06-17-2020, 12:40 PM | #2201 |
Rep 3,843
About noise...on a long boring trip if you use the comfort or efficient mode it will decrease the ASD cabin sound a lot. I learned that when I did my ED pickup in Germany. Driving all day with the ASD on loud gets old. If you've turned off ASD, well nevermind my comment.
06-17-2020, 04:16 PM | #2202 |
Rep 506
Cut out the tri colors from vinyl for the front bumper slats. I used blue painters tape to make a template and applied the vinyl wet to be able to get them into position.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
06-17-2020, 09:36 PM | #2205 | |
2531
Rep 1,908
In the pick below you can see my small misfortune. If you you look closely at the mirror mount in the background you can see its position, which is important because you want to be lined right up the middle of the mount. If you are lined up, the mirror pops off quite readily; if off-center, then you will be likely laying the mirror to rest and coughing up $197.92 to your local BMW dealer for a new one. . . driver side mirror more expensive, so I would advice you start on the less expensive (passenger) side. Many videos online on the topic. These include individuals just 'yanking' the mirror cap off and others prying the mirror cap slightly off and using a mallet to pound it fully off. In my initial attempts and experience, neither is the best approach . . . obviously others have had success that I did not, so it is your call. Ultimately, it just seemed the removing the mirror caps was an all-or-none proposition, and I could not get either of the described approaches to work. My approach obviously came at a cost, but was pretty simple and involved removing the mirror and un-clipping the mirror cap from within the housing. Hopefully, my tip above will prevent you similar mishap. Also, in some videos (M2?) there are three clips that are pinched together with something like needle-nose pliers. My M2C only had two clips and they only need to be pushed to the side with a flat-head screwdriver, or similar tool, not pinched. The outer clips are easiest to manipulate and once disengaged, the inner clip will just pull off with a little tug on the mirror cap. FYI, my CF mirror caps are OEM straight from BMW. Good luck! ///AVM |
M2COMP497.50 Killed by Death12767.00 |
06-17-2020, 09:47 PM | #2206 |
6643
Rep 4,145
Drives: '18 M2 6MT
BAN_M2C4186.50 Threeebowel31.50 |
06-17-2020, 10:14 PM | #2207 |
Rep 140
Installed M Performance Coils
06-17-2020, 11:02 PM | #2208 |
Rep 3,081
Thanks! Got this one from further back.
Follow me on IG
4
06-17-2020, 11:05 PM | #2209 |
Rep 3,081
Follow me on IG
06-17-2020, 11:10 PM | #2211 |
Rep 3,081
that was my Tooshie Tuesday post this week
Follow me on IG
06-17-2020, 11:11 PM | #2212 |
Rep 3,081
Got my CSF cooling package today. Won this from their May giveaway
Follow me on IG
06-17-2020, 11:27 PM | #2213 | |
Rep 1,054
I am adding 10mm spacers as well. |
06-17-2020, 11:45 PM | #2215 |
Remove Before Flight
6882
Rep 1,615
500 miles today-- Ely NV to Vacaville, CA. US 50 is a few minutes of twisty fun once in a while, followed by HOURS of boredom as you don't turn the wheel more than an inch or two for what feels like hours on end.
Stopped in Reno and went to the National Car Museum. Nice break in the drive! Driving down to San Jose in the morning to drop off the car at Carbahn. I'll pick it up on Monday, assuming I dry out from a fancy dinner, three wineries in Napa and my wife's 50th birthday party. Getting the Carbahn software installed (without the extra startup roar and burbles, I think), and the M3/M4 intakes, VTT CBC and Mishimoto oil catch can done as well. |
06-18-2020, 07:13 AM | #2216 |
Rep 77
Drives: '20 Hockenheim M2C
Garage List 2022 Ford Bronco Ba ... [10.00]
2008 Alfa Romeo 8c ... [10.00] 1994 BMW 325iC [10.00] 1949 Mercury [10.00] |
Are those italian-market tail lamps on the tii or custom?
06-18-2020, 08:16 AM | #2217 | |
2531
Rep 1,908
Nobody but members on the forum will notice slight imperfection in fitting Out of curiosity, did you apply the 'yank' approach, or did you remove the mirror and un-clip mirror cap from within the housing? ///AVM |
06-18-2020, 08:25 AM | #2218 | ||
Rep 618
Since I replaced my mirrors to European style wide angled, I removed mirrors. Then I used a rubber mallet with a flat wooden stick to dislodge OEM mirror cap clips. |
///AVM2531.00 |
06-18-2020, 10:59 AM | #2219 |
Rep 317
Picked her up from the dealer today!
15
bjorn///M121.00 ChrisK4452.00 flybigjet6882.00 hAxel91.00 Fuji550i389.50 GPGP226.50 HazChem262.00 Killed by Death12767.00 Ed360.00 Davil6570.50 SilverScotty320.00 mcvaughan706.00 Mavallone164.50 Really_fat_ninja404.00 MovingChicane109.50 |
06-18-2020, 12:08 PM | #2220 |
6882
Rep 1,615
Nice. Shop.
Wow. Car will be done Monday.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
06-18-2020, 02:30 PM | #2221 |
Rep 3,081
I have no idea, I found a seller on eBay with clear corner tails that caught my attention and grabbed his last set. Paired with amber bulbs and gave the tail of the car a refresh.
Follow me on IG
Defiant2282.50 |
06-18-2020, 03:12 PM | #2222 |
Rep 392
Drives: 2019 BSM M2C
Early Father’s Day present to myself.
13
///AVM2531.00 Killed by Death12767.00 cptobvious2531.50 BAN_M2C4186.50 Poochie9106.00 ASAP10208.50 Fuji550i389.50 Kleinacus671.00 SilverScotty320.00 ///Pip286.00 mcvaughan706.00 Kattanah137.50 IM2C2068.50 |
