M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      06-10-2017, 10:20 PM   #1
wheelpro
wheelpro's Avatar
Egypt
176
Drives: M5,F10,JB4,DP,CP,METH,SSP
after 2 run afr too lean m5 f10
after 1 or 2 run with map 1,2,8
I feel my car not running well
and when I make data log I see
afr going up too 15,16
and engine temperature too high
looking for turbos its red
I changed spark plugs to be safe
but still bad
my engine too hot cause there is no fuel enough
now I am afraid from pressure pump , or high pressure pump,
I read rail pressure seņor at idle its 5 bar looking to. set point ok
but my idle play up and down
why after 1 or 2 run. my car going to die ?
any one meet this issue on s63 ?
thanks
      06-10-2017, 11:27 PM   #2
Msizzle
Drives: 2013 M6 Coupe
do you have a competition pkg?
      06-10-2017, 11:41 PM   #3
wheelpro
wheelpro's Avatar
Egypt
176
NO
      06-11-2017, 05:33 AM   #4
ur20v
Drives: F10 M5
If using JB4 and running 22psi plus you may not have enough fuel head room on a non-CP car, some do (like mine) some don't (like yours), you need meth as a top-up to keep fuel trims in check plus add cooling.
      06-11-2017, 08:02 AM   #5
wheelpro
wheelpro's Avatar
Egypt
176
Now after 1 run afr too lean on map 0 too
      06-11-2017, 08:40 AM   #6
ARC550
Drives: M3, X5, 720s, X5, 750xi
Go to your local tuner and have them diagnose. Play it safe.
      06-11-2017, 10:11 AM   #7
wheelpro
wheelpro's Avatar
Egypt
176
Map 0 = stock
Did you hear some one change fuel pump low or high or injectors !
      06-11-2017, 11:36 PM   #8
TMR
TMR's Avatar
Drives: M3
You could have got a bad tank of gas.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      06-12-2017, 10:48 AM   #9
wheelpro
wheelpro's Avatar
Egypt
176
changed gas twice
      06-12-2017, 11:07 PM   #10
wheelpro
wheelpro's Avatar
Egypt
176
mission done
      06-13-2017, 04:47 AM   #11
ur20v
Drives: F10 M5
And what was the issue... HPFP or fuel rail or bad injectors?
      06-16-2017, 10:00 PM   #12
wheelpro
wheelpro's Avatar
Egypt
176
Bad injectors
Mcc420475.00
      09-22-2017, 05:13 PM   #13
epiphanyray
Drives: 2003 E39 M5 + 2013 F10 M5
Originally Posted by wheelpro View Post
Bad injectors
Once you changed your "bad injectors" did you redyno and see what your AFR is like? I think I may be having a similar issue. Running lean, and my AFR refuses to go below 14.7-15 in stock flash.
      09-23-2017, 09:24 PM   #14
wheelpro
wheelpro's Avatar
Egypt
176
Did you use meth kit !!
Whats your setup !
      09-24-2017, 12:06 AM   #15
AWF10M5
225
Drives: f10 m5
did u have any symptom of bad injector
if so can u share and describe
thx
m5post
