04-17-2018, 04:44 AM | #749 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
It is more complex than this. The reason there are two turbos is mainly to improve response (reduce lag). The same level of boost can be more efficiently achieved with a single bigger turbo but it would have more inertia and hence would take longer to spool.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
Poochie9104.50 |
04-17-2018, 04:52 AM | #750 | |
General
21117
Rep 20,741
04-17-2018, 05:05 AM | #751 | ||
Rep 2,577
What I also pointed out is that when you apply WOT or anything close to that, S55 takes more time to achieve turbo shaft rpm that's demanded with the power DME asks, meaning turbo lag. Those characteristics are well reflected on the dynograph. On 5th gear dyno pull, flooring it from 1k5, S55 will see its maximum torque at 3k-3k2 while M2 N55 does that at 2k3-2k5. On 4th both do it quicker but delta remains. In real world at any time WOT, downshift to 4K+, neither N55 nor S55 will have instant power. Turbo still need time to spin up to make air flow and thus boost. Turbo lagginess exists and can't be avoided.
Lemania 2320
04-17-2018, 05:23 AM | #752 | |
General
21117
Rep 20,741
I agree that all turbo engines have inherent lag to some extent though, but the S55 has less than the N55.
04-17-2018, 05:42 AM | #753 | |
Luxury at the redline :)
9105
Rep 7,563
I don't want to keep going back and forth on this subject but I would like to get it correct, can you direct me to any articles or forum discussion where I could research a it little more in-depth. I will do my own search also. Thanx. |
04-17-2018, 05:48 AM | #754 | |
Mini Beast
188
Rep 361
There is a big Jump in price from a standard M2 to M3/M4. You could see the jump is acceptable as they have different engines and more luxurious. New M2C Same engine, same seats and more, for a bargain price less than a M3/M4 don't seam right. M3 and M4 little difference in price but the M2 is in another postcode lol
M2 = big smile every time
04-17-2018, 06:16 AM | #755 | |
Rep 790
Still waiting to find out what a "weight-optimized twin turbo" means. |
M3 Adjuster7905.50 |
04-17-2018, 06:55 AM | #756 |
Rep 258
04-17-2018, 07:01 AM | #757 | |
General
21117
Rep 20,741
What you describe is possible in sequential turbo arrangement like on the Mazda RX8 rotary engine or the triple turbo M550d. But it simply isn't the case for the turbo arrangement on the N54 and S55. When turbos are setup in parallel, such as with the N54 and S55, they both work concurrently at the same level. Each turbo is fed by their own individual trio of cylinders, so the engine would not be in balanced operation if they were set to supply different boost levels. As I posted previously, a large turbo is actually more efficient at producing large amounts of boost. However, a large turbo has much more inertia and needs more mass flow to operate, so it will have a much higher boost threshold and significantly more lag. A parallel multi turbo arrangement is a compromise to be able to achieve higher boost levels while minimizing lag and lowering the boost threshold. Vanos is BMW's designation for variable valve timing while Valvetronic is BMW's designation for variable valve lift. These technologies can also be applied on normally aspirated engines or turbo engines of different configurations. They can be tuned to optimize turbo operation, but their presence is not related to the quantity nor the arrangement of turbos.
Poochie9104.50 |
04-17-2018, 07:20 AM | #758 | |
9105
Rep 7,563
CanAutM321116.50 |
04-17-2018, 07:41 AM | #759 |
Rep 13,106
Earlier today BMW M posted this picture on its Instagram account + #M2 (see ):
But don't be fooled: that ain't the new 788M wheel (M2 Competition). To my eyes that's the 405M 2-Series M Performance wheel (19" forged light alloy wheels) of Autumn 2013 (see here). In Spring 2014 BMW presented the virtual BMW Vision Concept GT6 featuring exactly those wheels, though with full black finish + red-colored rim protector. Posted by the same photographer (https://www.instagram.com/thomasschornfotografie/?hl=en) (M2 LBB under neon lights): For the record: 405M 2-Series M Performance wheel (Autumn 2013) (the bi-color BMW GT6 Vision concept wheel):
///M is art ↔ Artemis
04-17-2018, 08:26 AM | #760 | |
4972
Rep 10,200
04-17-2018, 08:28 AM | #761 | |
4972
Rep 10,200
04-17-2018, 08:43 AM | #762 |
Rep 118
04-17-2018, 09:51 AM | #764 |
Rep 2,505
So the M2c will be revealed tomorrow April 18 in Germany?
04-17-2018, 10:34 AM | #767 |
Rep 3,842
All prices for goods throughout Europe and the UK include VAT, it's just the way they do it. It is common knowledge there.
04-17-2018, 10:39 AM | #768 |
Rep 3,622
04-17-2018, 10:43 AM | #769 |
General
21117
Rep 20,741
I guess I'll be allowed to say so on the M2-Competition forum
04-17-2018, 10:47 AM | #770 | |
Rep 1,609
The vast majority of dealer services are recorded and picked up by Carfax. Sometimes an oil change isn't listed specifically, and it may be listed as "scheduled maintenance performed." So then I call the dealer. Autocheck is a whole 'nother issue (and basically a scam). So, let me put it this way: "You wouldn't believe how many dealers I've called to ask about a service record for an M2 and found there were no oil changes done until 9,000, or 10,000 or 12,000 miles." Some dealers will give you that information if you have a VIN #. Others won't unless you own the car. In which case, I pass on that car. Trust me, I'm doing my homework before I buy. Would you want to buy a car that had an owner who didn't care about maintaining their car? I wouldn't.
'17 M2 San Marino Blue, 6MT; 2011 335iS, 2007 328i, 19 Ram 1500, '18 Yamaha MT-07, '14 Kawasaki Ninja 1000. SOLD: '16 European Delivery M3 San Marino Blue, 6MT. '13 335iS, 2002 M3 6MT, 1997 M3, 1998 M3, 1996 328is (picked up in Munich at OLD ED Center), '88 Mustang GT 5.0, '84.5 Mustang SVO Turbo, '77 Rabbit,a cool 1992 Taurus SHO, and KTMs.
