04-19-2016, 09:00 PM | #1 |
Da Baus
283
Rep 259
JRC Exhaust Valve Delete mod
JRC exhaust valve delete mod
Unlike the f80/f82, our f87 only has one exhaust valve proximal to the driver’s side exhaust tips. When you first start the car, you’ll notice it has that burbly tone but after ~30 seconds the sound becomes more subdued— thats the transition from open valve to closed valve. You can read up elsewhere on the forum about when/why the valves open/close in different driving conditions/modes. Personally, I wanted the valves open all the time. I drove the first 100 miles in Sport 90% of the time, and then got the JRC exhaust valve delete kit developed for the f80/f82. There is a pretty simple youtube video for the install . The kit essentially comes with a male and female connector to plug what was just disconnected (oem bmw connectors). Since the f80/f82 kit comes with 4 plugs for 2 valves, just get the 2 series kit that has one pair for 1 valve. The one difference from the M3/M4 that I will mention when installing this, the f87 valve is located just beyond a bend so its hard to get to with a screwdriver if you want to manually push it open. So before disconnecting the valve, put it in sport+, give it some revs, then turn the motor off to keep the valve in the open position. If you look through the medial exhaust tip on the drivers side with a penlight, you should see a sliver of the valve in the open position. Its a terrible pic, but its that sliver just beyond the bend. Easier to see IRL. As far as being able to adjust it on the fly, there is CG Precision VSC-1 that is plug-n-play and confirmed to work on our f87, but is ~ 200$. Theres the Macht Schnell EVC module, that hasn’t been confirmed for the f87 and is ~$500 and requires splicing into obd2. Theres the BMS can flap module which is ~$280 and plug-n-play, but unconfirmed for f87. If there are any i'm missing, or the aforementioned have been tried on the f87, please post! Overall, theres more gurble and pop in the low end when revs are coming down. I can’t tell any difference under load with higher speeds (perhaps bc the valves are usually programmed to be open then), but just putzing around town the Braap-gurble-brap is more prominent. Its too cheap and reversible not to try. pros: -cheap, 3 minute install -reversible -no check engine light/errors -no drone -no damage to exposed wires/connectors cons: -cannot open/close valves on the fly
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) Last edited by supersam; 04-19-2016 at 09:48 PM.. Reason: adding picture of valve |
04-22-2016, 10:28 PM | #3 | |
Rep 425
Just to clear something up on the op's post, all the other cars close the valve on startup, I'm pretty sure the f87 is like this too. The reason you hear louder at startup and then quieter later, is actually because the wastegate is open to bypass exhaust gas around the turbocharger, to heat up the catalyst faster. So if you open the valve on startup, it will be even louder than the pen car, which is still a bit louder on startup due to the above reason. Can someone confirm if the valve is closed on startup with the f87? You should be able to see with a flashlight and feel the change in exhaust flow on the left tips. |
04-23-2016, 05:24 PM | #4 |
Rep 1,406
Drives: 2020 SO - M2C
Thanks man just ordered one I'll see how it sounds. I like the first 30 seconds of start up then gets a bit quiet!
Link if anyone wants to order only 25$ shipped.. http://jrc-designs.com/charter-packa...n-m-234-series |
04-24-2016, 02:32 AM | #5 |
///MYK
111
Rep 133
Is this the valve that opens with the sports setting or something else for cold start? Just to make sure I understood this correctly, the value in this mod is to have the exhaust in sport mode regardless of the drive mode?
04-24-2016, 08:16 AM | #6 | |
Rep 1,406
04-24-2016, 01:06 PM | #7 | |
Rep 796
04-24-2016, 01:16 PM | #8 |
Rep 1,406
This mod just caps off both ends so no pins or anything bends. You can technically just unplug and tuck away but could possibly bend a pin while exposed. Or short out if gets went maybe?!
04-24-2016, 01:21 PM | #9 | |
Rep 796
05-02-2016, 08:07 PM | #11 | |
Rep 1,406
05-02-2016, 08:34 PM | #12 | |
Da Baus
283
Rep 259
Best method to open it: start it, put it in Sport+, Rev her up and shut it down.
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
05-02-2016, 09:39 PM | #13 | |
Rep 2,560
Drives: Rapidly from A to B
05-02-2016, 10:02 PM | #14 |
BMW Newb
581
Rep 903
Yes, it's required. I'd emailed the JRC store owner, who confirmed it's a necessary step, because like you I wasn't sure and wanted to confirm
05-05-2016, 09:29 AM | #15 | |
Rep 542
TIA -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
05-05-2016, 10:08 AM | #16 | ||
Da Baus
283
Rep 259
05-05-2016, 12:18 PM | #17 |
Rep 1,963
Is the valve always open in sport+ or just at certain rpms? Just wondering if it's worth doing this as I only drive in sport+ anyway.
Current
AW BMW M2 Past VO BMW 1M |
05-05-2016, 03:37 PM | #18 | |
Rep 542
-c EDIT- Just did the install, takes literally a minute or two. Only thing is, I can't tell a difference?!? In Sport and Sport+ mode I still get that lovely burble/burping when letting of the gas in lower gears. But in Comfort mode, sounds awfully quiet. I think I followed the instructions correctly (ie I started the car up in Sport+ and gave it some revs to open up the valve). oh well -c
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock Last edited by pup73; 05-05-2016 at 04:15 PM.. |
05-06-2016, 07:02 PM | #19 |
Rep 689
Trying to understand this method more compared to just buying an MPE.
Besides the ludicrous price. Is the difference between this "hack" and MPE is that you have a bluetooth to open and close the valves? |
05-06-2016, 07:42 PM | #20 |
Rep 328
Drives: Ex BMW owner, will return soon
The MPE sounds better but it's still overpriced. Only good thing about the MPE is the warranty, that's it.
05-06-2016, 07:53 PM | #22 |
Da Baus
283
Rep 259
talk to your service advisor.. most are cool with just an aftermarket exhaust. aka your warranty still stands on everything else besides the modded part (upstream problems should not be blamed on something like a catback exhaust). A downpipe, on the other hand, might not be so cut and dry since it does more directly affect turbo spool.
