ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Cosmetics Modification (Exterior/Interior) Discussions
  TireRack
      10-14-2017, 05:14 PM   #1
Ponta
Ponta's Avatar
17
Drives: Z4 3.0si roadster
DRL lights
I have read in the manual that there is an option for such kind of lights in my zed. I need some kind of coding? I want the inner ring to lights up when I switch to auto, because when NOW I switch to auto at 1 am on a sunny day, my lights are completly off.
      10-17-2017, 07:50 AM   #2
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
640
Drives: 2005 Z4 3.0i
So wait, when you turn your switch to Auto turn on, nothing happens when it's night time? you may have a bad switch partner.
      10-17-2017, 12:41 PM   #3
Ponta
Ponta's Avatar
17
When I switch to AUTO yes my lights are working fine in a tunnel or so. They work in the evening BUT in the daytime on AUTO my lights are completly off.
I need inner rings to join in as DRLs, like for example leds in early Audis.
I need lights 24/7 by law, but I do not want my D2S to be on when it is 13 am. Just inner rings I think you can call them DRLs. Am I right in this?
Same as you put switch into parking lamps? I guess?
      10-17-2017, 12:59 PM   #4
StickMon
My other car is on Mars
StickMon's Avatar
Drives: 2006 MR
See here.
Warning: May contain traces of nuts.
      10-17-2017, 01:02 PM   #5
3GFX
3GFX's Avatar
723
Drives: 2003 BMW Z4 3.0i
The programming is more like you can choose to activate or not activate the default options that BMW provides within the coding...and that still may not work.
For example, I wanted my fogs as DRL (since I don't have halos).
The coding went like this (as an example):
Highbeams DRL
-not active
Lowbeams DRL
-not active
Foglights DRL
-active
Which should have worked, but didn't I had no DRLs. So you'd have to get in there and play around which would take some time between loading up one change at a time and seeing if it works. You'd have to pull the module data first to even see if what you want is an option.
Hope that helps!
(for a couple hundred bux and you coming to Canada I'd giver a shot hehe).
zpost
