BMW M2 Forum > M2 Photos, Videos and Builds > ► Tyspeed Pikes Peak BMW M2 Race Car on 18" APEX FL-5 Wheels.
      05-21-2019, 01:56 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3523
Drives: M3
BIMMERPOST
     Featured on BIMMERPOST.com
Tyspeed + APEX
As a proud sponsor of the Tyspeed racing team, we caught up with driver Tyler Pappas and his crew at New Jersey Motorsports Park as they prepare their BMW M2 race car for the 2019 Pikes Peak International Hill Climb. Preparing the car for this event has been challenging, but the mountain will present an even greater one. The intimidating mountain stands over 14,000 feet in elevation and the race hosts ~12 miles of intense turns without the safety of guard rails. Follow along as Tyler and his team make their way to Pikes Peak.
#BECAUSERACECAR
APEX Wheel & Tire Setup
  • 18×10.5″ ET40 FL-5 Wheels in Race Silver
  • 295/35/R18 Toyo Proxes RR (DOT Compound)
  • 25mm front spacers for suspension clearance
Car Details
  • 2017 BMW M2 Club Racer
  • 3,000 LBS Dry, No Driver
  • Power Rating : 505 whp/ 540Ft/Lbs Torque
  • BMW CCA B-Modified
  • NASA GTS-U
Body, Chassis & Interior
  • Completely stripped interior
  • Tyspeed Composite Doors, Hood, and Deck lid assembly w/ factory mounting
  • RKP Carbon 2×2 Roof From IND Distribution
  • Club Race Spec Roll Cage-Fabricated In house
  • BMW M235IR Carbon Floor pan inserts / 1pc Center console
  • Custom Carbon Door panels/Rear bulkhead/interior trimmings
  • 13 Ecu’s Removed, wiring harness thinned, operational I-drive + Drive dynamics + Functional HVAC/Defrost
  • Sparco Circuit II Seat + Sparco Clubsport Belts
  • KMP Drivetrains F8x Paddle Shift wheel w/ Quick Release + DSC Buttons
  • AIM MXG Data System W/ Smarty Cam HD From Krause + Associates Beta F8x Protocol For CAN BUS
  • Ultrashield Lexan Windshield (custom Cut) Lexan Side windows
  • Longacre Wide View Mirror
  • AJ Hartman Aero Apex 12 Dual Element Rear wing w/ custom CNC machined swan neck uprights
  • Dual Stage Rear Diffuser System + Flat Floor Panel From AJ Hartman Aero
  • AJ Hartman Aero C5 Corvette Front Canards (custom cut)
  • Motorola Digital Long track radio communication system
  • RKP Carbon GP front lip w/ AJ Hartman Aero Custom Splitter w/ tunnels
  • SPA Techniques On board Fire system
  • SPA Techniques Side View Mirrors
Suspension & Brakes
  • Stoptech STR-60 15” Brake kit F+R 6 Piston Front, 4 Piston Rear Fully forged calipers w/ custom brake ducting kit
  • Stoptech Stainless brake lines
  • Performance DSC/ABS Coding
  • JRZ RS-PRO 2 Way Remote Adjustable Coilovers 1000LB Front 1200LB Rear Springs
  • Ground Control Articulating Rear spring perches/ Adjustable Front camber plates
  • Fall Line Motorsports Spherical Front LCA Bushings
  • Fall Line Motorsports Adjustable Rear Toe Arms
  • SPL Parts Front Lower Control Arms
  • SPl Parts Front Bump steer adjusted Tie Rods
  • SPL Parts Rear Forward Trailing Arm kit
  • All Factory Rubber suspension bushings are poly / Spherical replacements
  • Dinan Upgrade Sway Bar Kit F/R w/ Custom End links
  • GTS EPS Steering Flash
  • GTS ABS/DSC Flash
Drivetrain
  • N55B30T0 w/ CP Standard size/compression Forged pistons , Carrillo
  • Connecting Rods, ARP Hardware
  • ARP Studded Block M11x1.5
  • Ported Cylinder head from HeadGames Motorworks
  • CSF Racing 4 PC Cooling kit including Tripe Pass Racing Radiator, Stepped Intercooler, Boss 275 Cubic Inch Oil cooler , and Double pass DCT cooler
  • Dual M4 Auxiliary Radiators w/ Boost pump
  • A/C system Removed + Coded out
  • Pure Turbos Stage 2+ Turbocharger
  • VRSF Stainless Downpipe plumbed into custom-fabricated 3” Oval Exhaust
  • Burger Tuning Catch Can + Oil cooler bypass Valve
  • Custom Tuning By Frank Smith for MS109 Fuel
  • Meth Injections system w/ Pre+Post Inter-cooler Sprayers
  • GTS Rear Differential Flash
  • GTS Transmission Flash
  • Powerflex Poly Rear Differential Mount bushing Set – Black Series
  • VRSF 2 PC Charge Pipe
  • Pyrotec 15 Gallon Fuel Cell w/ walbro 450 In Tank Pump + Dry Break Filling System
  • XDI 35I High Pressure Fuel Pump from TTFS
  • Tuned to 505 WHP / 540 Ft/Lbs OF Torque
Sponsors
  • APEX Race Parts
  • CSF Radiators
  • Stoptech Brakes
  • Sparco
  • Pure Turbos
  • Toyo Tires
  • IND Distribution
  • Liqui Moly
  • Eventuri
  • KMP Drive Train
  • CSL Design NJ
  • AJ Hartman Aero
PHOTOS
Appreciate 19
      05-30-2019, 11:21 AM   #2
bimmer456
Drives: 340i
Check out the electric E36. Wonder how this would do on pikes peak. Only issue is endurance though as the battery capacity is reduced to save weight. It's supposed to be better at putting out power than a Tesla battery. And the motors are in back with the battery pack occupying the space under the hood. Strictly for going fast and stopping fast and having 50/50 weight distribution.
      05-30-2019, 11:52 AM   #3
nathanm4
nathanm4's Avatar
Drives: Aston Martin Vantage
hope he wins the race!
      05-30-2019, 12:04 PM   #4
Igor_M5
Igor_M5's Avatar
Drives: Many, BMW.
Love that they used some of the most common and biggest supporting brands in today's BMW AM industry for this incredible build.
Good luck TY!
ApexWheels1426.50
      05-30-2019, 12:34 PM   #5
Brake_Late
Brake_Late's Avatar
Norway
1938
Drives: 2015 F82 M4 FIREORANGE2
Lit 2 🚆🔥🏁
#dankeniki
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
      05-30-2019, 12:48 PM   #6
dezzracer
Drives: 2018 M3 CS
Off the hook. What a car. Im from Colorado. When the pikes route was dirt you had to have a sack to pull out the stops to the top.
Brake_Late1937.50
ApexWheels1426.50
      05-30-2019, 01:16 PM   #7
m981addicts
m981addicts's Avatar
Drives: 98Mz3-09-135i6sp-13-135isDCT
Originally Posted by bimmer456 View Post
Check out the electric E36. Wonder how this would do on pikes peak. Only issue is endurance though as the battery capacity is reduced to save weight. It's supposed to be better at pitting out power than a Tesla battery. And the motors are in back with the battery pack occupying the space under the hood. Strictly for going fast and stopping fast and having 50/50 weight distribution.
Haha, Brahdah literally 'in da hood!'
      05-30-2019, 01:19 PM   #8
bimmer456
Drives: 340i
Check out dudes YouTube channel Rich Rebuilds. He literally rebuilds wrecked Tesla's and gets them for super cheap. He's opening the worlds first Tesla independent repair shop.
Brake_Late1937.50
      05-30-2019, 06:10 PM   #9
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Rimac with his electric E30 drag car did it first, but definitely cool to see more and more people doing Tesla swaps (think LS swaps) these days though.
      05-30-2019, 07:00 PM   #10
///M4TT
18’ F82 ZCP
///M4TT's Avatar
Drives: 18' F82 ZCP in MGM
Nice car; great race!
I saw the Audi Quattro dominate the Pikes Peak Hill Climb in the 80s. I was only a kid but that race is unforgettable. Later named a Great Dane Zebulon (Zeb) after the Mountain.
Good luck and stay safe!
2018 F82 ZCP MGM
      05-30-2019, 09:26 PM   #11
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Since there are no Tesla dealers, every Tesla shop is an independent.
      05-30-2019, 09:30 PM   #12
MilehighM3
MilehighM3's Avatar
2009 E90 M3  [6.50]
OP- what class is he entered in? I'm local and will be watching. Hopefully the car has seen some higher altitude testing. If nothing yet, I hope they arrive plenty early for some testing ahead of practice. Performance and tuning at altitude is an entirely different process and they will have some issues. Hopefully TTFS will be available to help them out. I'd love to see the car finish the event.
      05-31-2019, 12:39 AM   #13
bimmer456
Drives: 340i
There are locations that do maintenance and repair while you're under warranty, not any independently owned and operated Tesla shops as you can't purchase parts or DIY your own repairs directly from Tesla, you would have to source junk yard vehicles for parts.
      05-31-2019, 07:13 AM   #14
TYSP33D
TYSP33D's Avatar
502
Drives: 16 M2
While Its a shame this thread has been jacked by some random guys driving a Tesla- I appreciate everyone elses' support, including Expert@ApexRaceParts
Regarding high altitude tuning MilehighM3 -
Frank and I have discussed , and basically all we are going to have to do is adjust the MAF scaling parameters by doing a few base runs and sending him logs.
Luckily , there is 4 days of practice, with the first day being at the highest section. This will allow us to get the tuning right on day one, and hopefully survive the rest of the weekend.
This is a race against the mountain for us (and others), not other competitors.
      05-31-2019, 07:25 AM   #15
TYC
TYC's Avatar
24
Drives: 2015 M235i TE
Any chance I could get some more information about the DSC, and ABS work that you had done.
I run in a time attack race series
@theyoungcarmody
2015 m235i track edition
PTF / Bm3 n55 dev car / brand ambassador
Cscs time attack - street rwd
Who says a race car can’t also be a show car?!?!
      05-31-2019, 04:44 PM   #16
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Very impressive build!
How is this car able to run two M4 aux radiators? Is one placed in front of the oil cooler, or? Also I am curious about the flow rate / power rating of the aux radiator booster pump and how it was configured. All three radiators in parallel or series or? AFAIK the M2 already had one booster pump from factory.
And finally, is the car actually able to stay cool in hot weather on track with that kind of power? Any data available?
Also an important part was left out - what brake pads does the car run on track?
      06-13-2019, 09:09 AM   #17
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Glad to be part of it!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      08-15-2019, 10:23 PM   #18
243Racing
1448
Sooo how big of spacers up front? Ugh I have so many questions
      08-15-2019, 10:25 PM   #19
243Racing
1448
He’s got a lot of detail on his own thread here on the forums but it kind of died
      08-16-2019, 03:35 PM   #20
Expert@ApexWheels
3523
Drives: M3
Great question! He's running 25mm front spacers to clear the suspension. We'll update the OP with this info as well.
--Dylan
243Racing1447.50
