ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      02-05-2008, 05:00 PM   #1
MaSt0RaS
Drives: Z4 White
Atb quaife deifferential
What do you have to say about this differential to a z4 2.5si is it worth to put on the car?
Helitorope Hotels iN MytiLiNi (Greece!)
www.heliotropehotels.gr
      02-11-2008, 04:55 PM   #2
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
Depends, do you regularly track your car?
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      02-12-2008, 05:23 AM   #3
MaSt0RaS
Drives: Z4 White
Nop , but iam asking if the car will be better and without problems...What differential do you suggest to me?
      02-12-2008, 08:25 AM   #4
Reach
gone baby gone
382
Drives: 2016 F80
What gearing are you looking into? I believe your 2.5 comes with a 3.46 from the factory, so you have to step up to something pretty steep if you really want to get your go fast from your diff.
I hear a lot more of the 3.0s changing diffs, going from the stock 3.07 open to the 3.46LSD. Personally, you could just change your open to LSD by getting an M diff and swapping it out, that wouldn't change the ratios but would be a nice upgrade regardless.
Check out diffsonline.com they build great equipment.
      11-17-2008, 04:30 PM   #5
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Quaife, The Ultimate Differential is now in stock for your Z4 3.0 at HP Autowerks, Inc.
"The Quaife torque biasing differential enables your car to accelerate quicker and corner faster. How?
By getting the power to the ground!"
"In drag-race style, straight-line acceleration runs, this results in a close to ideal 50/50 power split to both drive wheels, resulting in essentially twice the grip of an ordinary differential (they don't call open diffs "peglegs" for nothing).
In cornering, while accelerating out of a turn, the Quaife biases power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed."
If rebuildable diff cores become available, we will offer complete diff housings with the Quaife installed and ready to bolt in!!! Price TBD.
      11-23-2008, 10:12 AM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
if you have 5 gears, not 6, I wouldn't recommend it
zpost
