BMW M2 Forum > M2 Photos, Videos and Builds > ► TYSPEED BMW M2 Race Car on APEX ARC-8R Forged Wheels
      08-19-2019, 06:02 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3523
Drives: M3
TYSPEED + APEX FORGED
The Tyspeed team has been running our 18” FL-5 flow formed wheels on their BMW M2 race car for a few seasons now. After claiming the title of BMW CCA Club Racing’s North Atlantic 2018 Regional Champion (B Modified), along with participating in numerous Time Attack events in preparation for the biggest event of Tyler’s career, the 2019 Pikes Peak International Hill Climb, I think it is safe to say that our wheels have been put to the test.
Tyler and his team are always chasing the bleeding edge of performance, and APEX has been right by their side with an identical goal in mind. Armed with our new forged wheel line up, APEX is proud to support their efforts to get to the next level of performance. Tyspeed is first to receive a set of our all-new polished 18” ARC-8R forged wheels, in a wide 18×10.5” ET40 rotatable square configuration.
These forged wheels clear the massive Stoptech 6 piston 380mm brakes mounted on the M2 race car with ease, and with an impressive 1,800 lbs load rating, they will provide more than enough strength and durability to keep up with the crueling demands set forth by Tyler and his team.
Car Details
  • 2017 BMW M2 Club Racer
  • 3,000 LBS Dry, No Driver
  • Power Rating : 505 whp/ 540Ft/Lbs Torque
  • BMW CCA B-Modified
  • NASA GTS-U
Note: Build specs have not changed from previous Pikes Peak post found here.
APEX Wheel & Tire Setup
  • 18×10.5″ ET40 ARC-8R Forged Wheels in Polished Finish
  • 295/35/R18 Toyo Proxes RR (DOT Compound)
  • 25mm front spacers for suspension clearance
Body, Chassis & Interior
  • Completely stripped interior
  • Tyspeed Composite Doors, Hood, and Deck lid assembly w/ factory mounting
  • RKP Carbon 2×2 Roof From IND Distribution
  • Club Race Spec Roll Cage-Fabricated In house
  • BMW M235IR Carbon Floor pan inserts / 1pc Center console
  • Custom Carbon Door panels/Rear bulkhead/interior trimmings
  • 13 Ecu’s Removed, wiring harness thinned, operational I-drive + Drive dynamics + Functional HVAC/Defrost
  • Sparco Circuit II Seat + Sparco Clubsport Belts
  • KMP Drivetrains F8x Paddle Shift wheel w/ Quick Release + DSC Buttons
  • AIM MXG Data System W/ Smarty Cam HD From Krause + Associates Beta F8x Protocol For CAN BUS
  • Ultrashield Lexan Windshield (custom Cut) Lexan Side windows
  • Longacre Wide View Mirror
  • AJ Hartman Aero Apex 12 Dual Element Rear wing w/ custom CNC machined swan neck uprights
  • Dual Stage Rear Diffuser System + Flat Floor Panel From AJ Hartman Aero
  • AJ Hartman Aero C5 Corvette Front Canards (custom cut)
  • Motorola Digital Long track radio communication system
  • RKP Carbon GP front lip w/ AJ Hartman Aero Custom Splitter w/ tunnels
  • SPA Techniques On board Fire system
  • SPA Techniques Side View Mirrors
Suspension & Brakes
  • Stoptech STR-60 15” Brake kit F+R 6 Piston Front, 4 Piston Rear Fully forged calipers w/ custom brake ducting kit
  • Stoptech Stainless brake lines
  • Performance DSC/ABS Coding
  • JRZ RS-PRO 2 Way Remote Adjustable Coilovers 1000LB Front 1200LB Rear Springs
  • Ground Control Articulating Rear spring perches/ Adjustable Front camber plates
  • Fall Line Motorsports Spherical Front LCA Bushings
  • Fall Line Motorsports Adjustable Rear Toe Arms
  • SPL Parts Front Lower Control Arms
  • SPl Parts Front Bump steer adjusted Tie Rods
  • SPL Parts Rear Forward Trailing Arm kit
  • All Factory Rubber suspension bushings are poly / Spherical replacements
  • Dinan Upgrade Sway Bar Kit F/R w/ Custom End links
  • GTS EPS Steering Flash
  • GTS ABS/DSC Flash
Drivetrain
  • N55B30T0 w/ CP Standard size/compression Forged pistons , Carrillo
  • Connecting Rods, ARP Hardware
  • ARP Studded Block M11x1.5
  • Ported Cylinder head from HeadGames Motorworks
  • CSF Racing 4 PC Cooling kit including Tripe Pass Racing Radiator, Stepped Intercooler, Boss 275 Cubic Inch Oil cooler , and Double pass DCT cooler
  • Dual M4 Auxiliary Radiators w/ Boost pump
  • A/C system Removed + Coded out
  • Pure Turbos Stage 2+ Turbocharger
  • VRSF Stainless Downpipe plumbed into custom-fabricated 3” Oval Exhaust
  • Burger Tuning Catch Can + Oil cooler bypass Valve
  • Custom Tuning By Frank Smith for MS109 Fuel
  • Meth Injections system w/ Pre+Post Inter-cooler Sprayers
  • GTS Rear Differential Flash
  • GTS Transmission Flash
  • Powerflex Poly Rear Differential Mount bushing Set – Black Series
  • VRSF 2 PC Charge Pipe
  • Pyrotec 15 Gallon Fuel Cell w/ walbro 450 In Tank Pump + Dry Break Filling System
  • XDI 35I High Pressure Fuel Pump from TTFS
  • Tuned to 505 WHP / 540 Ft/Lbs OF Torque
Ed360.00
      08-22-2019, 08:48 AM   #2
white2abbit
white2abbit's Avatar
1122
Drives: Cayman GT4
Love it!
'98 BMW 328i sedan (R.I.P.)
'16 Porsche Cayman GT4
'18 Porsche 911 GT3 Touring
'20 BMW M2 Competition (6spd, Euro-delivered July '19)
      09-01-2019, 06:09 AM   #3
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
What a bad boy! 👹👍
      09-01-2019, 11:24 PM   #4
PilotxERAU
Drives: 2018 F87 M2
Beau-ti-ful.
