRE 520 - OEM GTS Hood - CS lip/spoiler/diffuser - Status Gruppe SRS Coilovers - Nose Lift - Full Suspension - OEM Alcantara & Carbon interior - BM3 - IKON |
x.shell6585.50 HRE_Wheels2125.00 |
10-26-2018, 04:02 PM | #3 |
Rep 341
Lmfao thanks man. Thats what I thought. Yes I have a torque wrench at home, should be easy
10-26-2018, 04:05 PM | #4 |
Rep 471
Drives: F80 AW 6MT
Send it buddy.
10-26-2018, 05:31 PM | #6 |
Rep 6,733
There’s a jack point on each side of the car on each corner. If swapping wheels, just put the jack there.
Honestly, if we’re asking if jacking up the car to swap wheels is ok for the suspension, maybe it needs to go to a shop or have someone who knows simple mechanics to help out. I’d hate to see you or your car get hurt. Here’s a helpful tip... for the front, leave the tires slightly loaded on the floor and loosen the lugs. Once all are loosened, then raise up the car and remove the lugs. For the rear, it’s fine to loosen the wheels while in the air because of the RWD |
10-26-2018, 06:36 PM | #7 |
Assistant TO the Regional Manager
617
Rep 728
I second this but I also know we all have to start somewhere. OP, there is really nothing to it. Have a friend or family member help you the first time to make sure you and the car are safe; it would be a good way to learn to eventually start wrenching on your own.
2018 M4 Coupe. 6MT.
Der stärkste buchstabe der welt |
10-26-2018, 06:41 PM | #8 |
2125
Rep 2,014
10-26-2018, 09:51 PM | #9 |
Rep 333
I'm a little confused. Are you simply asking if you'll be able to swap wheels yourself? Isn't that what everyone (who isn't lazy) does to every car?
Not trying to be an ass or anything. But to answer the question, you can, and you will have absolutely no problems doing 2 wheels at a time. I swap all the time between winter, summer, and track wheels. |
10-27-2018, 03:50 PM | #11 |
Rep 1,481
My 2 cents and you're free to swap your wheels however you want. I use the side jack point but the one closest to the front wheel. From that jack point, on a lowered car, I can lift up both wheels / tires within a 6-8 inches of lifting my jack. Then I place two wheels / tires underneath the car as safety in case jack decides to give out, and swap the wheels. I can swap wheels like this in under 10 mins with torquing.. YMMV
