02-13-2018, 08:27 AM | #133 |
Rep 1,339
Anyone have confirmed the actual disengangement of clutch with 3 washers by observing the clutch window is under the car yet?
I removed mine last week and missing the BMS clutch stop but at the same time paranoid to use it... Wish I have a hoist available in my garage... |
02-14-2018, 05:26 PM | #134 |
Rep 584
I am not aware of a clutch window, but I am not an expert (yet) on my car. However, if it does have a window I don't believe that you'll be able to see if it is completely disengaging by just looking at it.
02-19-2018, 10:07 AM | #135 |
Rep 709
I'm really, really useless at mechanics but I managed to install mine all on my own in about 3 hours. I'm not sure how to put the clutch pedal back in place, or the brake pedal or gas pedal LOL. Actually it took me 3 minutes and I love it (3 washers).
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
04-03-2018, 09:34 AM | #137 |
Rep 20
04-03-2018, 03:33 PM | #138 |
Rep 584
The previous posts in this thread mention checking a sensor (or two) and how to do a clutch drag test. Are you looking for more confirmation than that? (Serious question - not trying to be sarcastic).
04-03-2018, 05:28 PM | #139 |
Rep 584
Here's another thread for additional information: http://f87.bimmerpost.com/forums/sho...php?p=22708623
04-03-2018, 06:05 PM | #140 |
Rep 929
04-03-2018, 09:04 PM | #141 |
Rep 1,459
Also mentioned in this thread is someone who experienced abnormal wear in a relatively short period of time after thinking the clutch was fully disengaged. I don't have the expertise to determine if a simple test I can do myself is sufficient.
04-04-2018, 12:56 AM | #142 |
Rep 175
I went back to stock. I had 1 washer installed and it felt like the clutch was dragging from time to time, especially when shifting from 2nd to 3rd at 6k+ rpm. After going back to stock it feels less notchy.
04-04-2018, 05:40 PM | #143 | |
Rep 584
If you want to be safe, don't use it. I am using it but with one washer because I feel that the clutch throw after I "think" the clutch is disengaged is sufficient - however, when it is really cold outside (like around 0-10F) and the car has just been started, the gears can slightly grind and the shifter feel especially notchy for about a mile. I am assuming that the synchro are not sliding as much as when it is warmer due to the thick fluid at the colder temps. I say this because I am considering replacing the stop with the stock one for at least the cold winters my car and I experience. Last edited by M2guru; 04-04-2018 at 05:53 PM.. |
04-06-2018, 06:55 AM | #144 |
General Moron
247
Rep 158
BMS stop arrived this morning and just fitted it. Simple enough to do but pushing the new stop in was like thumbing in a softy and required some two-handed superhuman strength
With all 3 shims in place the car will only start with a firm push of the pedal so will have to see what gear changes are like when I take it for a spin later. Last edited by Peasley; 04-06-2018 at 07:09 AM.. |
07-24-2018, 01:15 PM | #146 |
Rep 65
F80 M3 owner here (couldn't find another BMS clutch stop thread in that group that is as thorough as this one), just installed last night after having it just sit around for a year, completely forgot that I ordered one.
Definitely removes dead space, and engagement happens quick which I like. I used 2 washers (removed 1). For those concerned with whether the clutch is fully engaging/disengaging, one simple and general way: - Start the car in neutral, and on a relatively flat surface/road (where car is not rolling with foot off the brake) - Put it into first, and slowly let clutch out without any throttle input - When the car starts to inch forward, clutch is engaging flywheel Before the car started to move, I noticed there's still a good amount of travel before it happens. I'd like to think that this means there's still full engagement/disengagement but someone can prove me wrong.
2017 M3 Competition, MT
07-24-2018, 03:46 PM | #147 |
Rep 12
Gear Grind
These washers don't change the point of clutch engagement they just reduce the amount of dead space from the point of engagement until hitting the "floor." I purchased my car with 20k km's and it occasionally grinds slightly between second and third gear. The previous owner installed the washers (don't know how many.) I previously asked about gear grind on the forum with no concrete answers until now. I find it hard to believe that the my "grind" is due to the BMS kit but who knows. Do any of you manual manly men have any notchiness?
07-24-2018, 08:06 PM | #148 | |
Rep 584
07-25-2018, 04:55 AM | #150 | |
Rep 243
Drives: 2018 MGM 6MT M2
The engagement occurs with the same amount of clutch pedal throw or travel that it did with or without the stop. The stop merely limits the pedal travel with the goal of eliminating excess or unnecessary pedal travel. If the travel is reduced too much with the stop, then the clutch would not completely disengage. Again, engage / disengage would occur at the same points in the pedal travel. The question is whether or not the pedal is free to reach those points or not with the stop installed. |
07-25-2018, 05:10 AM | #151 | |
Rep 584
randyt224.50 |
07-25-2018, 12:44 PM | #152 |
Rep 468
I bought it and never installed it. Don't think its worth the (granted small) risk. Have driven the car enough now that the stock clutch take-up point just feels normal.
07-25-2018, 12:58 PM | #153 |
Da Baus
283
Rep 259
Seems everyone on the f8x platform likes on average 2.7 shims.
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
07-28-2018, 03:22 PM | #154 |
Rep 1,263
Gang I was the one who had trouble with my E36M3 after a clutch stop was installed.
It took hundreds of Auto X runs & track events but I eventually had trouble shifting from 2nd to 3rd gear. It got so bad that I had to swap in a used tranny. I wasn't trying to scare anyone, just letting you know that they are an awesome upgrade but you need to make sure that you aren't to aggressive with the adjustment. In my case I had no idea that I was slowly damaging the synco cone.. I know tons of drivers who are fine with this mod. HTH, HAZMAT
