11-09-2021, 02:27 PM | #23 | |
Rep 3,046
Drives: 2019 M2 Competition
If your cuts (mid to exhaust) have some gap AND the torca clamps are loose enough they can vibrate together, that would absolutely cause noise/feeling. Depending on gap, clamp strength, dirt in the gap, and other variables, it could absolutely only be an issue at certain RPMs or engine created vibration levels. Great thought!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
11-09-2021, 02:47 PM | #24 | |
Rep 73
11-09-2021, 04:47 PM | #25 | |
Rep 89
11-11-2021, 07:49 AM | #26 | |
Rep 2,320
BMW DIY Guy3109.50 brand new guy16.50 |
11-11-2021, 10:03 AM | #27 | |
Rep 3,046
Some like you and I have no problems whatsoever, sounds great and is awesome. Some, from the videos, have real problems and I am trying to understand why. There clearly are some variables involved.. install, fitment, clearances, what specific other components, and so on. If it was always bad, I would say ok.. there is a product problem but that isn't the case. Since many folks, and would anecdotally say the majority of folks, don't have issues then its something about the install itself. My hope is that if we can identify the variables we can find a common source of any rasp, and therefore can fix it for those (few?) that do have it. Call me a raging type A.. *laugh* There are a few folks so passionate about this, that I would love to find a solution, since there are examples of it working perfectly. If yours/mine/others work fine, we can find what is different.
11-11-2021, 10:06 AM | #28 | |
Rep 2,320
11-11-2021, 10:07 AM | #29 |
Rep 3,046
Hmmm.. I am catless.
11-11-2021, 10:12 AM | #31 | |
Rep 3,046
I am working on an fully comprehensive comparison video for sound changes with midpipes. Video will be the following configurations. Component combinations: 1. Full stock OEM - downpipes, midpipe and exhaust 2. Stock downpipes, Active single channel midpipe with and without resonated AB pipes, and stock exhaust. 3. Active downpipes, Active single channel midpipe with and without resonated AB pipes, and stock exhaust. 4. Active downpipes, Active EL midpipe with resonated AB pipes, and stock exhaust.
11-11-2021, 10:25 AM | #32 | |
2435
Rep 11,669
do you mind listing what is in your system? - down pipes: OE , HF CATs, CATless - Mid pipe: resonated or not - back box? I have done tons of exhaust work over the years, including working with a system fabricator doing test fitting etc. In my experience the single biggest contributor to rasp is running HF CATs, or CATless. To a lessor degree resonators design/elimination. Vibrations, (especially those that are intermittent) are usually install related. One of the biggest things that installers miss is the shift rearwards of the system with heat. I have come across simple things like length of screws that make contact, only when hot. I've also seen the same situation but opposite result, vibration when cold but goes away when hot. In a nut shell there are lots of variables in play with a system that is designed within close tolerances and it doesn't take much to have an issue. |
BMW DIY Guy3109.50 |
11-11-2021, 10:29 AM | #33 | |
Rep 3,046
11-11-2021, 10:34 AM | #34 | |
Rep 2,320
BMW DIY Guy3109.50 inTgr8r2434.50 |
11-11-2021, 10:42 AM | #35 | |
2435
Rep 11,669
A harmonic resonance can occur at a specific RPM and can be engine/drive train related. The system will vibrate more at a specific resonance and make contact with that needle in the haystack screw. You did well to find and isolate that! That's also why you see resonance dampers on some OE systems. Usually just a weight(s) clamped onto the pipes. |
11-11-2021, 07:51 PM | #36 | ||
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
11-11-2021, 07:59 PM | #37 | |||
Rep 2,320
11-12-2021, 12:21 AM | #38 | |
KYHOMPB
219
Rep 461
Drives: Only BMW's Ja
11-12-2021, 09:02 AM | #39 | ||
Rep 3,046
I am trying to understand though why this is the case.
11-12-2021, 06:25 PM | #40 |
Rep 32
Some notes.
I have gone through my decat, El res, and remus race backbox twice. And I have checked all bolts, loosened and tighten everything again, but to no avail. Still raspy at around 1500-2500 rpm when driving normal. It's raspy as soon as I drive, so heating and expansion should not do any difference. I have Coldstart coded out. I can note that the choice of clamps between the two parts of the equal length is a peculiar one. The clearance between the pipes at the crossover part is very small. I believe the problem lies in the side of the exhaust that bends from the aft turbo. The exhaust speed is reduced because of induced turbulence in the pipe because the gasses mixes at each bend, and introduce disrupted flow. I think the evidence is that the bendy part is clearly much hotter than the straight pipe by looking at the colors. This could also mean the bendy part of the equal length expands more due to heat than the other straight part. I find that the exhaust is less raspy with opened valves. I believe all this just how my exhuast and the setup is ok. For example if I use the same the throttle input from 2500 to 3500 rpm, the exhaust doubles in volume when I hit 3000 rpm. Another thing is I can create an extremely loud reverberance if I floor it at 2500rpm and let go at 3000 rpm, sounds mental. The sound also increases in volume when heated up. Link here for sounds |
11-12-2021, 06:39 PM | #41 | |
Rep 3,046
FANTASTIC write up, thank you for such detail and being so thorough! Its a very interesting thought that it could be gas speed down both pipes?
11-17-2021, 02:27 AM | #42 |
Rep 638
Drives: M2C
I'm very happy with my EL non-resonated despite admittedly not being 100% perfect.
Setup is: -stock DP -EL non-res -stock muffler (non-M) The only time I ever get bad sound is on some cold starts (meaning not 100% of the time). Likelihood goes up as overnight temps decrease (I park outdoors). Here is a video showing the issue (it will be even worse than this in Jan ) Other than that? Love the sound. revs: red lining: boring driving at low revs: With that said, I was disappointed last month to see I was a victim to a melted defuser. Confusing thing is that it took many months after install for it to happen... https://f87.bimmerpost.com/forums/sh...4&postcount=15 I also occasionally still get these vibrations, especially when making tight turns within the first minute or so of a cold start: I realize that the melted diffuser and vibrations are due to install issues but I'm weary of taking it back to the shop since despite these issues I'm happy with the install since 99.9% of the time it sounds perfect (and the diffuser can't get unmelted...) |
11-17-2021, 09:43 AM | #43 | |
Rep 3,046
Side note, I am in the Seattle area as well and done this install a ton.. need review of your fitment I can help. Shoot me a DM if so.
11-17-2021, 11:53 AM | #44 | |
Rep 3,046
OEM is 1.3mm AA is 1.52mm So I understand your concern on this point at least, but when measuring that is not the case.
