07-13-2020, 08:48 PM | #1 |
Rep 500
Trouble finding 2nd gear under load
This has happened 2 or 3 times during track driving. Basically I've had a few instances of difficulty finding (engaging) 2nd gear (M2C 6MT) just after heavy braking and while beginning lateral load from turn-in (always to the right). I remember it happening at Daytona on Turn 3 and also at Sebring on Turn 7.
I have an AutoSolutions short shift kit with 95A bushing on left side and OE bushing on right side (long story short: Ron messed up and only sent one bushing). I initially thought the problem was just me not being used to the SSK, but I've been driving it for some time now and beginning to wonder if the shifting under heavy load (and the bushings) may have something to do with it? Anyone experience anything like this? |
07-13-2020, 09:15 PM | #2 |
Rep 427
My local tracks don’t require a downshift to 2nd, but I’ve encountered a similar situation for 4->3 downshifts if I wait until I’ve started turning to make the downshift. As long as I downshift where there’s no lateral load, I have no trouble in the same corner entry, and there’s really no good reason for me to be shifting while turning at my local tracks. I’ve just made it a conscious effort to shift a bit earlier- before turn in.
My assumption is that the powertrain is leaning on the engine/trans mounts and altering the position of 3rd gear. I’ll be interested to hear if others are encountering this. |
4
07-13-2020, 09:27 PM | #3 | |
381
Rep 731
At a Point above 7,000 RPM.
Daytona_550463.50 |
07-13-2020, 09:32 PM | #4 |
Rep 1,662
I also have the Autosolutions SSK, love it. I try and get my downshifting done right before turning in. This weekend there were a couple of times when I needed to downshift from 4th to 3rd mid corner when being given a point by from a car that had slowed me up a lot, but didn't notice any difficulty shifting. The M2C has so much torque it would need to be a very slow corner for me to downshift to second.
Semi related but I find heel and toe so annoying to get right on track, probably because I'm not at the level where I'm 100pc consistent. I flip flop between lifting the heel and shifting the side of my foot across to blip or just having the ball of my foot on the brake and side footing the throttle. Probably just need to stick with one. Its hard to really fine tune on the street as its very rare you are that deep in the brakes. Not being able to enable throttle blip with DSC off was one of the most stupid design decisions in the f8x generation IMO, I'm literally considering BM3 just so I can enable it. |
smknjoe234.00 |
07-14-2020, 02:42 PM | #7 |
Rep 660
I've almost mis-shifted into 2nd twice when attempting to go from 3 -> 4 - this happened when I was going around a long and fast sweeping left turn (at thunderhill west, if anyone is familiar with that track). I really had to concentrate on making sure the shifter went into the correct position - this is literally the easiest shift, straight back! So I do agree it does seem to shift a bit under lateral load.
07-14-2020, 03:41 PM | #8 |
Rep 744
Not to stir the pot but its interesting to hear some frank reviews of the manual instead of the usual huzzah around them.
Makes me glad I picked the DCT as slopy/difficult shifts is the thing I liked least about my previous car. Dont get me wrong I love manuals (half the reason I own an NA Miata) but the ease of the DCT is just beautiful.
Maynard3848.00 |
07-14-2020, 04:50 PM | #9 |
Rep 500
Thanks all for the feedback. Surprised to see that this is a fairly common thing.
I'll reach out to Ron to get his thoughts and to upgrade the SSK bushings to a harder compound. |
07-15-2020, 06:18 AM | #10 |
Rep 408
I've had a similar issue.. Headed fast into a hairpin right turn down a mountain with heavy braking, tried to downshift from 3 -> 2 and the stock shifter disengaged from third but felt like it was blocked out of 2nd and would not move into 2nd until I cleared the turn and the car straightened out. I doubt it's because of the SSK, more a BMW and their transmission problem. I usually try to downshift earlier and make sure I'm in the right gear before coming into a similar situation again.
07-15-2020, 06:41 AM | #11 | |
Rep 88
Yea I know exactly what you mean, although I feel it's just due to the amount of play in the shifter.
07-20-2020, 02:01 PM | #13 |
Rep 69
For the 3-2 Down shifts you many be crossing over to the reverse area of the shifter gate...You know how you have to push hard to the left to get to reverse... I have found that this area of the shifter gate prevents engagement of 2nd for example on a 3-2 shift. On track it could easier to accidentally push the shifter too far left preventing engagement into 2nd.. Give it a try and see if this replicates the feeling.
ashmostro1254.00 |
05-25-2021, 01:53 PM | #16 | |
Rep 500
The original issue only happened on track, and I haven't driven it on track since these changes. Next track event is Barber in July. I'll post some feedback afterward. |
Fined243.00 |
05-26-2021, 09:44 AM | #17 |
Rep 2,873
For those who aren't lifelong track shifters, practicing heel-toe is really essential; since it requires DTC off, it is sort of suicidal to be tracking w/o total confidence (so best bet is leave at least MDM on and go w/revmatch). If there is a way to code revmatch off while still having DTC that would be ideal, because DTC-off makes for expensive learning curve. Start with stationary practice sitting in the car going thru it until it is smooth and consistent (like an hour, not just 'til you get bored and the song ends). Then use it on the street all the time, until it really becomes second nature. You really need 4 point belts to stay in place in the seat too, without the dead pedal support. Disclaimer is that I spent my early life doing this, when MT was the only real option in a performance car and the usable rev range was about 2000rpm wide if you were lucky; now I'm in a DCT and loving it.
m400vfr4000.00 |
07-15-2021, 03:38 PM | #18 | |
Rep 500
The changes I made were going to the hardest bushings on the AS SSK, Rogue Engineering transmission mounts, and a Turner rear carrier bushing for the shifter. |
07-16-2021, 12:26 PM | #20 |
Rep 500
07-16-2021, 12:42 PM | #21 | |
Rep 4,134
Keep in mind, I have an M235i, and the M2 Drivetrain mounts are more robust (transmission and engine mount are shared with the M3/4 and are stiffer) Since you made the changes the driveline, please keep us posted on how it turns out.
Mods: Yes.
chris7197334.00 |
09-23-2021, 12:55 PM | #22 |
Rep 500
Update: the 2nd gear lockout issue popped up again a couple of times this weekend while braking hard at Sebring's Turn 7. Both times were on 3-2 shifts while straight-line braking (no lateral load).
