M2 Technical Topics > Suspension | Brakes | Chassis > Spring removal with Jack lowering
      04-05-2020, 03:15 PM   #1
widetyres
279
Drives: M3 E92 DCT, 2012
Hi,
I'll be fitting my AST coilovers soon - can't wait to try them!
Re removing the old shocks, has anyone lifted their front suspension arm with a jack to compress the spring tension, removed the strut nut and then lowered the jack slowly to gradually release spring tension?
I do have some spring compressors, but doing the above seems to my mind safer and quicker.
Any thoughts or experience?
Cheers!
      04-05-2020, 03:43 PM   #2
Drop the hammer
Drives: '17 F87 M2 AW, Dct
Yup, that’s exactly what I did for my coil over install. I followed a YouTube video. It was pretty easy. I put the front of car on jack stands under each front jack point, then with wheels off ground did the job using my floor jack to support hub and then lowered it after the nut was off. Just have to remove headlight sensor and the sway bar off strut. That’s about it. I watched a couple YouTube’s the day before I did it.
widetyres279.00
      04-05-2020, 04:01 PM   #3
M Fifty
844
Drives: M2 & 330CI
Originally Posted by widetyres View Post
Hi,
Cheers!
Yes to the above. I also fitted the coilers the same way - but in reverse.
widetyres279.00
Kankles1484.50
      04-05-2020, 04:05 PM   #4
supersam
Da Baus
supersam's Avatar
Drives: F87 6MT, RA, E46
Yes. Our coils don't expand thaat much with offloading
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
widetyres279.00
      04-05-2020, 04:09 PM   #5
widetyres
279
Thanks all for confirming that'll work - super glad about that as i wasn't really looking forward to the spring compressors.
Thanks!
      04-06-2020, 05:14 AM   #6
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Thanks!
If you watch Evolve YT channel for suspension swaps on their bmw fleet (m3/m2) and supra, it looks as if they use this method.
Current '22 X3M LCI..
widetyres279.00
      04-06-2020, 07:52 PM   #7
Nezil
Nezil's Avatar
1403
Drives: LCI '18 6MT M2
I did my strut top hat replacement for the M2C / M3 / M4 brace the same way, after watching the Evolve video. It was actually really easy and I'm not sure why others wouldn't do it this way.
The only thing that would help to have a helper for, is aligning the strut shaft as you jack the car back up. I did it alone, but it was kind of awkward pushing in one direction and trying to pump in another.
I also used a Quickjack to lift the car rather than jack stands, which might make it a tad more stable.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
Bee Pee1779.00
widetyres279.00
      04-07-2020, 02:03 AM   #8
M Fifty
844
Drives: M2 & 330CI
Undoing the drop link beforehand makes things easier too.
Bee Pee1779.00
widetyres279.00
      04-08-2020, 07:58 AM   #9
widetyres
279
The Evolve videos are actually super helpful for tips - I like the way that they undo the rears by removing the inner arm bolt, instead of the camber bolt on the hub - again, looks a lot simpler.
It'll only take me 10 mins now per corner!!! (I wish!!!)
Bee Pee1779.00
