06-01-2018, 08:20 AM | #177 |
Rep 105
I own a 17 DCT M2 and I really want to buy the new bigger brakes when they release it as an MPerformance Upgrade!
Does anyone of you know when it will be available and what the estimated costs are? How much could be asked for lightly used M2 brakes about 7000km old? |
06-01-2018, 11:16 AM | #178 | |
Rep 3,714
M3 Adjuster7909.00 |
06-01-2018, 11:32 AM | #179 |
7909
Rep 11,785
06-01-2018, 02:03 PM | #180 | |
Rep 552
I knew that going in, that the PFC's would be as you described, which actually sounded good on paper, but in reality is not what works for me. I am smooth with all my inputs, and thus, having a pad that doesn't have a lot of initial bite probably is not for me. It would be one thing if the PFC's would end up grabbing like I am used to, but it seems to me, even when I start to really step on them, they just refuse to bite as much as I want. I drove a friend's car back to back and he has Stoptech brakes and their pads and they felt much better than the PFC's also. I should say that I only switched the front pads, and the rears are still Hawks, but I don't think that matters. Maybe it is something else? Rotors glazed or brake fluid not good anymore? The reality is that my times are very close, so the results are not much different, but it feels like I am having to brake a bit sooner, which should be slower. I have a track day next Friday and will bleed my brakes and put the old Hawk pads on for a couple of sessions. They still have a few mm on them and i'll see if I can make rhyme or reason of what is going on. Last edited by norMcal; 06-01-2018 at 02:52 PM.. |
06-01-2018, 03:33 PM | #181 | |
7909
Rep 11,785
track pads really do impart a lot of materials onto the rotors. In my experience, the pad materials between Hawk and PFC are not very compatible. It might even take a full event for the PFC pads to transfer enough onto the rotors for them to become effective. For people that swap pads for street and track.. it helps to stay within the brand... Just as if one were to play tennis or basketball... if you normally wear a Reebok or a Nike show for casual activity.. one probably should keep with the same brand for heavy activity. I imagine if you swap pads back... it likely may take some time for the Hawk pad material to transfer back onto the rotors before the Hawk pads feel like they are in good order again.. I would endeavor to give the PFC a second chance.. only because they likely are just coming into their own with regards to pad transfer. Clearly you aren't radically SLOWER.. so that's a good thing. interesting on the feeling that you need to brake sooner with the PFCs... I guess that it may technically be true.. that one can feel the need to brake a little sooner with the PFCs because of the lack of the sensation of the initial bite of the hawk pads. That doesn't necessarily mean that the PFC are worse.. to me.. the high initial bite also creates heavier front end dive. getting on the brakes a little sooner and not having the weight transfer forward as much may end up with better chassis balance at turn in. I would trust the lap times...but certainly driver comfort is a concern. If you have a chance to check out the PFC a second time.. I would do so... if you still dislike them then rip them off and go back to Hawk. As stated previously., the Hawk initial bite is very addictive.. and many people once they have that sensation... cant get away from it as it becomes a bit of a security blanket. Last edited by M3 Adjuster; 06-01-2018 at 03:42 PM.. |
06-01-2018, 05:12 PM | #182 | |
Rep 7,340
06-01-2018, 09:13 PM | #183 |
Chief Warrant Officer
1025
Rep 1,638
Question:
How many members here complaining about the additional rotational mass and curb weight of the new brakes are actually competitive racers with anything at stake beyond pride? None? Thought so. So either way, does a tenth of a second added to or subtracted to your weekend track warrior lap time at Watkins Glen or Willow Springs really matter one iota? No? Well then how about we just enjoy the car and stop nit-picking irrelevant minutiae? Just my two cents, but trying to put this all in perspective.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
06-01-2018, 10:14 PM | #184 | |
Rep 650
Cavpilot2k1025.00 |
06-02-2018, 01:43 AM | #185 | |
Rep 13,166
///M is art ↔ Artemis
Cavpilot2k1025.00 |
06-02-2018, 02:41 AM | #186 | |
4143
Rep 6,926
06-02-2018, 05:52 AM | #187 |
Rep 3,361
No matter how much it might be marketed, discretely, with pictures on a track etc, the M2C, like the M2 before it is simply....a competent street car which is where 99+% of them will spend essentially near 100% of their time. It is what it is -- a nice combination of essentially bin available parts that will allow BMW to make a profit selling into a niche in the marketplace.
We'll know BMW is barely becoming serious when they allow front camber adjustment so these M-cars don't lean on the outer 2" of the front outside tire and rapidly overheat and chunk/cord the tires at the track. They've gone the other direction after the E9x generation and have taken away what little extra negative camber adjustment there was back then. In SCCA street class autox competition, where no modifications beyond one sway bar are allowed, competitor American iron have adjustable front camber that puts BMW to shame. Just like all prior BMWs, if one seriously wants to track this car, you need: decent coilovers with adjustable camber plates, adj sway bars, etc; however, you can probably get away with using these new brakes, even with R-comps and limits of the car driving, if you use a good fluid, Ti shims between piston and backing plate, and a good race pad. Ditch the front pads when they are 2/3 worn to keep heat transfer to caliper down. It'll work fine. However, that takes away the point of an M2C -- which is that it is a street car. Serious track driving should be done in a serious track car -- full cage, fire system, seat, harness, HANS, window net, etc, in my opinion (and fortunately or unfortunately, depending on your view, the growing opinion of insurance industry underwriters -- just look what they did here in NC to the liability policy language (all companies required to use same policy - regulated) for people who use their car on track!)
Current Stable:
Cavpilot2k1025.00 MR_M2522.00 |
06-02-2018, 10:15 AM | #188 | ||
Rep 552
You raise a good point/concern, maybe it would not be ideal to swap pads back and forth. Although I think a day of street driving usually removes the impeded material on the rotor and I drive a couple hundred miles to get to Laguna Seca, so I would think the rotors would be preped by the time I get there. Just swapping back mid day would not be a good strategy. Quote:
I don't want to sound like a broken record and keep bringing up my e46 M3, but since this M2 was supposes to be the replacement for it, I tend to compare all aspects against it. If i was in the market for a new street car that I would occasionally take to a HPDE, then the M2 is a fabulous car, I'm sure. But for guys like me, that want it as a second car, and want it to be a track toy, it does appear like it missed the mark a bit. Getting heavier than the regular M2 was definitely not what I was looking for, and I do care a lot about un-sprung weight. However, I also know from a guy that tracks his M2 a lot, that the stock brakes are at best, at the very limit of being able to take the abuse. I am all for going with the smallest/lightest brakes one can get away with. And I have never been someone who is aggressive on brakes. I am more of a momentum driver. But, with the added pork and power of this car, I have a feeling the bigger brakes are necessary. |
M3 Adjuster7909.00 M+M226.50 |
06-02-2018, 12:55 PM | #189 | |||
7909
Rep 11,785
The M2 Competition has bigger brakes because Big Bertha has added on more weight in the M2 Competition years. |
06-06-2018, 03:19 PM | #190 |
Rep 923
When you read this M performance list: http://f87.bimmerpost.com/forums/sho....php?t=1503472
According to this list; the Retrofit Kit 19-inch compound Brake system are not available for the normal M2... Strange?
06-06-2018, 03:25 PM | #191 | |
Rep 3,660
Drives: 981 Cayman GTS
06-06-2018, 04:11 PM | #192 |
Rep 923
The standard M2 comp brakes are the same as the M2...so I would presume the bigger brakes would fit on both...Maybe BMW don't want owners of the M2 to fit them, but that is another matter.
06-06-2018, 04:18 PM | #193 |
Rep 3,660
I think the whole point behind the red M performance BBK is to make more money by selling it to M2C owners who went with the smaller blue brakes as well as the original M2 owners. So I'm pretty sure you can retrofit them on your M2.
06-06-2018, 05:52 PM | #194 |
Rep 923
I would still rather have the silver 2NH calipers...but ordering those in parts will indeed be more expensive then the red kit.
06-06-2018, 05:53 PM | #195 |
Rep 3,660
06-06-2018, 06:03 PM | #196 |
Rep 923
06-06-2018, 06:29 PM | #197 |
Rep 2,787
You won’t have any problem selling them. I know some M4 owners interested. Many M4 CCB owners have switched to iron rotors, essentially creating a 2NH. RB has a two piece iron rotor set for CCB. They should theoretically work on 2NH, they will save about 12lbs over 2NH oem rotors. Definitely an option when rotor replacement is needed.
06-06-2018, 06:37 PM | #198 | |
Rep 3,660
