08-25-2021, 08:55 AM | #1 |
Rep 3,022
Drives: 2019 M2 Competition
Mishimoto S55 oil catch can install DIY - Highly recommended!
It's that time again.. really excited to share out my latest F8X DIY from Mishimoto Automotive!
I am a big believer in having an oil catch can in any modern direct injection motor, like my earlier N55 and now the S55 in the M2C. While the residue build it MAY not be as bad as it was in the earlier e9X models with the N54 motor, I also feel its just a matter of time. A good quality catch can is an easy install, and I really see as a no brainer to have in your car. Why WOULDN'T you do so, especially with the really important other benefit this kit brings! The OEM crank case breather hose is (in)famously brittle, and I have broken two myself. The corrugated plastic gets fragile due to engine heat, and can take the slightest touch to shatter. Not only does the Mishimoto kit give you a baffled well designed catch can, but replaces the OEM hose entirely. You get high temperature hoses that will never break like the OEM. I recommend doing this install on every single S55 (and N55 too for that matter) as cheap insurance. Avoid future engine deposits, which will prevent future valve cleaning and replace the failing hose timebomb. Check it out, and very seriously consider doing this for your car.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
08-25-2021, 09:36 AM | #2 |
24199
Rep 190,807
BMW DIY Guy3075.00 |
08-25-2021, 03:29 PM | #3 | |
Rep 7,429
I wish the oil catch can in that particular area would fit the n55 m2 but it doesn't, the oil lines are in the way and I personally couldn't get anything to fit there. Also I pulled my inlet pipe to install an inlet last year and there wasn't a single drop of oil in the pipe, so for me I don't think an oil catch can would be effective - and I know other m2 guys have reported the same. That's probably because the valve cover has a second route for pcv vapors to escape into the head. The only way to truly 100% stop blow by is to tap and plug the head ports and force all the crank case vapors out of the pcv hose (otherwise even with an occ you will still have vapors going directly into the intake valves), but you should also install an oil filler cap vent in that case to ensure too much pressure doesn't build up.
BMW DIY Guy3075.00 TheHunterHofman237.00 |
08-25-2021, 03:55 PM | #4 |
Restless
1335
Rep 1,031
Great vid, thanks for sharing and taking the time to do that!!
