M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Odd window behavior on shutdown
      07-03-2018, 11:23 PM   #1
Rupes
Rupes's Avatar
Drives: F87 M2 (current), E90 330xi (w
Anyone else experience this? I pull into the garage, and pull both window tabs up hard to activate the automatic close function. Windows are halfway up and I turn off the ignition and suddenly, one of the windows goes back down while the other one continues to finish closing! Can't figure it out,and it has happened a couple times.
I've coded ASD off with Bimmercode, but nothing else. Not sure if that's related, but thought it was worth mentioning.
      07-03-2018, 11:24 PM   #2
430409M2
430409M2's Avatar
95
Drives: ///M2 PE
Try turning on the power, hold the window button down till the window is all the way down, release and quickly press the button again and hold for about 5 seconds. Now try the windows again.
      07-04-2018, 09:21 AM   #3
Rupes
Rupes's Avatar
Just to be clear - I'm immediately able to correct the window going down (it isn't stuck or anything). Just seems odd it would inexplicably reverse course!
      07-05-2018, 10:03 AM   #4
JB330Ci
Drives: M2 LCI
Same thing happened to me this morning. Same situation like yours, the passenger side reversed the closing and went down. For safety reason?
      07-05-2018, 04:56 PM   #5
McGary911
McGary911's Avatar
Drives: 2017 LBB M2 DCT
It happens to me from time to time. I like fresh air so usually have the drivers window down. It’ll happen sometimes when I’m turning off the car. I’m wondering if you code the button to only need one push (rather than 2) if his behavior will continue? It seems to happen to me on push #2 if I’m remembering correctly.
2017 LBB ///M2 DCT
2013 Porsche Boxster S
      07-06-2018, 08:41 AM   #6
Rupes
Rupes's Avatar
Have you coded off ASD?
      07-06-2018, 08:44 AM   #7
supersam
Da Baus
supersam's Avatar
Drives: F87 6MT, RA, E46
I have asd off, this happens to me on occasion too. Rare though
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      07-06-2018, 09:36 AM   #8
JB330Ci
Drives: M2 LCI
Yes, I have the ASD coded off. Also coded turning accessory off when open the door.
      07-06-2018, 11:39 AM   #9
hshot_rooke
123
Drives: 2017 BMW M2
This happens to me too. If the windows are closing when I shut the car off, it sometimes reverses direction. Electrical conflict?
I have ASD coded off too, but I don't think they're related.
      07-06-2018, 04:52 PM   #10
Rupes
Rupes's Avatar
Until I see someone post that it happens to them without ASD coded off, feels like more than a coincidence.
      07-06-2018, 11:11 PM   #11
supersam
Da Baus
supersam's Avatar
I think we can just replicate different shutdown sequences and see what triggers it
1- window up full
2- push ignition off
3- open door
Just try the above in different permutations
      07-13-2018, 11:03 AM   #12
McGary911
McGary911's Avatar
My ASD isn't coded out. I have a bypass cable.
2017 LBB ///M2 DCT
      07-19-2018, 07:15 AM   #13
GoneIn4Secs
1287
Drives: BSM F87 LCI (DCT)
Why do u have to turn off car midway the windows are going up?
      07-19-2018, 04:40 PM   #14
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
I would try coding out the safety feature that prevents the windows from auto closing when the door's open. Not sure if that would help or not but it's worth trying IMO.
      08-21-2018, 06:32 PM   #15
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
I had this happen to me recently - didn't even realize my passenger window was down until I came back after work!
Now I just roll up all windows first and then press the ignition button.
      08-23-2018, 07:39 AM   #16
Rupes
Rupes's Avatar
Have you done any coding to your car?
      08-23-2018, 08:53 PM   #17
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
Yes and ASD turned off is one of changes I made.
