07-12-2022, 07:59 PM | #23 | |
Rep 582
I didn’t intend to be condescending to anyone so apologies if my writing came across that way. Just attempting to share my experience and provide a different viewpoint that it is in my opinion not a case of weak motor and / or transmission mounts but rather something OP is doing in order to save him some money. I think possibly the way I worded my initial response could have been more precise. The point of mentioning my experience is that if there was an inherent problem with the stock mounts, then why wouldn’t I have experienced issues as well given the amount of time I’ve spent on track with sticky rubber, camber and stiffened suspension which can handle even higher loads? And I do track at multiple circuits that require 2nd gear, including Palmer and Thompson. I also didn’t encounter this issue from any of the other M2 drivers I’ve discussed things with. Unless some model years have different parts, which I don’t think is the case. As you are suggesting, I’d also advocate for OP to first rule out something he may be doing. Then he can use his saved money on unneeded parts on something fun, like better tires.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
DRLane3988.50 |
07-12-2022, 08:02 PM | #24 | |
Rep 582
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber Last edited by dvas; 07-12-2022 at 08:16 PM.. |
07-12-2022, 08:13 PM | #25 | |
Rep 7,298
I have seen this complaint on M cars a lot over the years. Denial into 2nd when in a turn is pretty common I'd say. I've heard occasionally it from E46 M3 owners, E92 M3 owners, Z4M owners, F8x owners, etc. I followed the Z forums the most and know that most people that encountered this denial were able to help it at least with the engine and/or transmission mounts. It was really prevalent on the Z4M, I even experienced it on the street. BMW just tends to use soft mounts for NVH and this is a possible side effect. |
07-14-2022, 08:10 PM | #26 |
Rep 217
Thanks for all the ideas and feedback. A few thoughts:
1) I'm going to hold off on motor mounts since I can focus on shifting in a straight line instead. 2) I've always shifted with a side grip, but recently moved to more of a top grip for safety reasons. However, I think the top grip could be part of the issue. Today I tried going back to a side grip, but applying the safe-shifting techniques (palm of hand, just fingers, pushing away, etc.). Also, I've been reading a lot about workplace ergonomics recently, and the side grip is a much more ergonomic arm position, so I suspect it might have better control. 3) My car is 5 years old now with 15,000 miles, and I've never changed the transmission fluid. On my other cars I typically swap fluid every 30,000 miles which ends up being every 2 years. But perhaps 5 year old fluid has degraded some, particularly after some track days? I've heard fluid expires in un-opened bottles on the shelf, so I assume it would expire in the transmission as well. I'm aware of the "lifetime fill" guidance from BMW. I don't buy it since shifts in my other cars always get smoother after a flush. I'm on the track this weekend, but planning to do a flush afterwards.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" |
07-17-2022, 10:59 PM | #27 |
Rep 217
Update after being on track this weekend: I didn't have any situations where I needed 2nd gear at Road Atlanta, so I wasn't able to try any alternate approaches there. But I did end up staying with a "top" hand grip while moving my elbow over to the armrest for shifts, and it worked perfectly all weekend going back and forth between 3rd, 4th, and 5th.
I think I may just avoid 2nd gear on the track going forward.
bentom2335.50 |
07-18-2022, 08:40 AM | #28 |
Rep 41
Drives: 2016 BMW X5M
Glad to hear it's not just me who's had this.
Exact same, only happens on the track under lateral load. I'm going to try to downshift earlier before the turn in. |
07-18-2022, 09:33 AM | #29 |
Rep 500
If it helps:
Trouble finding 2nd gear under load https://f87.bimmerpost.com/forums/sh....php?t=1739227 |
fleetfoot120.00 |
