03-10-2021, 09:14 PM | #23 |
Rep 2,515
Unfortunately no. But I used one of the inserts from my wife's cupfone (WeatherTech) and it covers it perfectly. But this thing is so amazing, I'd cover the hole with duct tape if necessary.
04-08-2022, 03:22 PM | #24 | |
Rep 69
Can I ask whether you bought the 300mm or 380mm height lever? The height of yours looks perfect.
2016 BMW 335d x-drive Touring - DMS Remap (385bhp / 720NM) - 100k miles - Alpine White | Black Leather - Adaptive LED Headlights, HUD, Adaptive Suspension, Surround View Cameras, Panoramic Sunroof, Electrically Adjustable Seats.
04-10-2022, 07:14 AM | #25 | ||
Da Baus
283
Rep 259
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
AW F3139.00 |
03-05-2023, 12:36 PM | #26 | |
Rep 250
Have an E46 M3 with an RTD that I am looking to do some sort of solution with the IRP plate. Most the other people doing this mod have modified the plate heavily to fit. Yours seems much simpler. Just cant tell everything from the one pic. I know its sorta an old post but any info would be great. Thanks.
'16 F80 M3 DCT
TC Kline coilovers and camber plates, Apex 18" EC-7, Conti ECF 295r/275f, monoball thrustarms, SPL toe arms, Powerflex diff bushings/bracket, AP Racing 9660, Project Mu H21, Spiegler brake lines, AA midpipe, VTT crankhub, VRSF charge/j pipe, Turner tray, BM3 CS Youtube: Driver407 |
03-11-2023, 02:50 AM | #28 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Also did you take tons of photos? How did you fit it in there without damaging the cup holder? I did mine and a friends. Unfortunately for mine, the cup holder 100% had to be heated and pushed in for my CAE to fit.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
03-15-2023, 02:40 PM | #29 |
Rep 73
How long did it take you guys to install the shifter including modifying the cupholders? Still undecided on bringing it to a shop or diy. Any special tools and tricks required?
03-15-2023, 06:35 PM | #30 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
You will remove the whole center console. Be patient with the clip ins. Really watch full videos on removing the center console if there is any. Youll want a heat gun to mold the cup holder if you dont want to cut. After install, Get some tape to put over the top front of the CAE mount that will make contact with the cup holder. Put some white paint over the tape so you can see the exact spot it touches the cup holder and slowly using the heat gun bend in that area. The final clip for the connecting rod to the transmission was a PIA the first time. Buy a deburring tool just in case. My pin hole wasnt 100% clean on one end and was causing the new pin to get stuck. Look up how to unclick the different connectors. Expect 6 hours-8hrs your first time if youre doing it alone. You’re dropping your exhaust, removing the heat shield, removing some of the transmission mounts( super simple), removing the seats, removing the full center console. Then installing the CAE, carefully molding the cup holder and putting it all back together.
-2021 M2C, HS, 6MT
03-16-2023, 12:26 AM | #31 | |
Rep 73
11-07-2023, 12:40 PM | #32 |
Rep 130
Drives: 2018 BMW M2
I'm thinking of getting the CAE kit and doing the install this winter. For those of you in NA, did you buy it directly from CAE? or is there a NA distributor or something?
11-09-2023, 09:35 AM | #34 |
Rep 42
Hi All,
I am looking to remove the CAE shifter out of my M2 Comp. It came with the car when I purchased it. Does anyone know what parts I would need to revert back to stock? I wasn't given anything. I have this diagram to go off but I am not sure what to order. Also to swap them over to do i need to drop the completed exhaust off and the prop? Thanks |
