Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > USA - Midwest / Rockies
      11-29-2016, 09:49 PM   #1
Oakleyguy
Resident Engineer
Oakleyguy's Avatar
Drives: Land Cruiser
2014 Toyota URJ200  [0.00]
2017 BMW M2  [0.00]
2015 BMW M4  [10.00]
2005 Toyota UZJ100  [0.00]
XIce 3 or Alpin PA4 for Denver?
Guys, thoughts on the two Michelin tire options for the winter?
I have WS80s on my beater Accord, and they perform quite well in the snow/Ice, but frankly drive like shit on dry pavement.
Anyone have experience with the PA4s?
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD
2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air
European Delivery Journal & F8X Door Rattle Fix
Machine Shop Directory - www.mfgcenter.com
      11-29-2016, 10:52 PM   #2
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
The PA4 is pretty good. You may also consider a set of Nokian Hakkapeliitta R2. They're the best IMO.
      11-30-2016, 04:01 PM   #3
Mr Pete
Mr Pete's Avatar
Drives: 997 GT3 4.1, Golf R (daily)
Nokian Hakka R2 is a great tire. I ran those last season and I got through just about everything, without any concerns.
      11-30-2016, 08:18 PM   #4
Xtabi
Xtabi's Avatar
Drives: 2016 M3
I have PA4s on my winter wheels again this season. Last year they were great. I'm not in Colorado though.
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
      12-10-2016, 01:26 PM   #5
jamesq
Drives: 2015 SO M3 6 Spd
I have a new set of PA4's on mine after having PA3's last winter. So far so good through the first snow. Blizzaks always felt mushy to me and these feel better.
      12-10-2016, 01:30 PM   #6
visi107
Drives: 2018 M3CS
I have the X-ice. Have had them on for one week. They drive great in the dry too.
My thought was, i'm getting the winter tires for the wet and snow, not for the dry. Just for the dry i could have used the summer contis, they were manageable in 20-30 deg whether just fine, that's why i went with the X-ice over a winter performance.
2018 F80 M3CS
2016 F80 M3 - May 14th ED- The ED Adventure
2013 F30 328i xdrive - Retired
      12-12-2016, 04:52 PM   #7
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
One thing I don't like about the Hakkas is their R speed rating. Not really ideal if you spend most your time on the Front Range, IMHO.
OP - I've had my PA4s for about 3 weeks and driven through a few snows in Denver/Breck and have been pretty happy. They aren't too squishy in the dry if you get the pressures right (currently running 32/35 PSI). The bad news is you may have trouble finding them this late in the year. I ordered mine in late September, and still had to wait 6 weeks.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      03-13-2019, 11:37 AM   #8
arrivederci
Drives: F80 M3
Just a follow up note on Hakkas. I put a set of R3s on my F80 and at around 32 PSI they are a handful on dry, warm roads (which can be fun). Moderate turns feel unstable and acceleration in 2nd or 3rd gears easily engages traction control. Panic stops also seem to require a lot more distance. I'll mess with tire pressures a bit more. Today's bomb cyclone should provide a good test for non-dry roads.
      03-20-2019, 02:14 AM   #9
CRRobert
Drives: 18 Avus Blue ZCP M3
I have had the Hakka 2 which i would consider similar to the X-ice 3, and great for ice or compacted snow, but was not very good in the slush or sand/mag chloride mix that can accumulate to either side of the wheel paths on the road. Changing lines could be an adventure. My PA4 were a lot better in that regard, and better for the cold dry days and keeping a performance feel, at the expense of the ice and pure snow traction of the Hakka 2 and X-ice. I would like to personally try the Hakka 8/9 without studs.
      03-20-2019, 11:09 AM   #10
arrivederci
Drives: F80 M3
I drove home last week in the middle of the storm with slushy and icy roads on the Hakka R3. They were really, really good. No issues with the soft mix and changing lanes - plenty of traction and little/no floatiness. Getting started on hills at a stoplight wasn't a problem either. Didn't drive at speed on I25 or I70 so nothing to report there yet. But the slush, snow, ice we had that day is about as bad as it can get traction wise. I anticipate I'll only have problems when the snow gets deep enough that ground clearance becomes an issue.
On dry roads though, even with different tire pressures, the deep tread and squishy tread blocks give the traction control system fits. I had a hard time out-accelerating a Nissan Leaf the other day...can't get anywhere close to full power. Put it in MDM mode and its another story.
I ran Xice3 on an xDrive F30 and while snow/ice performance wasn't as good as the Hakka R3s, it was a better compromise for dry street use.
      03-23-2019, 08:37 AM   #11
CRRobert
Thanks for the feedback
What a storm. Sometimes could not see the front of my car when driving home.
Ground clearance is definitely an issue, especially in the neighborhood streets with that kind of storm.
f80post
