06-13-2022, 04:16 PM | #1 |
Rep 6,979
Drives: 2018 M2 AW DCT
50th Anniversary Roundel
Just purchased the 50th Anniversary Roundel. Will take 3-4 weeks to arrive from Germany.
06-13-2022, 07:30 PM | #3 |
3039
Rep 13,778
~loud noises~
DanG10845.00 infinitekidM2C4229.50 BMW DIY Guy3109.50 Kikuchiyo125.00 prompt292.00 AndrewC198910949.00 Jeffe204.00 |
06-13-2022, 07:33 PM | #4 |
Rep 6,979
06-13-2022, 07:41 PM | #5 |
Rep 1,614
DanG10845.00 toolband66256.50 |
06-28-2022, 03:22 PM | #6 | |
Rep 3,046
Drives: 2019 M2 Competition
So the number you show on the box in the pic, I have listed as the "truck retrofit". Here are all the part numbers I was able to find, but ZERO US distributors have them yet. I DID just find 545 on Schmiedmans! MW EMBLEM 50 JAHRE M Ø 82MM / M 51148087188 BMW EMBLEM 50 JAHRE M Ø 74MM / M 51148087195 NABENABDECKUNG 50 JAHRE M BMW 36135A37E40 BMW EMBLEM 50 JAHRE M Ø 74MM / M (Trunk RetroFit) 51148087196 BMW EMBLEM 50 JAHRE M Ø 82MM / M (Hood RetroFit) 51117886545 NABENABDECKUNG 50 JAHRE M BMW (Wheel Hub RetroFit) 36125A57484 Can you confirm which part numbers you used for trunk and tail? Thanks!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
DanG10845.00 AndrewC198910949.00 |
06-28-2022, 03:23 PM | #7 |
Rep 3,046
What is APM and could you please confirm which part numbers you used?
Thanks!
06-28-2022, 04:09 PM | #8 | |
3039
Rep 13,778
Select a 74mm and a 82mm in the drop down menu. My guess is that IND has these also now, but they haven't marketed yet to fit our F8x cars yet. But I'm sure once they notice these posts, they'll adjust accordingly.
~loud noises~
BMW DIY Guy3109.50 DanG10845.00 |
06-28-2022, 04:13 PM | #9 | |
Rep 3,046
NICE!!! Thank you! Schmiedmans is just a little cheaper nicely enough and just checked there. They were also able to provide the Motorsport front sway bar when no one else could! I have auto leveling hubs now, and would LOVE them to be Heritage as well, but not sure I want to pay the expense on that.. will see. Thank you again, ordering now!
06-28-2022, 04:52 PM | #10 | |
3039
Rep 13,778
~loud noises~
BMW DIY Guy3109.50 |
06-29-2022, 08:23 AM | #12 |
Rep 3,046
Schmiedmans is now telling me late August at best, so I cancelled my order. I have reached out to APM to confirm availability.
06-29-2022, 11:32 AM | #13 |
3039
Rep 13,778
Not surprised. It took a little over a month to get the initial batch of emblems. You should just reach out to IND and confirm what they have. But be sure they're in stock. I was told a M235iR trunk would take 2 weeks, and it's been 2 months. Had I gone with APM, I would have gotten it in 2 weeks.
~loud noises~
06-29-2022, 11:39 AM | #14 | |
Rep 3,046
They said they have them in stock so assume shipping quickly. I ordered the same front and rear, so hopefully good to go! I am hearing its likely there will be new style self leveling hub models, (which I have now) but no part numbers on those yet. Not sure I way to pay that premium again so likely will end up mismatched long run, not sure anyone else will care other than my low level OCD. 8)
06-29-2022, 11:58 AM | #15 | ||||
3039
Rep 13,778
~loud noises~
06-29-2022, 08:35 PM | #16 | |
Rep 6,979
06-29-2022, 09:06 PM | #17 |
3039
Rep 13,778
I'm sure there are various versions. I'm happy with the version I got. If you want to spend the money and experiment and find an alt, by all means. Both fit great.
~loud noises~
DanG10845.00 BMW DIY Guy3109.50 |
06-30-2022, 04:12 PM | #18 |
Rep 3,046
well lets hope this is right! Shipped today!
Shipped Items BMW G82/83/ 2 Series Front Hood - 50 Years Anniversary Badge (74/82mm) SKU: 51117886545 Size: 74mm (G8* M Cars) Price: £49.00 Qty: 1 £49.00 BMW G82/83/ 2 Series Front Hood - 50 Years Anniversary Badge (74/82mm) SKU: 51148087190 Size: 82mm (other models) Price: £49.00 Qty: 1 £49.00
DanG10845.00 |
07-02-2022, 04:33 PM | #19 |
Rep 6,979
My hood roundel showed up today. I had to break off the tabs and add 3M doubled sided tape to install it. Looks great though. 5117886545.
07-05-2022, 11:55 PM | #20 | |
3039
Rep 13,778
it should have had tape on it already, no?
~loud noises~
DanG10845.00 |
07-06-2022, 08:55 AM | #21 |
Rep 6,979
07-06-2022, 01:36 PM | #22 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
There are over a dozen 50th Anniversary Classic M Roundel PNs as shown in this PaddleShifterz (Germany) video. So be very careful before ordering a set. If the back adhesive and pins don't match your current roundel design, you probably have the wrong PN.
They were due in the US in June 2022, but it looks like July/August. BMWPartsPros has them listed for pre-order, but some of the fitment info is incorrect. In general the hood is 82mm and the trunk is 74mm. Larger BMWs have 82mm roundels for both the hood/trunk. There are wheel hub center caps for cars with a 5 x 112mm bolt pattern, like the G8X M3/M4. Word is there will not be any floating center cap versions. Older BMWs use a 5 x 120mm bolt pattern...not sure if the 50th Anniversary Classic M wheel hub center cap will be made to fit older BMWs. Cheers Last edited by nyc_dude; 07-07-2022 at 12:09 PM.. |
